15 threads found!
shareone | 4 | 149 | ||
shareone | 18 | 402 | ||
shareone | 5 | 157 | ||
shareone | 11 | 138 | ||
shareone | 11 | 166 | ||
shareone | 7 | 187 | ||
shareone | 0 | 96 |
(none)
shareone | 11 | 178 | ||
shareone | 2 | 135 | ||
shareone | 30 | 867 | ||
shareone | 3 | 180 | ||
shareone | 4 | 195 | ||
shareone | 12 | 553 | ||
shareone | 12 | 291 | ||
shareone | 9 | 176 |
25 comments found!
Thank you all for your help.
Believable3D, I changed intensity and still got white scene. BTW, I used only one IBLÂ light.
ghonma, thanks for the links.
Latexluv, this link is great and I will use it, but take in mind it generates jpg, not hdr file.
ice-boy, I see now that the tutorial I took was indeed Poser Pro tutorial: poserpro.net/King_Tut/Lighting/poser_IBL.html
If Poser 7 can handle hdr files correctly, can you explain how?
Thanks again...
Thread: Save cloth animation (as pose?) | Forum: Poser - OFFICIAL
Thanks for your help. The need for saving the cloth animation was due to the fact IÂ can't use the cloth animation in Cinema (interPoser doesn't import it).
Maybe I'll just learn to clothify in Cinema...
Rance01, the animation is was created using Daz's plugin aniMate.
It helps creating smooth animations, but it is limited to the packages available.
I started to convert BVH files but they require a lot of work in Poser so I stopped.
Thanks again
Thread: Expressions Made Easy by MatrixWorkz - A Short Tutorial | Forum: Poser - OFFICIAL
Thread: Help Looking for MoCap and motion for Poser/DAZ figures... | Forum: Poser - OFFICIAL
Daz's plugin aniMate is good too.
You can see samples in youtube. This is an animation I made in Poser using aniMate:
http://rapidshare.com/files/194831332/Dont_mess_with_Maddie_2.avi.html
The problem with "smooth" animation is that every frame is an animation key, so exporting number of cloth variations will not maintain the animation. Maybe there is a script to convert dyn file (dynamic cloth/hair) to poser pose file (pp2 I think).
I can make a preview animation just to show you the "moves" because I didn't even pick the textured caracter I'll use. OR, you can check the attahced animation IÂ did with the same technic.
In the new one I was thinking to use dynamic hair as well (as you can see in the attached the hair animation is not good enough), but I'm having troubles in this part too.
If anyone can help with the "saving dynamic cloth animation as pose file" please do.
Thanks,
 Sharon
Thread: Change the y transfer on all frames | Forum: Poser Python Scripting
Thread: Poser hair question | Forum: Poser - OFFICIAL
So there is no way to make Hair type hair dynamic (calculated as a responde to a movement)?
Do I have to grow the hair myself?
Thread: Animation frustrations | Forum: Poser - OFFICIAL
Thanks jerr3d, nice animation (though I think some hair movement could help for realism).
I know it's a lot of work but the result might worth it :-)
Well, it didn't do anyhting on V3 either.
Do you have animation to share? now I'm curious
ockham, do you have an example of this script use? I tried to use it on v4 character (poser 7) and didn't notice anything. The list in the right, is it belong to the selected figure or just a fixed list?
can I see an animation you did?
Thread: Old/antique cracks effect | Forum: Photoshop
Thread: IBL questions | Forum: Poser - OFFICIAL
