Forum Moderators: Staff
Hello, It's true that Poser does not really have bones. It uses joint parameters to bend the mesh at fixed points. One way might be to get "LifeForms", it builds a skeleton figure from the poser model and uses it to animate the figure inside LifeForms. This skeleton figure can be exported and might could be used as a bones setup in another program. Just a idea to try. Serpent
Hello to all ! Is there any way to get the bones out of Poser4 ? obj, dxf, 3ds... ? Thanx, -Juergen.
