20 threads found!
LBAMagic | 6 | 511 | ||
LBAMagic | 5 | 156 | ||
LBAMagic | 3 | 453 | ||
Advisories: violence
LBAMagic | 6 | 258 | |
LBAMagic | 1 | 59 | ||
LBAMagic | 0 | 69 |
(none)
LBAMagic | 2 | 132 | ||
LBAMagic | 3 | 149 | ||
LBAMagic | 14 | 561 | ||
LBAMagic | 8 | 330 | ||
LBAMagic | 17 | 665 | ||
LBAMagic | 0 | 148 |
(none)
LBAMagic | 2 | 127 | ||
LBAMagic | 2 | 103 | ||
LBAMagic | 16 | 265 |
178 comments found!
Following is a really good free script for render presets. They are really great.
http://www.sharecg.com/v/57250/browse/8/Script/DAZ-Studio-4-Render-Presets
Following is some free UberEnvironment sets. I haven't tried these yet.
http://www.sharecg.com/pf/full_uploads.php?pf_user_name=glaseye
Must be registered to download these files but that's free too.
Hope it helps.
Thread: searching for a texture program | Forum: DAZ|Studio
Daz Studio to Photoshop Bridge has the following limitation.
DS 64bit to PS 64bit = OK. // DS 64bit to PS 32bit = Will not work.
DS 32bit to PS 32bit = OK. // DS 32bit to PS 64bit = Will not work.
Thread: UberEnvironment in DS4 | Forum: DAZ|Studio
Attached Link: Basic Lighting in DAZ Studio
@![](http://www.renderosity.com/art/null.gif)TheOwl68 - Good image. If you add a distant light and set it's Light Ilumination to "Specular Only" and Shadow Type to "Deep Shadow Map" then it brings out the highlights.Thread: Daz 4 product-Skyreach | Forum: DAZ|Studio
Quote - Wondering how this past the testing before it was put on the market..
Probably like most sites outside of DAZ3D they are more aimed at the Poser user. But even some of those Poser products are not well packaged either.
I remember one Poser product I bought that had everything, I truely mean EVERYTHING, was thrown into one runtime Props folder (PP2, PMD, OBJ, and texture files).
It took me about an hour to sort the files into their proper Poser runtime subfolders, then I used Dimesion3D's Runtime Repair to auto-correct the PP2 files reference code to call up the associated files from the new (proper) locations.
Grrrr!
Thread: Useful Scripts for Daz Studio Newbies | Forum: DAZ|Studio
Attached Link: Move Origin Script
Another script that I find useful and now works in DS4 is the move origin script by DeltaX15. When you apply some 3rd party poses to a figure the origin / pivot point of the figure has moved away from it's normal position. So to move it back on the figure this script helps.Thread: Move Axis | Forum: DAZ|Studio
Thread: Daz4 rendering | Forum: DAZ|Studio
Actually you can render in the active window by using the "spot render veiwport tool". The icon is a camera with a mouse pointer. I use that when I want to check only a small area of my scene but you can just click and drag it over the whole scene too. The only thing is that it doesn't save the rendered scene if using the spot render veiwport tool.
Thread: Archer poses for Genesis figure | Forum: DAZ|Studio
You can use V4 / M4 poses on Genesis and then fix them using the following script.
http://www.sharecg.com/v/60135/gallery/21/DAZ-Studio/Genesis-V4-pose-adjust-script
If you have an item with transperancy / opacity map (such as hair / eyelashes) applied to its Surface then Uberenvironment render times will be even longer unless you apply UberHair Shader first to the item's Surface. Or in the item's Paramater tab turn Cast Shadows to Off.
BTW I used Lantios Lights 2 (from Daz store) in my above render.
(A) Occlusion Samples (larger number = higher quality = longer render time)
(B) Shading Rate (lower number = higher quality = longer render time).
Try (A) first then fine tune with (B). Also adjusting Occlusion Colour can help but it lightens the shadows.
Attached Link: InjectPMD Plugin
I'm glad you find the scripts useful.If I come across some more useful free scripts for DS4 I'll post them.
DeltaX15 makes many useful free scripts that he posts at Daz forum. InjectPMD Plugin is one of the most important script / plugin he has created. I think he now has a beta version of the InjectPMD Plugin for DS4.
Not sure why Daz doesn't include the InjectPMD Plugin as standard in all DS releases. Anyhoot for DS4, he and others are waiting for Daz to release the DS4 scripting code so they can upgrade their scripts. Some DS3 scripts work in DS4 and some don't.
For any Daz Studio user (old or new) I highly recommend the following program.
a) Runtime Repair by Dimension3D (purchase at Rendo's marketplace).
A stand alone program that I find extremely useful. DS has a hard time locating files if in the wrong referenced folders. This program fixes the runtime file code that references the related files.
Becareful how you use it because you may accidently overwrite a file that you didn't want to. To be safe just use it on one file at a time until you get to understarstand it then you can use it on mulitiple files and folders.
I really wish all Poser content creators would use this program before putting their products in the market place for sale. Sigh!
http://www.renderosity.com/mod/bcs/runtime-repair/50760
Thread: more Japanese freebies | Forum: Freestuff
Attached Link: Spiral Cats Team (Cosplay)
Not sure if anyone posted this yet. It's not really a Japanese Freebie but more like reference material for content creators / artwork. For really cute cosplay check out Spiral Cats. These girls really put a lot of effort in their clothes designs based on Anime/Manga characters. Would love to see more realistic asian faces in the markeplace like these girls.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Thread: Poser IDL in D|S? | Forum: DAZ|Studio
