6 threads found!
Dmurphy | 11 | 142 | ||
Dmurphy | 4 | 177 | ||
Dmurphy | 21 | 379 | ||
Dmurphy | 9 | 372 | ||
Dmurphy | 9 | 30 | ||
Dmurphy | 0 | 50 |
(none)
22 comments found!
I did not think of that. What if the model is part of the complete scene. The STL format is not a real 3-D format. Can you do the same scene we are working on and use 8 shades of gray with no black.
Thread: STL format or DXF | Forum: Poser - OFFICIAL
Thread: Collabaration (seachnasaigh) | Forum: Poser - OFFICIAL
I also had a small set back. Slightly health-related setback. But I am now back working on the machine hope I have it set up this weekend I will cut out some test samples. Glad to see you're still with me when you get the rest of the things added I will try to cut some test samples
Thread: Looking for collaboration partner | Forum: Poser - OFFICIAL
As long as you have havng a good time I can wait. I worked on the CNC machine today.I think I am done with the Z axis . Now to mount the Rack and pinion drives for the Y and X axis.
Don
No I did not try to expand the image. I will do that now. if you need to make a new scene that is OK. I can wait. We are experimenting right now to see what will give good results without to much work and resources. We need good detail but also not to small.
Don
PS do you need my emial address
Well I would like to continue with the one we have. Can you move the charaters down. So they look like they are on the ground. Remove the scroll work and add a Castle wall in the back ground.
Also need better detail on some parts. The mail on the horse is not coming through.The shield decorations are not coming through. May need to in crease the size of some of that. Could you double the size of the picture. If it is to big for here e-mail it to me.
Thank You
Don
I also need to ask if you want to be a part of this project. please let me know
I am putting the finishing touches on my cnc now. It's a cnc router products CRP2448. It will do 24 X48 . The have a web site. They are also 1hour from where I live. I will check out the link. If you want to work together I have no problem making the larger items. Wall panels and whatever strike my fancy.
Don
Exactly what I think (lol) I am looking for. I downloaded your picture to test I will let you know in a day or 2.
Thank You
Don Murphy
They do not need to be stacked. I may be describeing it wrong. I may be able to find a link to show what I mean. If you have a height field map already made I could test it in the program I use to make cutting paths. If it works we can then discuss sceens to make.
Thank You
Don Murphy
Thread: Vicky in action | Forum: Animation
