6 threads found!
spacedragon1234 | 3 | 109 | ||
spacedragon1234 | 45 | 1690 | ||
spacedragon1234 | 7 | 254 | ||
spacedragon1234 | 35 | 1602 | ||
spacedragon1234 | 52 | 1335 | |
spacedragon1234 | 12 | 313 |
23 comments found!
I never posted any drive speeds at all.ย ย Do you mean interface speeds?ย ย If so, I have checked and I think I have the correct values in bits per second.ย I'll forget you confused drive and interface speed if you accept that my spellchecker capitalised the 'b' of Mb and I'm too lazy to spank it? :-)
In theory USB2 has a theoretical max of 480 but I challenge someone to demonstrate that to me. Then again, I think there's still a lot of older PCs with crappy PCI busses out there which might explain why it tends to measure around 300.
Thread: Poser in External HD Runs Noticeably Slower than in Internal HD ? | Forum: Poser - OFFICIAL
Likos, re-read 2nd sentence of 4th paragraph of the article you linked (not counting italicised prologue) :-)
Basically the application can "fork" off a number of sub-processes and each sub-process can use its own 2 GB of data memory, so if you need 8 GB, you just fork 3 times.ย ย Kernel memory is shared but you don't use that for data - each new process has just a small kernel footprint.ย ย That 2 GB of kernel ram can support many dozens of processes, each with its own 2 GB of data.
Poser 7 can use a second thread for rendering if you set it in the options.
Poser 7 on a PC can use more than 2 GB as it can render in multiple threads.
Poser 6 and lower on a PC cannot use more than 2 GB of ram. This is a problem with windows only allowing 4 GB per process (2 for the kernel and 2 for the application). Google "windows 2GB process limit" for technical explanation. [Victoria 4 at max res with the armadesa hair it comes with, wont render at max quality on Poser 6 PC due to the textures needing more than 2 GB]
Macs dont have this problem with Poser 6 or 7. Unknown other versions.
RAM needs to be matched if you have more than one stick. That means all sticks electrically compatible, and the same size. Google "mismatched ram problems". Otherwise not only will your dual channel ram not be dual channel, but you'll get crashes. Not many, but enough to make a diference if you ship hundreds of PCs (and get you slaughtered by tech magazines for doing that). Most people who build their own PCs are really sloppy - they throw in any amount of ram and never use antistatic straps when handling the chips ... you'd get fired by a major manufactuer for even touching RAM without wearing an antistatic strap. :-)ย As a result people think Windows is a lot less stable than it really is ... there are Windows webservers that have run without a reboot for months at high CPU usage % with their drives in constant use - but they're built properly.
IIRC speeds are
USB 2.0 Interface ---> 150 to 300 MB per second depending on your PCI bus
SATA Interface ---> 1500 MB per second approx
Hard drive speed is above USB2, so yes, external USB2 drive is slower. You may not notice the difference however, as it will be affected by your other components and the nature of the data being copied.
However I'm worried that you have 1.5 GB of RAM. It's a weird amount. None of the "big boys" in computers (Dell, HP, etc) will ship a machine with a 1.5 GB in standard configuration as it'll cause some odd problems sometimes (mysterious crashes that people usually blame on Windows). Should have 1 GB or 2 GB.
Thread: One for the IP Department | Forum: Poser - OFFICIAL
How do I contact renderosity store to get this product taken down?
It's blatant theft of someone else's work. Already notified the IP Holder.
Lucifer, you know it looks IDENTICAL to the film one, right? As in absolutely 100% "i challenge you to spot a difference" identical. Well OK, Some really minor ones probably due to imperfections in the modelling rather than intent.
As for being anonymous, definately not. Its instantly recongnisable as being perhaps one of the only wheeled combat vehicles with next to zero gound clearance. (The old "oh dear, 5th squad's APC is stuck on a speed bump / curb / debris in road again")
I would hyperlink but just google image search for "aliens apc"
Thread: Prop Needed - Stage | Forum: Poser - OFFICIAL
Thanks for all the links. Still nothing suitable, I'll have to make one in Max. I'll stick it on the forum freestuff when it's done.
Thread: Sanctum Art's Phenotype Models | Forum: Poser - OFFICIAL
Thread: Clothes Converter 3 | Forum: Poser - OFFICIAL
Cloth Converter works but you must be prepared to click a bunch of stuff to make it do that. If you are, get the program, and you'll be happy with it.
I got a Daz refund in cash but that was about a year ago. I don;t know what their current policy is. But a Daz credit --- well that will get used sooner or later. Could probably sell the credit on EBay if you got desperate.
Thread: V4 No Ear morph? | Forum: Poser - OFFICIAL
I'm sure Daz won't mind if you just email it to one guy who already has V4 and don't do it again. Just don't post it in a public place for anyone to download, and don't give it to anyone who doesn't have V4 already. In fact, just email it to him and forget you did it. :-) Really doesn't make sense for them to make a fuss about that, it going to be bad for business.
Tried poserpros, too. Darn it. Going to have to make one in Max.... AAARGH
Want To Buy: Make Mesh Button.
Thread: V4 Rubish | Forum: Poser - OFFICIAL
There's no magic button to autotranslate clothes. if there was, people would just make "cloth templates" and have the program fit them automagically to the figures.
So yes, you'll have to do some work to fit it, but there isn't that much. It takes me about 15 minutes to convert an item, but I'm slow. I'm sure it can be done quicker.
So what you are saying is "Right now there isn't enough support for her" not "she's rubbish".
In a year's time, everything will be V4. Then again, doesn't help you now :-)
there is a good thread on this on the daz forums
linking
[url]http://forum.daz3d.com/viewtopic.php?t=50520&highlight=[/url]
[edit] cant get link to work, sorry
