Wed, Feb 5, 2:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 2:05 am)
Subject: Please help me get reflection : (
bagginsbill ( ) posted Wed, 23 May 2007 at 6:08 PM
OK Here's the first render - this took 26 minutes. I used the Quality and Softness at 1, and Min Shading Rate = .2.
bagginsbill ( ) posted Wed, 23 May 2007 at 6:09 PM
Here's the material.
bagginsbill ( ) posted Wed, 23 May 2007 at 6:10 PM
Here's the second render. In this one, I turned off my sky sphere in ray tracing. Then I connected a blurred copy of the scene to the shader.
This render took 30 seconds. The reflections aren't the same, as a Sky_Sphere does not quite do all the math the same as real ray-traced reflections, but it's ok.
There are some polygons that didn't render correctly - this is a standard problem having to do with Bias settings. Ignore that.
Here's the material for the second render.
Angelouscuitry ( ) posted Wed, 23 May 2007 at 6:16 PM · edited Wed, 23 May 2007 at 6:21 PM
"...,and when not,..."
I ca'nt wait to see the screenshot, I hav'nt tries Partly Ratraced/Partly Reflection Map!
"The distortions of the scene appear because of the curves."...of the model!  Exactly.  I'm not sure why we're trying for a blur, there are really bound to be hard lines, in a shiny promo of Mr. N.' Radd?  I was just thinking that using that Chrome Wheel imge as a Reflection Map...but I'm really partially to Infinite Partly Clouded Skies in my reflections.
bagginsbill - Thanks!
Shazam!
jwiest ( ) posted Wed, 23 May 2007 at 7:04 PM · edited Wed, 23 May 2007 at 7:09 PM
Thought I'd post this here and thank bagginsbill for helping out in this thread since I saw jj's image and she passed on the render settings to me. :)
I did forget to lower her down though so it looks like she's in the water blush :D  And didn't quite get enough stuff inside to block out the sky dome showing through the window like it shouldn't have in the reflection. LOL
Now to find time to read through his whole post which looks really detailed. :)
(edit)
Then it tells me my file's too big, so you'll have to settle for the link to it in my gallery. :)
http://www.renderosity.com/mod/gallery/index.php?image_id=1446063
John
bagginsbill ( ) posted Wed, 23 May 2007 at 7:22 PM
Very very nice! It looks really outstanding.
Now go read my tutorial on skin and fix her - she doesn't look as fantastic as the rest of the scene.
Ultra Basic Skin Shader
Some discussion and more renders from UBSS
jwiest ( ) posted Wed, 23 May 2007 at 10:53 PM
The UBSS you link in your post in that RDNA thread seems to be for V3.  The character I used for that render is V4 and has 3 texture files...Face, Torso & Limbs.  Is it safe to assume I can use the Face one on the Head and Torso on the Body, and if so, what do I call out for the limbs?
John
ice-boy ( ) posted Thu, 24 May 2007 at 1:18 AM · edited Thu, 24 May 2007 at 1:20 AM
thanks to everyone. thanks to you bagginsbill. i will post my renders.
did you use james ffrom poser 6 bagginsbill?
so if i understand it right silver refelects everything.its like a mirror right?
this means that they are cheating here right?
ice-boy ( ) posted Thu, 24 May 2007 at 5:18 AM
ok i now tested with your settings. and i think it is perfect. its better than the tutorial from runtime.
its to good to be true.
bagginsbill ( ) posted Thu, 24 May 2007 at 7:44 AM
jwiest - I think you missed the point. The UBSS shader nodes work for any figure. You have to set it up with different textures, and do it for each skin mat zone that your figure has, but the technique and node setup is identical for every figure. All that changes is which texture files to use.
And you didn't look closely enough on the second linked thread. Read the whole thing. I posted the actual Poser materials for V4 in there, with 5 different skin types.
bagginsbill ( ) posted Thu, 24 May 2007 at 7:45 AM
ice-boy:
I'm so pleased it worked!!!!! That looks outstanding - truly perfect!
