19 threads found!
julien_chaplier | 1 | 128 | ||
julien_chaplier | 2 | 193 | ||
julien_chaplier | 3 | 34 | ||
julien_chaplier | 0 | 53 |
(none)
julien_chaplier | 0 | 55 |
(none)
julien_chaplier | 2 | 129 | ||
(none)
julien_chaplier | 1 | 89 | ||
julien_chaplier | 0 | 84 |
(none)
julien_chaplier | 3 | 113 | ||
julien_chaplier | 12 | 285 | ||
julien_chaplier | 14 | 416 | ||
julien_chaplier | 1 | 108 | ||
julien_chaplier | 5 | 136 | ||
julien_chaplier | 2 | 67 |
42 comments found!
Hi Brian,
I hope you're getting better.
I added a short tutorial on the website:
http://www.inagoni.com/content.php?content.18
It's mainly screenshots, but it can help understanding what the Replica Array options are.
Let me know if you need more information.
Julien
Thread: Inagoni Replica "Array" modifier help | Forum: Carrara
I can make a tutorial for the small animation with the cubes if you want. Maybe next week-end if I find enough free time.
Julien
Thread: Architools Roof Problems | Forum: Carrara
Hello,
Could you send me the file and a few steps to reproduce the problem ar support'at'inagoni.com. I'll check what's happening here.
Julien
Thread: Just bought architools but don't know how to instal it | Forum: Carrara
The 3D objects on inagoni.com are also free of rights. They can be used in any commercial project. Julien
Hi, I just saw the question about using shaders from Inagoni on commertial products. Feel free to use them as you want, there're no copyright on them. Julien
Thread: someone want a headache? math genius needed maybe =P | Forum: Carrara
I think the ^ operator is not reconize by the parser, you should try with a multiplication instead.
Message edited on: 03/12/2006 05:36
Thread: primivol issues | Forum: Carrara
Thread: Veloute 2 question & problem....Thanks in advance :) | Forum: Carrara
Hi, You can find here another build for C5Beta: http://julien.chaplier.free.fr/DownloadLink/C5BetaPluginOld.zip for those that have the error that says the plugins are too recent. Julien
Thread: Full Raytracing (higher Quality) comparison | Forum: Carrara
The Full Raytracing is also required when the camera is inside the bounding box of an object, otherwise some triangles are discarded. I had the problem when the camera was inside an ArchiTools building. Julien
Thread: Primivol shadows? | Forum: Carrara
Hello Ed,
Volumetric objects in Carrara can't cast shadows (Primivol as well as Carrara's volumetric primitives). It a limitation due to the current implementation of this kind of primitive inside Carrara: volumetric primitives are rendered in there own space, appart from the scene. It's this same limitation that makes the distant lights the only one available for volume lighting. I sent these remarks to Eovia when I was working on Primivol and I hope the SDK will show some improvment for Carrara 5.
Regards,
Julien
Thread: Bump mapping issue? | Forum: Carrara
This information might help: I know that some of Carrara's shaders have a nice bump implementation (like the Cellular shader), but others use a default implementation that depend a lot on the scale of the shader (like the brick one). When I did Veloute, I made specific developments for the bump, so they usually give better result than the Carrara one's. What you could try if you want to use the Carrara brick shader in the bump channel, it's to use it after the Veloute Filter shader: it should improve the bump. Julien
Thread: something for architool users(not only) | Forum: Carrara
Thread: Thank you, Julien! | Forum: Carrara
Thanks for using them. I'm glad to see that these plugins are usefull. And if you want to share some of the images you'll make with, feel free to send them, I'll add them to the Inagoni gallery. Julien
Thread: Architools question... | Forum: Carrara
There's in fact 2 rooms separated by a short wall. The wall height is set to .2 inch, the floor on one side to .1 inch and on the other side to .2 inch: this make a .1 inch step. You can also set thte wall thickness to 0 if you don't want to see a border on the floor shading. Julien
Thread: Primivol evaluation version | Forum: Carrara
Hi Johannes,
The glow of the fog can be set using the Intensity parameter. And you can darken the profected shadow of the cloud on the scene by increasing its density.
Currently the fog can't receive shadows from other objects, as well as it can't receive light from ligth cones and light bulbs. These are 2 limitations I'm aware of, but I couldn't find a way to solve them with Carrara 3 or 4 architecture. I'll complete the volumetric model as soon as a solution is available.
About the evaluation version, if you lower the renderer quality ( setting the Antialiasing to Fast or None, and the Pixel accuracy to 2 or 4 pixels ) you should be able to render more than 4 or 5 times the primitives. Let me know if you think it's still not enough with these settings, I can build another demo that authorized a little bit more renders.
Julien
