25 threads found!
Insom_Nia | 14 | 258 | ||
Insom_Nia | 11 | 208 | ||
Insom_Nia | 10 | 225 | ||
Insom_Nia | 3 | 48 | ||
Insom_Nia | 2 | 140 | ||
Insom_Nia | 0 | 29 |
(none)
Insom_Nia | 10 | 201 | ||
Insom_Nia | 2 | 111 | ||
Insom_Nia | 4 | 111 | ||
Insom_Nia | 5 | 163 | ||
Insom_Nia | 11 | 187 | ||
Insom_Nia | 18 | 565 | ||
Insom_Nia | 7 | 194 | ||
Insom_Nia | 14 | 262 | ||
Insom_Nia | 3 | 153 |
157 comments found!
Thread: Die, Vue, Die! | Forum: Vue
IÂ know the problem with Vista....
It happened several times when IÂ wanted to restart an app later IÂ couldn't and the task manager showed me the app still running in the background. I then have to close it again manually and that often is not possible (sometimes IÂ even have to reboot to start fresh)...
I wish for a proggie which controls the running programs better than the current task manager! :(
Thread: My first Vue freebee! | Forum: Vue
Thread: HELP! Runtime folders vanished! | Forum: Poser - OFFICIAL
No difference sadly....on the first glance the whole directory was still there but empty...no files...all gone...
No....nothing in the recycle bin, no double folders, no warning...nothing! Wiped out!
I used now an undeleter which did find most of the lost files, maybe 75 percent...
The external runtimes are fully intact....but without the needed geometries not really usefull..
oh well. :unsure:
Thread: Poser 7 rendering and size question | Forum: Poser - OFFICIAL
Thank you both for your answers...I will look for the graphic card and make a re-install.
Quote - Render>
Render Dimenisions>
Set -Select-Render to exact resolution-Width, Height, ( large as you want or the largest you computer can handle ),Â
Set Resolution at 300 dpi>.....
Hello,
I just found out a problem...I can't render in an other resolution than 72 dpi.
(I never needed to before....)
I tried every option in the Render Dimension window and saved in several formats, the outcome
was always only 72 dpi?
I'm totally at a loss, what's going wrong here?
I'm using Poser 7 on a new computer with 2 GB RAM
(Poser works very unstable and I can only using SreeD...had never such problems before)
I'm grateful for any hint!
Thread: Nikolaus day in Germany = some vegs for you | Forum: Vue
Thread: Broken mesh after Setup room rigging! | Forum: Poser - OFFICIAL
Update and conclusion:
It was really the grouping!
After grouping it new and more closely to the figure (and taking care of the hip group)
everything conformed great and no breaks or holes whatsoever! :biggrin:
off to more learning
I used Hexagon...there you have to group the mesh to make it poseable!
(or did I understand you wrongly?)
Ummm....I just compared the groups of my pants with the pro pants using the grouping tool and my groups look nothing like they should be....the names are okay...but the groups look wrong (I used AutoGroupEditor)...I think that might be the error...I will do it again!
