75 threads found!
muralist | 4 | 175 | ||
muralist | 1 | 71 | ||
muralist | 16 | 202 | ||
muralist | 6 | 92 | ||
muralist | 2 | 107 | ||
muralist | 8 | 163 | ||
muralist | 7 | 151 | ||
muralist | 6 | 153 | ||
muralist | 0 | 65 |
(none)
muralist | 23 | 419 | ||
muralist | 0 | 74 |
(none)
muralist | 37 | 612 | ||
muralist | 17 | 224 | ||
muralist | 4 | 156 | ||
muralist | 5 | 111 |
341 comments found!
ChrisCox:
BODY isnt geom, just internal name in figure; Carriage is the main shell of the car, then there are parts like Roof, doors, etc.
I parented the compartment to the Carriage Part. I'll try it diferently and see what happens. I thought I should avoid parenting it to BODY since there's the same name in every figure and it could get confusing.
Thread: Parent figure to another figure, save, when loaded not parented... | Forum: Poser - OFFICIAL
In my final train I might have 3 carriages. Can I alter the internal carriage BODY Name from BODY:1 to a unique name so that each of them can have compartments and not be confused?
Smartparent DOES work. I posted, but the post is apparently lost.
In the compartment figure I changed
Parent: UNIVERSE
to
smartparent: Carriage:1
Now when I load the Carriage, then load the compartment from the library, it sticks to the Carriage. Thanks ChrisCox!
One thing weird about it: BODY_1 is added to the Carriage's Body Parts list.
Barcode: the cr2's already call external geometry.
The files are:
HP_Carriage.obj
HP_Car_Int_High.obj
HP_Car_Int_Low.obj
How do you mean "make extra loading options?"
Barcode: Under the Figure option in the menu bar you can Set Figure Parent.
What Hioushi is saying is impossible is exactly what I'm trying to do: save a figure in the same was as a smartprop.
I have a train car with 8 compartments, high or low res; I want to give folks the option of loading only the high-res ones they need and the rest low. I suppose I can make the default load with all low-res compartments, and a user can delete one and add the high-res there, then parent it themselves. I am trying to make it simple for novice users.
Does anyone know of a hack for this?
Thread: ERC in main figure to control child-figures? | Forum: Poser - OFFICIAL
I got it to work for an instant, though it was weird: turning the dial to the max setting suddeenly made the door jump fully open rather than the smooth transition as before, but it worked.
Thread: Render shadows cast but not the object? | Forum: Poser - OFFICIAL
Is there any way to export the shadow maps? Are they stored in a temp cache while rendering so I could get them directly?
Thanks. Im using ISF lighting in a train compartment and making two versions of the carriage, one high res one low for distant shots. To save render time on the low res version I want to be able to light the cars fast; I thought I'd use the regular shaders on the low res objects, and apply a lightmap to the emissive channel.
Thread: Do any of you ever use any of my models? | Forum: Poser - OFFICIAL
Thread: More classic and antique autos and other vehicles! | Forum: The MarketPlace Wishing Well
Thread: How can I make this image better? | Forum: Poser - OFFICIAL
How can you make the image better? How about something to look at? It is a woman's ass and a car, and a handgun. What is the story? The reflective side of the car takes up 50% of the image space, yet it reflects pavement. If you want this composition, put something on that pavement for the car to reflect: how about a body, or pool of blood, or a suitcase full of cash? As it is, the most important elements by brightness and location are those rims and the ass, then the gun. Tone down the rims, they aren't important. Put something for the car to reflect. It doesn't even have to be directly visible but only seen in reflectin. Then why is that important?
Thread: Are there any LOW resolution Characters for Sale or download? | Forum: Poser - OFFICIAL
