50 threads found!
alamanos | 16 | 624 | ||
alamanos | 2 | 123 | ||
alamanos | 126 | 5075 | ||
alamanos | 5 | 217 | ||
alamanos | 2 | 575 | ||
alamanos | 0 | 94 |
(none)
alamanos | 5 | 42 | ||
alamanos | 21 | 213 | ||
alamanos | 1 | 65 | ||
Advisories: nudity
alamanos | 10 | 539 | |
alamanos | 2 | 58 | ||
alamanos | 26 | 1123 | ||
alamanos | 10 | 162 | ||
alamanos | 3 | 557 | ||
alamanos | 41 | 1521 |
165 comments found!
you can use wordpad
open the uncompressed file, do a search and replace all
hidden 1 replace with hidden 0
line will look like this
initValue -0.017
hidden 0
forceLimits 0
min -100000
max 100000
Thread: Need help P7 hates rendering hair!!! | Forum: Poser - OFFICIAL
Thought it might have been the transparency.
Too bad there is no quality setting for transparency...or is there?? will scale down transparency maps..maybe play with settings. Â
is there away to set antialsing properties per object?
Thread: VISTA and POSER is a NO DEAL ...... | Forum: Poser - OFFICIAL
Poser on Vista does work fine, but this really depends on the graphic card you are using.
My first vista install was with and ATI X1300PRO.... poser would run... but there would be delays going from menu to menu... very slugish...Â
once I change video cards to nvidia...poser worked fine... no delays...
just curious, those who are haveing probelms.. are you using ATI??
Thread: DragonNaturally Speaking and commenting? | Forum: Vue
Hi Susan,
I've had Dragon NaturallySpeaking for about two weeks now and I think it works great. Just for your info, I used Dragon to type this out. Well, there was no typing involved just speaking into a microphone. It will take a couple of days to get used to it, you have to train it to your voice and you can teach it new words. You do not have to speak like a robot for it to understand you, which is a bonus.
Enjoy.
Nick
Thread: Wardrobe Wizard will it work on P7 | Forum: Poser - OFFICIAL
Thread: Carrara 5 render benchmarks? | Forum: Carrara
Carrara 5 Pro CPU: Athlon64 X2 3800+ (overclocked to 2200mhz) MEM: 2GB PC3200 DDR SDRAM Graphics: nvidia 6600 Time 9 seconds amd 3800 great chip with dual core... can be overlocked... also not very expensive...I think dual core is a must if you're working with carrara.. cuts render times in half
Thread: C5 demo questions | Forum: Carrara
Thread: Carrara 5 question from a poser user.. | Forum: Carrara
i have poser 5 and 6... but from what i'm reading, i should be able to eliminate poser from the loop...
Wow!!!..thanks for the info.. this is great news... it sounds like version 5 has everything i'm looking for... looking forward to buying it when it's released.. thanks again.. nick
Thread: Need help!!!! ... can't update my p6 to sr1.... | Forum: Poser - OFFICIAL
found it... if you log in to contenet paradise.. u have a maximim if 10 downloads... if you download it off the CL website it asks for a serial #... which can only be used once thanks.
Thread: Pixelated P6 Render problem | Forum: Poser - OFFICIAL
i think it's your texture. Regardeless of the resolution you choose. if your source texture for v3 is of low quality, you'll have pixelation.
Thread: V3 vs. Jessi, Post Your Opinions on Which One Looks Better... | Forum: Poser - OFFICIAL
Thread: Jessi.. with some home made mags and simple tex.. opinions? | Forum: Poser - OFFICIAL
thanks for the comments... yes her hands are that big!!. but I think you CL will be comeing out with a fix for them some. Good point about the hips... they are rather boyish...
Thread: need help saving custom magnets f or Jes. | Forum: Poser - OFFICIAL
Thread: How do you unhide parameter dials that have been hidden? | Forum: Poser - OFFICIAL