Yes I used James - he doesn't look good, but for demonstrations I like him because he has only a few material zones to set up and I have a lot of poses for him.
ice-boy ( ) posted Thu, 24 May 2007 at 12:02 PM · edited Thu, 24 May 2007 at 12:07 PM
now i only need to find a way to erase the ears.
thanks.
ice-boy ( ) posted Thu, 24 May 2007 at 12:23 PM
thanks.
equan ( ) posted Thu, 24 May 2007 at 12:42 PM
Hi all, The pics in ice-boy's post above, are great, how did u get the wheel to look like that. I love it.
bagginsbill ( ) posted Thu, 24 May 2007 at 1:24 PM
Equan - I believe he used a camera? :biggrin:
ice-boy ( ) posted Thu, 24 May 2007 at 2:24 PM
Quote - Equan - I believe he used a camera? :biggrin:
google ;)
equan ( ) posted Thu, 24 May 2007 at 2:45 PM
maybe my question was stupid. sorry i bothered you guys. won't happen again.
ice-boy ( ) posted Thu, 24 May 2007 at 2:50 PM
bagginsbill you last settings are awsome. i also noticed that it reacts on lightining. what i am trying to say is that if hte ligh is behind the surfer it makes it looks like this. you see the light is coming from right.
ice-boy ( ) posted Wed, 06 June 2007 at 9:15 AM
AnAardvark ( ) posted Wed, 06 June 2007 at 1:33 PM
Quote - One approach would be to use a high-res in-focus image for your environment sphere so it shows up nicely in the background, but make the environment sphere invisible to raytracing.
When you make something invisible to raytracing, and then use raytracing, does it show up in the render, but is not used when calculating ray-trace bounces? Is that how it works?
bagginsbill ( ) posted Wed, 06 June 2007 at 1:58 PM
Nice animation - very believable.
AnAardvark - yep that's right. That object will not show up in reflections on other objects, cannot be seen by refraction, and is ignored for purposes of calculating ambient occlusion. The latter has nothing to do with bounces - its implied that AO always has 1 bounce looking for nearby objects that block the ambient light.
ice-boy ( ) posted Wed, 06 June 2007 at 3:16 PM
Quote - Nice animation - very believable.
i am testing the reflection maps.
this looks very nice.
thanks to all that helped me.
Angelouscuitry ( ) posted Wed, 06 June 2007 at 8:10 PM
equan - There's no such thing as a stupid question...:tt2:
ice-boy ( ) posted Fri, 05 October 2007 at 11:21 AM
so i have a new question about reflection. i posted pics to explain.
in the bottom pic the i used 1 raybounce. the second one is a manip. is it possible that the material reflects the enviorment sphere 100 % and 50% himself?
ice-boy ( ) posted Thu, 11 October 2007 at 1:16 AM
this is what i now did.
what do you think BB
bagginsbill ( ) posted Thu, 11 October 2007 at 8:22 AM
Not quite right. What you did was 100% of the Sphere_Map *minus* 50% of reflection. This would make your reflections look like negatives.
If I take exactly your words as what you want (100% of sphere map + 50% of reflections) and you don't care about Fresnel effect, this is all you have to do.
See how I plugged the Sphere_Map into Ambient. Then I can use Ambient_Value to adjust the intensity. But you said 100%, so I used 1.
The Reflection_Value I set to .5, because you wanted to add 50% of the reflections.
I assume you are not using a true environment sphere here, surrounding the scene. Just the virtual one in the Sphere_Map (and blurred).
(Note: I had to adjust the Reflect Ray Bias because the James geometry causes artifacts.)
bagginsbill ( ) posted Thu, 11 October 2007 at 8:39 AM
I like this effect a lot, if you're willing to wait for a longer render.
I added a true environment sphere with the Pond HDR panorama attached. (The blurred image_map->Sphere_Map was made from this.)
I used 60% of the blurred sphere map + 40% of real reflections, with maximum blur. The Reflect node is picking up both the true environment sphere and the figure's own self-reflections. I used 2 bounces.
ice-boy ( ) posted Fri, 12 October 2007 at 1:08 AM
interesting. i will try.
thanks
ice-boy ( ) posted Fri, 12 October 2007 at 2:23 AM
p.s. i want that the object reflects 100% the enviorment and 50-30% of himself.
bagginsbill ( ) posted Fri, 12 October 2007 at 7:13 AM
When you say the "environment" i'm not sure whether you mean a virtual environment in a sphere_map included in the figure's material or the real environment in a big sphere surrounding the scene.
