16 threads found!
Cherryman | 3 | 3633 | ||
Cherryman | 5 | 2050 | ||
Cherryman | 2 | 432 | ||
Cherryman | 33 | 5084 | ||
Cherryman | 38 | 5186 | ||
Cherryman | 16 | 717 | ||
Cherryman | 10 | 414 | ||
Cherryman | 2 | 151 | ||
Cherryman | 7 | 303 | ||
Cherryman | 7 | 307 | ||
Cherryman | 3 | 192 | ||
Cherryman | 18 | 570 | ||
Cherryman | 9 | 364 | ||
Cherryman | 5 | 225 | ||
Cherryman | 12 | 277 |
164 comments found!
www.renderosity.com/mod/gallery/index.php
I did some gems last year:
Thread: Renderfarm tips? | Forum: Vue
Quote - Hi Rob,
your message went under the radar because you sent it to the 'info' e-mail (from where came your registration validation) instead of the 'contact' or 'support' e-mail. I'll answer you today.
Fred
I got it, tnx for youre replay!
Quote - Hi,
in the case you'd like to send projects to the RANCH, I recommend you read our PDF User Guides here. You will find answers to most of the questions you can have... You can also contact us by e-mail or phone.
Cheers,
Fred
Well.. I did email to the ranch at 14-4-2010 Did not receive an answer yet...
Regards,
Rob.
Thread: help: animation timelines | Forum: Vue
I'm sorry Bruno, but i think i misunderstood you.
Deleting or creating / loading object will not be recognised by keypoints.
As far as my knoledge the only way is making it either invincable with animated material/scaling or moving it very quickly out of side.
Thread: Difference or a problem with gizmos in Vue 8? | Forum: Vue
It could be that youre pivot point is not in the middle of the object. Try resetting the pivot point and see if it still is outside the box.
Thread: I could really use an animated mushroom cloud. | Forum: Vue
hobe, nice to be of assistance.
I would love to see youre finished render. Please share when you have finished
Good luck.
Thread: Nuke explosion | Forum: Vue
Maybe this helps:[
cloud.http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3502440&ebot_calc_page#message_3502440
](http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2798440)
Thread: PixelActive CityScape - Could this be a good combo with Vue? | Forum: Vue
For those wanna play: change .txt into .vue , an easter gift ;-)
Just remember to tab/click the little cloud on the light property screen, otherwise youre lights will not influence the clouds
Tnx.
I played a little more with it, can't figure out how to animate the bottom cloud to get the "roll" effect..
Did had fun adding a little three
I tried it a few times... And it's very hard..
I never finished this one:
It's animated metaclouds ,i don't like the end myself.
Just take one cloud at the time, i find it is not the amount of clouds (in the above only three) but it's the lighting that makes the difference. (Although that also depends on the scene and shot)
Thread: Can i import a picture in vue? | Forum: Vue
U can use either an alpha plane or backdrop.
Also check out the Image based lighting scene delivered with Vue, there you see how they use an image.
Good luck.
Thread: how to evenly distribute objects in a circle? | Forum: Vue
Quick and dirty:
Good luck
Thread: My first animation attemp | Forum: Vue
Hello thunder, tnx for youre comment.
And yes, i know that the flickering is caused by the render settings, i have flikker free render settings but i did not use them because then the rendertimes trippled or more... ;-(
When i'm satisfied i will try a renderfarm with the good settings
I saved as JPEG 100% pictures, and make them into a movie afterwards.
Thread: Rendering gems | Forum: Vue
