57 threads found!
sirenia | 1 | 59 | ||
sirenia | 7 | 3045 | ||
sirenia | 4 | 81 | ||
sirenia | 9 | 1075 | ||
sirenia | 3 | 401 | ||
sirenia | 3 | 102 | ||
sirenia | 3 | 86 | ||
sirenia | 2 | 154 | ||
sirenia | 2 | 159 | ||
sirenia | 20 | 932 | ||
sirenia | 10 | 163 | ||
sirenia | 7 | 209 | ||
sirenia | 2 | 167 | ||
sirenia | 11 | 223 | ||
sirenia | 5 | 300 |
236 comments found!
Wow, i ordered the book this week on wednesday evening and today it arrived with UPS at my door. Talk about fast delivery !
First impressions of the book:
Pricing:
Ordered it on the E-On website and it shipped with UPS (standard) to Belgium:
total = 66,98 euro's
Conclusion = i'm happy with my newly bought book
Society failed to tolerate me...
... and i have failed to tolerate society
Thread: Sea Dragon Picture Lighting | Forum: Vue
The most green one hands down !
Thread: Fire in Vue | Forum: Vue
The best i ever achieved with fire in Vue is by using an alpha plane that projects a fire. I started with placing some rocks in a circle, adding lots of thin branches in the middle and than placing the alpha plane on it.
I also added a lot of cubes (!) which i used for sparks that are flying above the fire (as you would see on a real fire) and i thinks it adds a lot of reality to it.
This image whas never finished and i think i can search for a better flame to project on the alpha plane, but the reason i post the image is to contribute to this forum to let us all build a better fire :-)
Sorry for the low quality of the render (preview render)
Oh almost forgot to mention that i made the materials glow on the cubes :-)
Thread: Vue xtream 8.5 on a Mac problems | Forum: Vue
if you cannot find / see the directory, you can always use "Terminal" to locate this directory and change the parameters via the Terminal.
Or if you don't know how to use Terminal, you can search google for an apple script that will unhide all the hidden folders on your system :-)
I have OS X 10.4.9 so this may be slightly different with yours, but if you right-click the folder and select "get info" you should be able to change the "ownership & permissions" to "read & write"
Thread: "flickering" in animation | Forum: Vue
Hi seachnasaigh,
Did not even know there was such a thing as jittering and reduced pulsation options :-)
I really need to start reading the Vue manual again LOL !!
Thank you all for the tips :-)
Daniel1705, that 's some good work (especialy the growing leaves on the tree)
I will look deeper into that tread and experiment with the settings as you described (this is my first animation too)
Although i used 25fps (as you also did) i think i will use a bit more fps because at 25fps it seems that it is not flowy enough (if that is even a word LOL)
Wim
Thread: Lighting Setup for Modeling in Vue | Forum: Vue
Thank you Chipp, that 's a neath trick indeed :-)
Thread: Switch Poser 6 from Mac to PC | Forum: Poser - OFFICIAL
Too bad Poser 6 is platform specific :-(
So i will probably have to consider upgrading...
Thread: Following Rutra - Goodbye everybody | Forum: Vue
If they have problems with your images, than they should throw me out too... because some of my previews contain straight up nekked poser models
I shure will miss you around here...
Thread: moving Vue from Mac to PC | Forum: Vue
Ah okay, so i won 't update but only install the upgrades 5 -> 6 and 6 -> 7 and apply the latest updates to 7.
Oh and crappercrappercrap... gonna have to download EVERYTHING again from Cornucopia and others plants & stuff i bought over time (that 's an awful lot !!)
Using Vue on the two computers will only be at first for reference to check what i have installed so far but that 's it.
Thanks
Wim
Aaargh :scared:
You 're scaring me here ! Where does it say on the e-on pages ? Can 't find it.
I installed Vue5inf from the cd, downloaded the Vue6inf upgrade and installed it (which put itself in the 64 bit folder, so no worries here) and just finished downloading the Vue7inf upgrade but not installed this one yet.
How can i install without wiping my HD's ??
Wim
Oh forgot to mention... am busy installing it from the original Vue 5 inf cd...
Thanks Peggy,
Installing Vue 5 infinite on my PC right now. This is a 32 bit version, so will it change to 64 bit after i apply all the upgrades/updates trough 7.x via downloads ?
Thanks
Wim
Thread: Quadspinners Book | Forum: Vue
