13 threads found!
shannonsuzanne | 5 | 192 | ||
shannonsuzanne | 5 | 132 | ||
shannonsuzanne | 2 | 129 | ||
shannonsuzanne | 1 | 175 | ||
shannonsuzanne | 20 | 652 | ||
shannonsuzanne | 6 | 308 | ||
shannonsuzanne | 2 | 85 | ||
shannonsuzanne | 3 | 162 | ||
shannonsuzanne | 9 | 276 | ||
shannonsuzanne | 18 | 319 | ||
shannonsuzanne | 13 | 379 | ||
shannonsuzanne | 13 | 274 | ||
shannonsuzanne | 8 | 1186 |
59 comments found!
Thread: Woe is Hair in Superfly | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Yeah, my settings look nothing like that in the material room. I have the bangs turned off through a material setting. I even went in and re-loaded a fresh load of the hair by itself with the same lights...still phantom bangs even with no head LOL. I am using the PHC materials to get that black and red combo. But even with just the hair itself loaded, it looks nothing like the picture you have as far as the nodes (see what I saw below). I am trying to get the EZ skin 3, but I cannot get the site to send me a confirmation e-mail. I'll keep trying to get it and see if that helps. I will also try the awesome render settings listed that you use. Worse case scenario? I just use firefly :) Thanks!
Thread: Need Help With Understanding Render Settings Poser User Trying Studio Again | Forum: DAZ|Studio
Yes! That helps a great deal. I always knew the formula, but it is always confusing...especially since Poser asks you for your DPI. This makes it much easier. I actually already tried a quick render and playes with the pixel size. Boy it rendered fast. A lot faster than I remember it being. Now, if I can just get my Genesis stuff from here into the correct areas for Studio I should be set. Looks like I have lots of downloading and installing to do.
Thanks again!
Thread: Poser Pro 2014 and the DSON/Genesis | Forum: Poser - OFFICIAL
Quote - Shoot the more I read about 2014, the less likely I am to get it. Why make a product that sounds like you need to be a Programmer to work it?
*sigh
Ariana
This is for the DAz Genesis. Poser works just great for Poser things. V4 and all your SM people. This is to get the creepy blob from DAZ and use the clothes in Poser for which it was not built. This is not a 2014 issue :)
Quote - The classic stuff can be converted in DAZ Studio to create Poser companion files (*.duf).
Don't know how to do that and I uninstalled studio :/ but good to know it can be done!
Quote - I guess there is no clear, for dummies explanation.
You have to install the DSON and the starter files. Then you have to install all the stuff you want to play with and the poser companion file. If there is no PC file it won't work in Poser. The genesis classic they gave us the first year has no poser companion file so it doesn't work. For me I got their install manager and did an install to a new runtime folder and just let the installer do all the heavy lifting.
I'm not sure why, but I went back and just reinstalled it and then in the "preferences" of the script I set the cache to the genesis folder and the other one about a writeable runtime to the runtime folder of Poser, something it did not tell me on my instructions. Works just fine now. Go figure. I'm tickled now I can use all this stuff I had gotten for Genesis when it first came out. Oh...the dread of downloading all that stuff.
Thread: Hair Help in PP 2014 | Forum: Poser - OFFICIAL
I had a similar problem when I went from 7 to Poser Pro 2012 with one of my FK hairs. It rendered OK, but the preview doesn't work and sometimes it's just mesh. I would try to apply the color and style you want and then do a test render. It usually works. Pain to pose, but it still renders!
Thread: Poser Pro 2014 | Forum: Poser - OFFICIAL
Yes. I have put mine on a cloud drive but will also make a DVD too. I just took my 2012 runtime folder and copied it into the new one and instead of overwriting anything I said no do not copy. That way all my shaders and anything else I may have forgotten about copied over. I think I can safely uninstall 2012 now :). Thanks everyone.
Quote - After you have installed them, the files are moved into the installed folder in that download location. Before they are installed (if you use the download manager) they are locatied in their own folder (/SmithMicroDLM/PSXP or PSXF)
Cool. That answers my question about back up. Thank you :)
Thread: Help with Hybrid Sylph Dress | Forum: Poser - OFFICIAL
I have run it several times step by step. The frames are at 45. The sleeves wont parent for some reason.
Maybe I will try the simpler dress first.
Thread: Poser-Rendering-that light grey "preview" box | Forum: Poser - OFFICIAL
Thread: Do you know what causes this? | Forum: Poser - OFFICIAL
Yup that fixed it. See..this is why I love Renderosity..almost like having a Poser pro on call LOL :)
Thank goodness! Now I can finish this for my client. Maybe I'll have some hair left too :0)
Thread: Daz Staff Picks May 20 thru May 26 | Forum: DAZ|Studio
