15 threads found!
ENGELKEN | 14 | 424 | ||
ENGELKEN | 14 | 587 | ||
ENGELKEN | 1 | 44 | ||
ENGELKEN | 14 | 949 | ||
ENGELKEN | 2 | 14 | ||
ENGELKEN | 9 | 32 | ||
Advisories: nudity
ENGELKEN | 13 | 102 | |
ENGELKEN | 4 | 28 | ||
ENGELKEN | 19 | 153 | ||
ENGELKEN | 16 | 75 | ||
ENGELKEN | 2 | 17 | ||
ENGELKEN | 12 | 56 | ||
ENGELKEN | 3 | 23 | ||
ENGELKEN | 7 | 34 |
2000 Sep 14 11:32 AM
Advisories: nudity
ENGELKEN | 3 | 15 |
173 comments found!
Attached Link: http://www.senosoft.com
Too easy...http://www.senosoft.com
The free version of P3dO Explorer 1.7.5
(earlier versions work too)
Select subdirectory in P3dO then,
Go to "Tools", then "Pattern Renamer"
Thread: How to Turn off render on a prop in a scene? | Forum: Poser - OFFICIAL
export two images, one rendered in jpg, tif, or whatever, and the second, go to hierarchy and put all the other scene elements invisible, except the one you want and export this, unrendered, as a .png. It will give you an image to layer over the first.
eng
Thread: New character ? Poser pro-Pack | Forum: Poser - OFFICIAL
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1977525
here's where the tutorial starts.Hint for future: to find the Good Doctor's toots, put DG# in the search engine.
Thread: Prop Hair? | Forum: Poser - OFFICIAL
All hair in .hr2 format is a smart prop, parented to the head. They can all be saved as a .pp2 file under Props if you wish.
eng
Thread: Simple rope bridle for Millenium Horse? | Forum: Poser - OFFICIAL
Maybe if your were a bit more specific. Do you need a halter? A Navajo war bridle? Western bit? English bit? Perhaps a pic of what you have in mind?
eng
Thread: H-E-L-P downloading the Poser Pro Update!!!! | Forum: Poser - OFFICIAL
If you registered originally with Metacreations, might need to re-register with Curious Labs.
Thread: michael hair | Forum: Poser - OFFICIAL
Attached Link: http://renderosity.com/messages.ez?Form.ShowMessage=1835532&Form.sess_id=24329204&Form.sess_key=110
Given the nearly 300 morphs, I suspect you can make it stand on its head and whistle Dixie. Seriously, though--this is a "hairpiece" made with infinite skill and meticulous detail which does not fail at even the most extreme distortions or odd camera angles. As for the flipping--it is the easiest thing in the world to do. I won't repost here, but the link refers to the method.Thread: michael hair | Forum: Poser - OFFICIAL
In answer:
Yes, that is the Egypt Hair.
No, no special conversion.
...that, by the way, is a question I never quite understand. Hair is a smart prop. You never hear anyone asking, "Where do I get the conversion so Mike can hold that sword in his hand, instead of Vickie's in hers?"
load the hair/prop. Adjust the trans x,y,z to center on the character's head/hand/whatever. In the case of hair, Mike usually needs a little increase on the Scale dial, 102 to 104% max...and, voila, M3 conversion. (we'll assume you started with the character in zeroed position.)
re-parent to head and lock actor, if you're going to be moving the main figure around a lot.
Thread: I Have a Question? | Forum: Poser - OFFICIAL
I always find that if I have been in Poser since the last time I rebooted, I have to reboot again before I can upload anything to this site. The program won't release my 'puter when I exit it, so some of the oomph goes out of my system until I reboot. I know that's not exactly the mechanism, you understand. That's just what it does.
Thread: noob question from someone who should know better | Forum: Poser - OFFICIAL
Hi, Lyrra. Your tunic tex's are awesome. Thank you, thank you.
As to the "not distributeable" thingee...
I find it hard to believe that all the V3 head/face morphs available in Free Stuff and Marketplace are only done with Magnets or in other Modelling Programs. I suspect some of them are combinations of existing morphs and original tweaks combined as described above and then set up to inject in a different channel.
But I could be wrong.
Thread: I'm looking for M3 hair... | Forum: Poser - OFFICIAL
You are most welcome. It was a good project for me to go over pz files for props again. Thank heavens that Kozaburo put a "fix neck" morph into this style or there would not have been a slot for the new morph and it would have been much more complicated.
The Count looks great.
Maybe a soutane and a spooky Hdri light set?
eng
Attached Link: http://7parabian.com/!M3PW.zip
If you want to try the link and let me know how it works, the download is at:http://7parabian.com/!M3PW.zip
Thanks,
eng
Thread: Changing .pz2 file to .cm2 files? | Forum: Poser - OFFICIAL
