17 threads found!
Fredoray | 2 | 63 | ||
Fredoray | 5 | 172 | ||
Fredoray | 0 | 144 |
(none)
Fredoray | 8 | 49 | ||
Fredoray | 11 | 47 | ||
Fredoray | 0 | 8 |
(none)
Fredoray | 15 | 418 | ||
Fredoray | 5 | 140 | ||
Fredoray | 1 | 133 | ||
Fredoray | 0 | 59 |
(none)
Fredoray | 6 | 197 | ||
Fredoray | 13 | 263 | ||
Fredoray | 11 | 274 |
2002 Oct 28 6:23 PM
Fredoray | 6 | 148 | ||
Fredoray | 4 | 101 |
21 comments found!
Quote - Make Movie can be set to use its own render options, not necessarily what you see in the preview - it looks as if you're in silhouette mode there. What version of Poser is this?
This is Poser 6 --- it works fine if I just make a png movie file, but does this weird outline thing if I try to use the image sequence option -- both png and tiff...Â
Thread: Alpha Channel and Poser 6 | Forum: Poser - OFFICIAL
Thread: Komodo dragon Poser model??? | Forum: Poser - OFFICIAL
Digimation offers its Komodo as an .obj Could this be imported and still maintain its posability or would it just be a rigid prop???
Thanks for all the assist -- The Ross dragon is not too realistic, but maybe with some better textures it would work... after visiting the Digimation site I have to ask... why are those models so expensive??? I mean some are up to $2500... I don't get it. Some are completely undetailed and unrealistic, but they're fetching $300 and up. I'm obviously missing something...
Are these usable in Poser -- sometimes I can get things into Poser but they come as immobile props with no posing ability. Also, would you have a link for digimation???
Thread: Realistic poseable great white shark ? | Forum: Poser - OFFICIAL
DAZ not only has a Great White, but they have a very good texture for it as an additional purchase. I have both the shark and the more realistic texture and have done some animations with it and it's very lifelike. If you've only looked at the shark, you should definitley check out the additional textures.
Thread: poser Wasp? | Forum: Poser - OFFICIAL
Thank you -- I'm an ongoing BT customer having alreday purchased the scorpion, ants and crocodile. This is very cool. FRED
Thread: Texture Template On The Loose! | Forum: Poser - OFFICIAL
Unfortunately I'm not that knowledgable. Guess I'll just go with what I have -- you would think however that Brycetech would be doing a pretty fair job of it -- maybe it wasn't meant to be tampered with. "-) thanks for the help. FRED
Thread: Bats in the Belfry Anyone? | Forum: Poser - OFFICIAL
Attached Link: http://retromedia.org
Thanks for all the info. I bought a Brycetech scorion and everytime I tried to animate the legs they became detached from the body! I think Lucifer the Bat is the way to go. That thing looks incredible! FREDThread: Bump map causes Poser to crash! | Forum: Poser - OFFICIAL
Here's how this ended. The author created a new bump jpeg that was double the dpi (went from 72dpi to 150dpi), but reduced the dimensions by 1/ 2 and that did the trick... really. Now if I can just figure out why the 3DS "science lab" model I bought crashes everytime I try to open it I could die happy. That particular author has failed to respond to any of my emails. The Scoutship guy was very anxious to help and was a very pleasant fellow. Thanks to all here. Fred Olen Ray
I'm using the mac converter that I always use. The author sent me a smaller sized bump map so we'll see how that works. FRED
Thanks for all the info. I'm using Poser 4 on a Mac G4 dual processor OS 9.2.2 with a high memory allottment (400 mb). The files are from a model called Scout Ship and came as jpeg files and converted to the green-style bump maps which I applied by hand thru the "materials" interface. I'm going to try a reduced file size when I get into work and see if that helps. FRED
Thread: Bryce Models INTO Poser? | Forum: Poser - OFFICIAL
It's the EARTH VS THE FLYING SAUCERS model in the Renderosity maketplace -- there doesn't appear to be a poser version. :-( Fred
Thread: Poser renders only shadow! Help! | Forum: Poser - OFFICIAL