The first one I posted is precisely 100% of sphere map + 50% of reflections. You can put anything in the image_map attached to the sphere_map that you want. That is the "environment" in that case, done without true reflection.
It is not possible to set up a true reflection which shows 50% of some items and 100% of other items. The Reflect node cannot be programmed in any way to treat different parts of the scene in different ways.
ice-boy ( ) posted Fri, 12 October 2007 at 8:04 AM
i know that it can not be programmed. thats why i was asking myself if we can fake this. this would not be realistic reflection.
you helped me a lot again BB.
ice-boy ( ) posted Sun, 26 October 2008 at 12:41 PM
so after more then one year you learned a lot. i downloaded your orbs and noticed that you changed the shaders for raytracing. are they better or is this shader just better working for those orbs?
ice-boy ( ) posted Sun, 26 October 2008 at 12:43 PM
so you think now we can do better faking reflections like i asked?
the figure reflects 100% around himself and 40% of second raytracing(himself,arms,head,...)
bagginsbill ( ) posted Sun, 26 October 2008 at 9:19 PM
Quote - so after more then one year you learned a lot. i downloaded your orbs and noticed that you changed the shaders for raytracing. are they better or is this shader just better working for those orbs?
The Orb shaders are glass. This is metal. Totally different.
ice-boy ( ) posted Mon, 27 October 2008 at 3:24 AM
one material shader doesnt have refract. so its like car paint right? i think its the red one.
ice-boy ( ) posted Mon, 16 February 2009 at 2:44 PM
bagginsbill i am asking if we can fake with HDRI in poser the specular highlights ?
like here
on the computer 1 is white. but HDRI means more then white. more brighter then that. like the sun for example. of lights. . when doing car paint for example it reflects everything. when you have a dark material then the reflection is also dark. but the sun or windows are bright.
i am wondering if we can fake that now that we have HDRI in poser.
kobaltkween ( ) posted Mon, 16 February 2009 at 3:00 PM
are those Poser renders?
ice-boy ( ) posted Mon, 16 February 2009 at 3:09 PM
no
bagginsbill ( ) posted Thu, 19 February 2009 at 8:07 AM · edited Thu, 19 February 2009 at 8:08 AM
I'm not sure why you're asking this as though it is a real surprise. Since Poser 7 we can load HDR images into lights and props. If you load an HDRI onto my environment sphere and use reflection you will get HDR reflections. It's simple.
Suppose the reflectivity of a surface is 10%, or .1. Suppose you have an HDR image on the environment sphere. Suppose that some places on the HDR have a luminence value of .1 and others go to 10. The reflected luminence is 10% of that so the reflection would be 1% to 100% luminence. Which means you will see only the bright spots. What is so surprising here?
To demonstrate, I loaded an HDR image of a dark room with an open door to broad daylight. The dynamic range here is clearly evident in the reflecting balls.
bagginsbill ( ) posted Thu, 19 February 2009 at 8:29 AM · edited Thu, 19 February 2009 at 8:30 AM
Another demo. I placed a 100% mirrored square behind the balls so we can simultaneously see the outdoor scene at full luminence and at the reduced luminence caused by the lower amount of reflection in the spheres.
The mirror, trying to render the full range, is clipped at the maximum luminence of your monitor, which is 1.0. We can only make out a couple details - most of it is above 1 and is a wash of white. However, the interior, which we can see behind all the spheres and mirror, is perfectly lit and rendered well within the unit range 0 to 1.
