247 threads found!
rowlando | 2 | 606 | ||
rowlando | 9 | 307 | ||
rowlando | 4 | 147 | ||
rowlando | 11 | 356 | ||
rowlando | 2 | 90 | ||
rowlando | 4 | 111 | ||
rowlando | 6 | 222 | ||
rowlando | 4 | 127 | ||
rowlando | 6 | 118 | ||
rowlando | 3 | 106 | ||
rowlando | 7 | 178 | ||
rowlando | 14 | 285 | ||
rowlando | 7 | 176 | ||
rowlando | 1 | 83 | ||
rowlando | 18 | 388 |
639 comments found!
yep, its really a pain trying to keep up, sticking with V4 until it becomes as useless P4 then I will go back to crayons if they are still around Ha
Seek what you can never loose
Thread: How to remove all morphs from a conforming figure in PP2014 | Forum: Poser - OFFICIAL
Hi Thanks, I decided to re convert the garment in wardrobe wizard and did not allow morph conversion, then I was able to put back in what I wanted to suit V4 works great now.
Your suggestions are also very good.
Cheers Rowland
Thread: Using PP2014 can anyone tell what is causing this issue re conformed cloth | Forum: Poser - OFFICIAL
hey got it sorted, I redid what man those names are hard to remember anyways a really big thank you.
re input morphs using morph transfer then checked them to auto conform in properties, things worked great.
Thanks heeps all
Ok thanks, I wanted the auto conforming morphs is there something to make this happen?
Hey Redphantom thanks so much, would you have a few images I could follow?
Yes I converted it in the fitting room, because I wanted the morphs added to the figure from V4, the figure did not have all the morphs I wanted.
Cheers Rowlando
O crap the image did not load, Ok its proborbly some size issue, will load it soon I hope.
Thread: Help with changing material zones or using the group tool please | Forum: Poser - OFFICIAL
Yes exactly what I thought and you have clarified all for me.
Thanks so much
Cheers Rowlando
Hi Primorge
Yes I found the hierarchy editor and was able to enable the invisible body part. However I want to enable other body parts with different material settings because basically everything is painted with the same texture and changing each part is not possible as it is.
I am thinking need to create a new material group for these parts is that correct? using your instructions above.
Thanks Rowland
Thread: How do I make GF2 cloths work on V4 in Poser Pro? is it possible? | Forum: Poser - OFFICIAL
Thread: Poser Update SR5.2 Now Available | Forum: Poser - OFFICIAL
OK just tried it and it says 10.0.5Â is that correct and up to date, I recently updated the via the DLC
cheers
Thread: I have found 2 installations of Poser Pro 2014 one on my C: drive and the one I | Forum: Poser - OFFICIAL
Yah sounds a lot of messing around, and then there is where all this stuff is stored, guess its a big learning curve if I think its worth it.
cheers
How can I find out what update I have installed, I use Poser Pro 2014
Cheers Rowlando
Thread: *slams head into desk* | Forum: Poser - OFFICIAL
