Sat, Jan 4, 4:08 AM CST
Subject: Anton Hair Question
glennjan ( ) posted Wed, 04 December 2002 at 7:21 PM · edited Sat, 04 January 2025 at 4:02 AM
Just picked up the changing ponytail set.......Just let me say first...LOVE IT!!!...Now I have applied the mat post with trans map for the hair ..Is the hair supposed to look ..kind of chunky I havent seen any different maps for it but I kind of wanted it to look more wispy or more realistic I guess is what I mean...any Ideas?..Thanks Glennjan
melanie ( ) posted Wed, 04 December 2002 at 7:58 PM
Which version of Poser are you using? I'm only familiar with P4. Check to see if your transparency falloff is set at 0%. Sometimes that will affect the way transparency works. Melanie
Momcat ( ) posted Wed, 04 December 2002 at 8:46 PM
The way the hair was modeled doesn't seem to allow much in the way of transmapping, so that's why it looks more like high res video game animation hair than real. What you can do is add wisps of loose hair in postwork. That adds a lot more realism.
queri ( ) posted Thu, 05 December 2002 at 12:50 AM
MysticWinter has done a set of textures for this hair that utterly transforms it-- not sure if they are here or at 3-d Arena. Makes all the difference. So does a bit of blur. Emily
Puntomaus ( ) posted Thu, 05 December 2002 at 1:26 AM
The textures for Vickys changing pony tail are over at 3-d arena and they look really good.
bloodsong ( ) posted Thu, 05 December 2002 at 7:05 AM
heyas; you might try turning down/off the bump map, if it is using one. it appears as if it may be using a bump map to make the strands stand out more.
nikitacreed ( ) posted Thu, 05 December 2002 at 10:28 AM
Definitely pick up Mysticwinter's textures for the changing ponytail!! They are beautifully done and give the hair a more wispy appearance.
Exotica ( ) posted Thu, 05 December 2002 at 12:17 PM
Where exactly is the freestuff over there? i don't see any link for it. Thanks
xoconostle ( ) posted Thu, 05 December 2002 at 1:41 PM
If you have Photoshop 7, you can try using the Liquify filter to smooth out those harsh angles. Select the specific area you want to work on, set the "brush" size very low, perhaps as low as 1 pixel, set the mode to "loose" or something like that. Using very subtle nudges, push the angles into more flowing shapes. I use lo-res Michael and Vicky a lot, so this technique comes in handy for rounding off those unwanted hard-angle verticies.
Puntomaus ( ) posted Thu, 05 December 2002 at 2:37 PM
Exotica, you find the textures by MysticWinter in the shop over there - not in the freestuff.
melanie ( ) posted Thu, 05 December 2002 at 7:28 PM
Could someone put a link to that site, please. I'd be interested in checking into those textures. Melanie
glennjan ( ) posted Thu, 05 December 2002 at 7:40 PM
http://3-darena.com/ The hair textures look interesting anyone have a closeup of them in use?
mysticwinter ( ) posted Thu, 05 December 2002 at 9:07 PM
Attached Link: http://www.mysticwinterdesigns.com/poser/previews/vcpc/more.htm
here are some quick renders I did.. close enough? I just did them in 15 min. no resizing of the image or anything the light is the standard country light.. maybe a search in the gallery to see some of the textures used in a setting? Mystic
Exotica ( ) posted Thu, 05 December 2002 at 10:54 PM
Wonderful, thank you!
