18 threads found!
ladydrakana | 7 | 1266 | ||
ladydrakana | 3 | 60 | ||
ladydrakana | 8 | 236 | ||
ladydrakana | 7 | 189 | ||
ladydrakana | 14 | 2206 | ||
ladydrakana | 5 | 216 | ||
ladydrakana | 3 | 412 | ||
ladydrakana | 14 | 3381 | ||
ladydrakana | 3 | 270 | ||
ladydrakana | 4 | 1947 | ||
ladydrakana | 5 | 363 | ||
ladydrakana | 2 | 107 | ||
ladydrakana | 2 | 66 | ||
ladydrakana | 7 | 145 | ||
ladydrakana | 8 | 275 |
123 comments found!
I have 2.79 and it ran fine on it. Otherwise, don't know what versions of blender it requires.
Poser Pro 2010
Thread: Anyone check out this cloth modeling experiment yet. | Forum: Blender
Thank you both. I also have cloth weaver. And have been playing around with it.
Poser Pro 2010
Thread: Making Pillows add on for Blender | Forum: Blender
I tried it and it works. Though there are no options for different shaped pillows. For instance round. Though you can get a few different looks in a square pillow. Depending on how you change the settings in Physics.
Poser Pro 2010
Thread: Blotch on model in preview mode | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: Need suggestions on this project | Forum: Blender
OK, Added his name. And did a little post-work as well.
TheBryster - I did make the exhaust longer. Thank you for the suggestion.
The rocket is a model I made years ago in Wings3D. For a report that he made for the Air-force. There is very little detail. Was concerned that lighting it up to much more would show the flaws more that improve the image.
Anyways, is this any better?
Poser Pro 2010
Lobo3433 - thought about putting his last name on the side of the rocket. But thought it might be to much. Still might do it anyways. RobynsVeil - Stars were created with procedural. No Particles involved. But get what you mean. Still figuring it out.
Thank you both for your comments
Poser Pro 2010
Forgot to mention. There has not been any post work yet. Didn't want to go there until it was done or almost done.
Poser Pro 2010
Thread: Lighting Question? | Forum: Blender
That's actually the tutorial that I was following. But I stopped when he got to making the sparks. Probably should have continued watching it.
Poser Pro 2010
I am just learning all the options for smoke/flame physics. Though I setup a shader like the tutorial that I was following. I did not use an emission node. Was not sure if I could or the right way to do it. So I will go back and take a look. See what I can do. Thank you for the suggestions and for the FB addition. And yes I have FB.
Poser Pro 2010
Thread: Anyone heard of or using Blender Sensei? | Forum: Blender
I found some information on Fluid Designer. Microvellum has updated the webpage for Fluid Designer but no download link. Found that is it here and has been updated in the last 4 days. https://github.com/Microvellum
Poser Pro 2010
Thread: Best method of creating morphs in an object? | Forum: Blender
Lobo3433 Thanks for the video. Am going to watch it tonight. So I don't get interrupted.
false1 I tried that but could not get the Morph Brush to stay on the object I wanted. It kept jumping to the cat figure. And got frustrating real quick.
Poser Pro 2010
Thanks for the information. I forgot about proportional editing. Displacement maps are beyond what I can do. Never had a single drawing class. and can't draw a straight line let alone do anything with detail. Thought about taking classes but there are none in my area. The ones that are available are way to far to drive for me. In another county and more than an hour away.
Poser Pro 2010
heddheld posted at 2:52PM Sun, 06 November 2016 - #4205110
Â
seen a similar thread lately, yes heard of it watched a few tuts !! it does look better for someone who cant/wont take to blender but for me blender shortcuts have stuck I don't even like the tabs and pie menus which seem to be all the rage (old dog new tricks rofl)
theres another "version" of blender ........ this maybe of interest to you as a vendor
 http://www.microvellum.com/products/fluid-designer</http:>damn I wish they'd fix this forum Â
Â
Went to Microvellum and there is no longer an option to download Fluid Designer. They still have the pages of info on it, but again no option to download it. Tried a while back to purchase the cabinet add-on. But couldn't find it and no one there responded when I asked them where it was. Are they dropping this product? Making changes? Could't find out myself.
Poser Pro 2010
Thread: my poser wil not activate | Forum: Poser - OFFICIAL
I got this message from having it installed to many times. Had just gotten a new notebook. Because the old one developed a screen issue. Which I could not uninstall poser from. But also had it installed on my desktop. Once unregistered from the desktop. Was able to install on the new notebook. That I would be using it on mostly anyway. So if you are installing again because of a computer change, This could be the reason.
Poser Pro 2010
Thread: Archmesh troublehooting | Forum: Blender
keppel posted at 9:09AM Mon, 23 May 2016 - #4270175
Can't explain the why behind the behaviour but if you tab into edit mode and unify the normals (Ctrl+N) this will correct the issue. Once you tab out back to object mode any further changes you make using the room parameters will mess the mesh up again. Unfortunately you have to keep fixing the normals each time you make a parameter change.
Tried this out. And it works. Thanks again.
Poser Pro 2010
