47 threads found!
danny7 | 11 | 569 | ||
danny7 | 4 | 86 | ||
danny7 | 2 | 94 | ||
danny7 | 0 | 48 |
(none)
danny7 | 4 | 175 | ||
danny7 | 1 | 85 | ||
danny7 | 4 | 67 | ||
danny7 | 3 | 190 | ||
danny7 | 2 | 67 | ||
danny7 | 2 | 128 | ||
danny7 | 3 | 101 | ||
danny7 | 7 | 162 | ||
danny7 | 1 | 48 | ||
danny7 | 4 | 179 | ||
danny7 | 4 | 145 |
11 comments found!
Thread: Camera In Poser 6 Is Off Center! | Forum: Poser - OFFICIAL
Thread: OK To Uninstall Poser 5 Now? | Forum: Poser - OFFICIAL
Thread: Poser 5.0 Crack | Forum: Poser - OFFICIAL
Wasn't the original subject of this post about crack? Or am I just asking a stupid question?
Thread: Wanted: Power-Generating Windmill For Poser/Vue 4 | Forum: Vue
Thread: One More ??? About BVH Files And I'll Leave Y'All Alone...For Now, Heh-Heh! | Forum: Poser - OFFICIAL
Follow this procedure:
Open Control Panel, click on the File Options icon.
Click on the View tab, then scroll down and uncheck the "Hide extensions for known file types" option.
Find the bvh text file, right-click on it, then click on Rename.
Replace the .txt extension with .bvh, press Enter, press Enter again and that's it.
When you're done changing all the file extensions on these files, go back into Control Panel and re-check that "Hide extensions for known file types" option.
Thread: Poser 4 | Forum: Poser - OFFICIAL
Poser 4 does not have Collision Detection like Poser 5 does. You can either get The Tailor, which is sold by DAZ 3D at www.daz3d.com or you can simply make some of Victoria's body parts invisible if they're not supposed to show at all. I try using The Tailor first. If that doesn't do the job, then I just make the hidden body parts invisible. Good luck!
Thread: Looking For Sources Of BVH Motion Files For Poser 4 and 5 Help! | Forum: Poser - OFFICIAL
OK, I found more Links to BVH files at the above link than I know that to do with. Thanks! However, a lot of the files are actually text files. Is there any way to convert them to .bvh files?
Thread: Bad Animation Rendering, Need Help! | Forum: Vue
Unfortunately, I am unable to post an animation on this forum because the file size is too large. If I shrink it down, it'll be too short to notice anything peculiar. Also, I tried the suggestion by wabe and got the same result as with an animation containing movement. I should also mention that rendered still images look immaculate. It's just the animations that look grainy/distorted/otherworldly.
Thread: What Happened To The DAZ 3D Free Stuff? | Forum: Poser - OFFICIAL
