33 threads found!
3-d-c | 20 | 1147 | ||
3-d-c | 4 | 247 | ||
3-d-c | 1 | 329 | ||
3-d-c | 3 | 271 | ||
3-d-c | 1 | 37 | ||
3-d-c | 6 | 96 | ||
3-d-c | 3 | 53 | ||
3-d-c | 3 | 55 | ||
3-d-c | 2 | 233 | ||
3-d-c | 10 | 190 | ||
3-d-c | 23 | 471 | ||
3-d-c | 0 | 19 |
(none)
3-d-c | 3 | 115 | ||
3-d-c | 2 | 49 | ||
3-d-c | 9 | 213 |
116 comments found!
Folks, i am still in it as a content creator. Still doing poser stuff. ANd love it. So check out my store folks....
3-D-Cs Facebook Page: 3-D-C on Facebook
Check the K-Azonica Story and World Evolving: K-Azonica
Check my website and products and the large freebie section: 3-D-C
Thread: Where has all the Poser content gone? | Forum: Poser - OFFICIAL
I still do poser exclusive. .. so check out my store too ;) https://www.renderosity.com/mod/bcs/?uid=502620
Thread: Poser Staff Picks: Feb 6 - 12 | Forum: Poser - OFFICIAL
cool! Thanks!
Thread: Poser Pro 11 Suddenly Won't Launch | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I also want to add: Smith Micro responded to my case, a few minutes after i opened it. Had the right hint/tip. Excellent support.
OK, i got mine back going. I found it related to an installation of LavaSofts Ad-Aware software (that must have installed with an FTP client). Obciously that was causing background communication of Posers Registration to break and then the application to crash. So mine is resolved.
Same Problem here. Tried the workaround, no joy. For me as a content producer, a real desaster.
Thread: Official Poser 11 Logo as PNG or so | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
thanks, yeah i just to do the same thing making my own one... ;)
thanks! since i am yet not fully ready with SF i will take your poser logo :) thanks a mil
Thread: Problems getting Queue Manager to work in a network | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Sorry folks, problem resolved. It was actually after all a firewall issue on my second PC (even though i was convinced i turned that off!)
Thread: Problem with materials created in Poser 11, loaded in Poser 10 | Forum: Poser - OFFICIAL
Actually found at the least the reason, but not why that is happening.... My material has a ambientocclusion node. Poser 11 puts it on the start of the shader tree of the material section in the figure. Poser 10 puts it at the end. Now, when i cut and paste that node section to the end of the material section, the problem is gone. I just wonder what this is about?? I now have to touch lots of stuff manually!? weird... anyone ever exprienced that??
shaderTree { node "ambient_occlusion" "ambient_occlusion" { name "Ambient_Occlusion"
Thread: superfly renders? | Forum: Poser - OFFICIAL
i guess i would need to tweak some nodes and work around with the new nodes...
Thread: Searching the original ReRo Banners | Forum: Community Center
Thanks Bob!!
Thread: is it possible to rotate all the lights at the same time? | Forum: Poser - OFFICIAL
Quote - Quote " Grouping can easily be done with the hirarhcy editor...
easilly? what sort of little scenes do you make? I end up with a big long list of things in my heirachy editor and it is never easy.
Love esther
Turn of all apart from the lights to be shown, that leaves you with very little things showing up in your hirarchy editor. Also, if you keep up the practise with grouping, you can fold the master of a group and dont see the childs.... for example, if i put groups of people in my scenes, i group them under a simple prop, so i can move the entire group around. Then fold the simple prop doesnt show me anything further underneath it.
Thread: Do all objects emit light by default? | Forum: Poser - OFFICIAL
another disturbing effect i have noticed a couple of times, is, that loads of material shaders have an "alternate diffuse" texture or color added which causes the closer objects to another object to be emmitted heavily with light (ie hair hanging close to the head causing a fraction of light close to it...
I usually turn all this things off....
what i usually do is to load a simple prop (i had created a simple ball or something for that) make it invisible in rendering and group all lights under that prop. You can also have some light to "point to" that prop. Then you can move, rotate or whatsover the prop and all lights move along....
Thread: Poser user really frustrated with store contents... | Forum: MarketPlace Customers
