8 threads found!
aztecmarco | 1 | 264 | ||
aztecmarco | 3 | 389 | ||
aztecmarco | 4 | 351 | ||
aztecmarco | 3 | 58 | ||
aztecmarco | 20 | 823 | ||
aztecmarco | 3 | 65 | ||
aztecmarco | 3 | 149 | ||
aztecmarco | 1 | 27 |
15 comments found!
Can someone explain what no support for unimesh figures means? Does this mean I won't be able to use M4/V4 .ect inside Poser 13 and if so, why would they stop supporting those figures?
Thread: Strange distortion in figure rigged in Poser fitting room | Forum: Poser Technical
Thank you for your response. I'm hoping someone can point to a cause of the distortion rather than trying to fix it after the fact. I'm either doing something wrong in the creation process or there's a bug in the fitting room. If I use the morph brush I suspect I would have to apply it to each morph I'd like to apply and I'd rather not do that.
Thread: Morphing Tool problem with M4 & V4 elbow | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I'm sorry, I don't mean to be dense but I'm really not following you. I really want to understand what the underlying concept is here so I can improve as a Poser artist. I know it's a pain, but would it be possible to have you explain this again? Maybe with pics? :/ When you say "Workable" position, what does that mean?
Yeah I think you're correct about the JCM conflict. I will check out the Manual. Thanks for the help.
Thread: L'Homme - missing transparency maps. | Forum: MarketPlace Customers
I was very surprised to see this happen, kind of disappointing. As a work around you can copy La'Femmes trans maps in to L'Hommes folder and then rename it.
Thread: Orion for Poser 11 | Forum: Poser - OFFICIAL
Any chance Orion will be available before Christmas? I've got money burning a hole in my pocket. Also is it possible to see more preview images?
Thread: M4 Parameter Panel in Disarray | Forum: New Poser Users Help
I've tried saving the character to my runtime folder and tried reinstalling the M4 figure with no success.
Excellent answer. I went through my projects unchecking calculation order and it restored the normal hierarchy for almost all my characters. Unfortunately it didn't help the one project where I first noticed the problem. Checking and unchecking the calculation order just rearranges the morphs but does nothing to put them in the proper nested order. I've gone through each of the body parts and they all have calculation order unchecked so I'm pretty sure that's not the problem. Thank you so much for your response, any further thoughts on what might be causing the problem?
Thread: Exclude Sky Dome from effects of Atmosphere? | Forum: Poser - OFFICIAL
You sir are a genius, this is exactly the effect I was looking for. Thank you so much and Happy Holidays!
It's kind of like the poser construct but it a sphere object with a star field texture applied to it. I actually want to be able to see it without the Poser atmosphere material affecting it. So basically you would see the effect of the atmosphere on all the object in the scene except the surrounding sphere/environment object. Thank you so much for your reply, I really do appreciate it. Sorry to be so vague about it, it's kind of a rough concept to try and explain. Attached is a version with no atmosphere effect applied.
Thread: Renderosity FreeStuff - Allow External Hosting Petition | Forum: Freestuff
Thread: Merman Creature? | Forum: Poser - OFFICIAL
Nope, but thanks for the reply. The product I'm thinking of was named Trident or something along those lines. It was a morph character for M3 and I thought it was by Winnston1984 but I could be wrong, it's been so long since I've seen it.
Thread: March 23rd right around the corner | Forum: Poser - OFFICIAL
