2 threads found!
amberf | 4 | 125 | ||
amberf | 2 | 72 |
38 comments found!
Thanks Deecey,
I ran both simulations one at a time and that worked. I'll try the Recalculate Dynamics one now.
Thanks!!!!
Thread: Problem with 2 or more Dynamic Clothes on same figure | Forum: Poser - OFFICIAL
Thanks Deecey,
I tried to set up different simulations and the only clothing that would be treated as dynamic would be the one in whichever simulation I would have selected.
Would I then have to run two separate simulations? Like select the first one with the MFD, run the simulation then select the second one for the cape and then run that?
Thanks for the tip=)
Thread: Colonial Clothes | Forum: Poser - OFFICIAL
there's poser 4 male colonial stuff here:
209.92.41.204/Poser/dlframe.asp
You'll need to select "colonial" in the box to see them.
Thread: Editor and Toolbox for Poser | Forum: MarketPlace Showcase
Attached Link: http://www.greenbriarstudio.com/3D/ToolBox/features.htm
You might want to change the name for your 'Toolbox' since there's another program by that name that's been around for a few months. It can cause some confusion.Thread: What is the best way to remove bones from new clothing figures | Forum: Poser Technical
Just undo when the head bone moves. As long as you haven't done anything immediately after it moved, you still have your 1 undo.
Thread: Can I make a single Full Body morph that includes other FBMs? | Forum: Poser - OFFICIAL
Yes you can. Set the morphs you want to whatever dial setting and then from the Figure menu, click on Create Full Body Morph and give it a name. You'll then have a dial in the 'body' part for that morph combination. Remember to set all the dials back to zero before using the fbm one.
Thread: Considering Work on a DAZ Figure? See this first... | Forum: Poser - OFFICIAL
Attached Link: http://poserpros.daz3d.com/forums/viewtopic.php?p=24225&highlight=#24225
more interesting reading re: DAZ EULA...Thread: Who made these sandals? | Forum: Poser - OFFICIAL
Thread: What could be causing this...? (dynamic simulation issue) | Forum: Poser - OFFICIAL
It's the SR4 for P5. Reinstall the SR3 and it'll get rid of that problem. I don't know if you can just install SR3 over SR4 since I went with the uninstall and reinstall P5 route.
Thread: Stormguards problems | Forum: Poser - OFFICIAL
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1077665
At the bottom of the link, someone at DAZ said if you bought it before Jan. 30 last year to contact him and have your download reset. There was an update for it on the product page before but it's gone now.Thread: grand theft help in a project | Forum: Poser - OFFICIAL
For the welcome signs, there's a scene on one of the CD's and it has those. I think it was a bridge scene. You'll just need to change the texture to change the sign.
Thread: Biblical era clothing resources? | Forum: Poser - OFFICIAL
Attached Link: http://www.joyfulcostumes.com/
Give these a try. The last one looks pretty good.http://www.holleygene.com/bible.htm
Thread: Spawning Morphs ala Python | Forum: Poser Python Scripting
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12390&Form.ShowMessage=1495455
Stewer wrote one but it doesn't have an interface to type in the morph name. It will spawn the morph target for all the body parts regardless of whether or not there are magnets affecting the body part but it doesn't seem to create the FBM. There's also a script that will set all the morph targets to 1 but again, no interface to specify which morph targets to set to 1. Ockham, if you can get the FBM to work and put an interface on it so we can type in the morph name that would be awesome!Thread: New Feature Freebie At Poser City | Forum: Poser - OFFICIAL
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1503527
The raider character was by Lourdes and her site is now gone.Thread: help! I cant get the stupid conforming clothing to conform | Forum: Poser - OFFICIAL
Attached Link: http://www.poserfashion.net/index.htm
Did you try these tutorials?They both have cloth room tutorials. I don't have Poser 5 up right now so I can't quickly check. Do the bikini pieces fit Judy or are you using the cloth room to try to fit it to Judy? Did you want to use it as dynamic cloth or conforming?
...assuming that you're trying to fit the bikini top to Judy and it's too small to fit her...and then you want to make a conformer out of it.
You'll probably have to adjust some of the joint parameters if it doesn't pose well. The 10 frame thing is just me picking a number...I don't think you'd need the default 30 frames...maybe even less than 10 would suffice.
