15 threads found!
MarianneR | 5 | 247 | ||
MarianneR | 6 | 78 | ||
MarianneR | 3 | 79 | ||
MarianneR | 8 | 73 | ||
MarianneR | 4 | 134 | ||
MarianneR | 3 | 106 | ||
MarianneR | 5 | 210 | ||
MarianneR | 3 | 93 | ||
MarianneR | 1 | 82 | ||
MarianneR | 3 | 84 | ||
MarianneR | 4 | 104 | ||
MarianneR | 8 | 96 | ||
MarianneR | 14 | 176 | ||
MarianneR | 4 | 77 | ||
MarianneR | 68 | 1726 |
713 comments found!
I tried with both Vue 2023 and 2024 and it is the same behaviour as far as I can see. So, props import well, but it doesn't work when I try to pose figures in Vue. According to the manual, there is supposed to appear a list of body parts when I double-click a figure. But the box where they should appear is empty.
Thread: Vue cannot find Poser 11? | Forum: Vue
Mine also says Poser SDK (11.0.5), like yours. I tried saving a pz3-file outside of the Poser runtime and then the figure showed up as white boxes in the the top, side and front views, but it rendered ok. The same figure pz3-file from inside the Poser runtime behaved correctly.
It seems that the path to your Poser installlation is rather long. Could that be a problem maybe? Just guessing, I don't know at all. I used Vue a little many years ago so I know very little about it. Sorry I can't help you.
According to Poser my version is 11.3.740.
I imported a pz3 of a simple scene and when asked about Poser I just pointed Vue to the folder where Poser is installed. In my case it is C:\Poser\Poser 11. This worked in both Vue 2023 and Vue 2024.
Thread: "You do not have permission to use this coupon" | Forum: MarketPlace Customers
Thread: Will Poser run offline? | Forum: Poser 12
The fact that Poser phones home is what made me desert Poser for Daz Studio. If I can´t connect to Renderosity's server Poser will stop working. It could be technical reasons, business reasons or politics. That would mean that I lose not only the money I invested in Poser itself but also all the money I spent on content that only works in the newer versions.
Thread: Does Rendo's Poser 11.2 Allow working offline? | Forum: Poser - OFFICIAL
I am not afraid of being hacked, but what happens if Renderosity goes out of business for some reason? I could be left with a non-working Poser 11 program, and also my investment in content for Poser 11 is useless. It won't work in earlier versions of Poser and as far as I know there isn't any other program that could use it either.
Thread: Poser 11.2.289 and Runtime Rodent | Forum: Poser - OFFICIAL
I haven't tried to actually use it, but Runtime Rodent does start in Poser 11.2.296 for me. Don't know if it matters but I have the Poser program installed in C:/Poser/Poser 11 and the content is installed in the D: drive.
Thread: Poser Install Directory | Forum: Poser - OFFICIAL
I don't know if it is necessary anymore to install outside of the Program Files directory, but some time in the past (don't remember when) I had a problem with a script or an addon that wouldn't work when Poser was installed to Program Files. Someplace in a forum I read about installing outside of Program Files and that solved my problem.
My old installation of Poser was at C:/Poser/Poser 11. Just like you I tried to set the installation path as I don't want Poser in "Program Files". Well, there wasn't any chance to change the path during the installation so I went ahead and installed anyway. Turns out that Poser 11.2 installed on top of Poser 11.1, in the same folder and seems to work fine. I chose to keep preferences during installation and all my old runtimes are in the library, just like in 11.1.
Thread: Poser 11.2 New Content download ? Registration number problem. | Forum: Poser - OFFICIAL
Are you sure that you are not writing the letter O instead of the number 0 when filling in the number?
Thread: Poser Has a New Base Figure!! | Forum: Poser - OFFICIAL
Here's my very artless attempt. She is almost straight out of the box, with hair by Aprilysh.
Thread: Can¨t say Thank you on some freestuff items | Forum: Community Center
But why does it work immediately sometimes and sometimes not? A couple of days ago I downloaded four freestuff items, and posted thanks on all four. Two of them showed up at once but the other two comments I couldn't see until yesterday. I tried two different browsers too.
I just went back to the freestuff pages and now the comments show, even the ones that I made a couple of days ago that I couldn't see before. Indeed strange!
Thread: How to correct Victoria 4's bending issues. | Forum: Poser - OFFICIAL
The zip file is of RTEJava works fine for me on my old Mac, but it needs Java installed to run.
