24 threads found!
Nails60 | 3 | 234 | ||
Nails60 | 2 | 214 | ||
Nails60 | 4 | 434 | ||
Nails60 | 1 | 153 | ||
Nails60 | 0 | 146 |
(none)
Nails60 | 1 | 127 | ||
Nails60 | 2 | 137 | ||
Nails60 | 3 | 656 | ||
Nails60 | 4 | 125 | ||
Nails60 | 1 | 57 | ||
Nails60 | 4 | 94 | ||
Nails60 | 7 | 226 | ||
Nails60 | 3 | 72 | ||
Nails60 | 0 | 64 |
(none)
Nails60 | 3 | 92 |
511 comments found!
If you converted the clothing from another figure using the fitting room did you set the l'homme size under the pose dials to zero before doing the fitting?
Thread: Add a face picture to a 3d model | Forum: New Poser Users Help
There is a program called headshop for poser which is available for purchase from this site
Thread: The TerraDome | Forum: Poser - OFFICIAL
MortemVetus has a number of expansion packs for terradome2 here at Rendo, some have been sold elsewhere but a couple are new.
Thread: Threadripper and RTX3090 with Poser | Forum: Poser - OFFICIAL
Poser 12 still seems to have the 32 thread limit for rendering, so assuming the cpu has hyper threading (or the amd equivalent) and as someone has stated 24 cores, ie total of 48 threads, a third of the threads would not be used. I don't know much about amd cpu's but if they make a 16 core, 32 thread with higher clock speeds you might get better performance in poser cpu rendering
Thread: Recovering or viewing gift certificate codes | Forum: MarketPlace Customers
On your account page there is an item "gift certs" near the top, just below the standard tabs.
Thread: Another pay-pal payment not noticed by Rendo | Forum: MarketPlace Customers
Thanks. Glad to hear Pay-pal doesn't hate me personally! (Just because you are paranoid doesn't mean they are not out to get you!!) John
Thread: Order #: 113665670 | Forum: MarketPlace Customers
Thread: Camera oddities ... | Forum: Poser 12
Have you adjusted the camera yon value? something I often forget with td2 when I'm not using a scene I've previously set up. This shouldn't cause the difference between the main and aux cameras as they have the same default value, but I notice the aux camera is slightly closer to figures so it is possible skydome just out of range with main and not aux
Thread: 2D Face to 3D | Forum: Poser - OFFICIAL
There is this
https://www.renderosity.com/rr/mod/bcs/headshop-12-5-for-la-femme-and-lhomme/141059/#
as an add on. It's a standalone prog so should work with p12. but I've not used it since installing p12
Thread: community newsletter coupon | Forum: MarketPlace Customers
Problem sorted, I'd left a letter out of the coupon code, I normally cut and paste but the way the newsletter was formatted meant I had to copy manually!
Thread: Replacing lights. | Forum: Poser 12
Thread: Models of dragons | Forum: Poser - OFFICIAL
Have you looked at the Sixus 1 Dragonz? My personal favourite dragon, especially when you add the expansion set
Thread: Silly, but not so Silly question. | Forum: Poser 12
Easiest way, in the edit menu, select general preferences, then in the window that pop ups select interface tab and select open to factory radio button. Now restart poser and you will be back at the default setting.
Then I would use the ui dots, normally located near the bottom left. Click on the first (empty dot) which will then fill. Now if you make any changes to the interface you can simply click on this dot to get back to the basic layout. Once you played around and found a layout you like just click on another dot to save it.
Thread: Poser Pro 11 tutorial "lighting part 1" - shadows & shadow light cameras | Forum: New Poser Users Help
The shadow light camera should move when you move the associated light, but the light will not move when you move the camera. Make sure you have selected the light either in drop down menu top left document window or by clicking on it in the lights pallet and then select the correct shadow cam from the cameras pallet (eg select light 1 and shadow cam 1). Now if you move the light the camera should move
Thread: I cannot access the hand figures in the library of Poser 11 | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I assume you just want a 2d image. Once you have the required image in your document window, you RENDER the image and poser will do this and create a thumbnail of the image you have in your document window.
Now right click on the thumbnail and this gives you the option to export in a range of formats , jpg, png etc
Thread: L'homme and the ballooning conforming clothes | Forum: Poser 12
