10 threads found!
Devon | 13 | 193 | ||
Devon | 3 | 56 | ||
Devon | 13 | 287 | ||
Devon | 0 | 23 |
(none)
Devon | 3 | 152 | ||
Devon | 10 | 151 | ||
Devon | 10 | 277 | ||
Devon | 4 | 25 | ||
Devon | 20 | 163 | ||
Devon | 0 | 4 |
(none)
28 comments found!
Thread: Looking for a Car Modeler | Forum: 3D Modeling
Thread: Problem with your Subway Entrance prop | Forum: MarketPlace Customers
Still Caleb68.....we get into the issue of ...is it really necessary to have such a small prop have such a large texture map? I hardly think so. In my opinion were going way overboard on getting detail here. Unless I'm doing an exteme close up of the prop it's totally unnecessary. Like I said before. I down sized it to 3500 pixels and that was more than enough. In my opinion this is more like a conflict issue with Poser not being able want to use a texture map larger than it wants to (than a memory issue). If you read my specs above on my machine. a 1400 MHZ machime running 512MB or RAM is more than enough. I even went so far as to partition my duel 80 GIG hard drive so that Windows has it's own partition and can run with no interference. I still would like to know how others were able to use that file and not I. Were they using that large texture map like I was? If so how did they get around it? I had my machime optimized so that I took full advantage of RAM and memory and had not conflict issues like in the past.
I checked Microsofts Knowledge base and could not find anything on this error. This has to be a Poser 5 problem . I did update to the first patch but did not install the second beta Patch. Was wondering if this might solve the problem. I never got this error message before using Poser 4 Pro pack on this same machine. This started with Poser 5 and only this file....so far.
Thanks Caleb68 for the suggestion. I did find a spotLight 1_shadow_0001.tmp file in there and took it out but that did not help. If anyone knows what that exception error means we might be able to know what the problem is. I know Microsoft has definitions for all there error messages. Wonder if the People at Curious labs can tell us what this is. I've contacted them on a few ocassions about problems but they never answer me.
Well I can't figure this out. I can't see this being a system error if we all are Running Windows XP Professional. I even disable my Virus protection because of past problems. Don't seem to be having any problems with other files. Can't figure this out. Anyone have any suggestions? Could this file be bad after the download or something? I have a 14oo MHZ ADM Athalon with 512 MB of ram. Does anyone know what that error message means?
Thread: Poser Lighting (saving) problems | Forum: Poser Technical
Attached Link: http://home.cfl.rr.com/greenhornet2002/
You might not claim to understand much about lights, but you hit the nail on the head on this one my good man. You were right. It worked. My problem was I was saving all the subset lights much like when saving props. I had a bad habit of saving props the wrong way in the past. I kept forgetting to save the sub sets or parented props to it to get the entire package. I thought all this time I had to do the same thing with the lights. Never realised or tested it out the other way. Go figure. Thanks what's so great about the Renderosity community. Always a fellow helping hand member.....I thank you so very much. DEVONThread: Looking for a Car Modeler | Forum: 3D Modeling
Attached Link: 1990 Honda CRX model
Just wanted to clear this up. I want my CRX model to look EXACTLY like my own car. NOT any basic stock look. Unlike the other image above, mine will have the rear wing and louvers along with the exact style chrome wheels. I will also have chrome acent fender flares and side panels put on next month. That's why I'm waiting before I want it done. I also have neon lights under the car ala "Fast and the Furious" which I was hoping to have modeled.Thread: Looking for a Car Modeler | Forum: 3D Modeling
That's the ORIGINAL 1985 Version 1 CAR.....THAT"S NOT the look of my car and NOT what I'm Looking for. I have VERSION 3 and my car looks way different as you can see in the pictures. But it's a start if you can take the model and change and/or add to it. Thanks DEVONThread: This problem is a dooozzyy. Can anyone help me? | Forum: Poser Technical
I finally found the problem. Thanks to everyone for your help. I just wanted to let you know that I had a computer technician come over to look at my computer and found out the following. I did not have a Volcan 6 cooling fan on the CPU as I was told. So that needs to be corrected and My Motherboard was found to have heat spots on it and a voltage regulation problem. Since this started around the time I installed Windows XP we have to assume XP caused the problem since it allows the Hardware to run faster than Windows 98...hence that's why things got hotter.
Thread: Is there anyway to do this in Poser? | Forum: Poser Technical
Glad to know your Poser Folder is 18.9 GB. I thought mine was big at 11GB. It seems that I only had problems with them loading when I got down to the bottom of the list. Usually around the t's to the z's. Maybe it's a problem with the PNG thumb generations. I'll look into that. I was only having problems with the Pose folder. I'm running Windows XP professional...1400MHZ AMD Athalon with 512MB RAM and G-Force 3 64MD video card. Thanks for your reply.
Thread: Single sided polygons get burned... | Forum: Poser - OFFICIAL