The reflections in the spheres show plenty of detail, demonstrating that the exterior data is there in the HDR image. It is available for calculations, particularly those involving reflections from imperfect mirror surfaces, where the detail will reveal itself.
ice-boy ( ) posted Fri, 20 February 2009 at 4:24 AM · edited Fri, 20 February 2009 at 4:29 AM
but isnt the HDR image a lot darker? does it represent how a mirror would reflect it?
and just to ask again. i just load a HDR map on your ENV sphere? i dont need to change the gamma in and gamma out?
and i still dont understand why i always think about the specular when thinking about HDR reflections.
ice-boy ( ) posted Fri, 20 February 2009 at 5:27 AM
Gamma In has to be set to 1 right?
bagginsbill ( ) posted Fri, 20 February 2009 at 7:26 AM · edited Fri, 20 February 2009 at 7:28 AM
What do you mean by darker? Darker than what?
Any photo can be darker than some other image of the same scene, just by adjusting the exposure level on the camera. An HDR image is usually made by combining several LDR images taken at various exposure levels. Until you view it, it is not darker or lighter - it is just data. If made correctly, the data indicates the actual luminence of every point without regard to artificial limits imposed by 8-bit images or traditional digital camera encodings (even 14 bits is not enough) or by the limitations of your display device. It is just data. Trying to look at that data directly on your monitor is meaningless and impossible, because it covers luminence levels far greater than your monitor can produce, and because your monitor is not linear, either.
To view it, you take the data and multiply it by the exposure level you're trying to render, then you gamma correct it. Using my e-sphere, you can set gamma in = 1.0, gamma out = 2.2, and set the luminence (exposure level) to any value you like. This way you can bring out the details in the interior, or the details in the exterior, but not both at the same time, not for direct viewing.
Reflections such as above are effectively reducing the exposure level, which means darker details become invisible and brighter details change from being impossibly white to becoming easily visible. If we were comparing exposure levels to make an HDR like the one I used above, where you have bright sun outdoors and dark indirect lighting indoors, the exposure levels to capture detail in these two areas are 1000 times apart. At the same f stop and ISO setting, I'd need to use 1/5000 of a second outdoors and 1/5 of a second indoors in order to be able to squeeze the details into the luminence data range representable by a JPEG image.
Gamma In should be 1.0 yes, but only if your HDR image is linear. Not all of them are linear. Dosch sells HDR images that are actually sRGB, which is a violation of the specification for HDR images and also a gross generalization of the sRGB color space. sRGB does not extend beyond 1. Values like 1.5, and certainly values like 150 are meaningless in sRGB.
kobaltkween ( ) posted Fri, 20 February 2009 at 7:33 AM
wait.  then how are they HDR?
bagginsbill ( ) posted Fri, 20 February 2009 at 8:28 AM
How are what HDR?
bagginsbill ( ) posted Fri, 20 February 2009 at 8:33 AM
Oh I think I understand your question. I say those are HDR reflections because they are reflections of HDR data. Look at my last image.
The flat mirror and the black sphere are reflecting the same thing, but at different exposure levels. If the e-sphere image was not high dynamic range, then the part that looks white (outdoors) would actually be clipped at white. A reduced intensity reflection of that such as on the sphere would be a solid gray. Instead the reduced intensity has detail in it - detail we could not see at the exposure level reproduced by the mirror.
A low dynamic range image would not simultaneously have meaningful interior and exterior detail. You'd have to choose which to record, by chosing an exposure level. That would lock in the data for one range and totally discard the data from the other range. So low-intensity reflections and high-intensity direct viewing would not be simultaneously possible as it is in my render.
kobaltkween ( ) posted Fri, 20 February 2009 at 8:38 AM · edited Fri, 20 February 2009 at 8:38 AM
um, no, sorry for jumping in and being unclear.  i was following along until your comment about Dosch selling HDRI that only go as high as 1 (and maybe only as low as 0?).  how can it simultaneously clamp values greater than 1 and be HDR?
ice-boy ( ) posted Fri, 20 February 2009 at 9:18 AM
aha now i understand. for true realistic renders we need to use HDR maps. but we can not use this for backgrounds. because this is all data.
correct?
bagginsbill ( ) posted Fri, 20 February 2009 at 10:44 AM · edited Fri, 20 February 2009 at 10:44 AM
Quote - um, no, sorry for jumping in and being unclear.  i was following along until your comment about Dosch selling HDRI that only go as high as 1 (and maybe only as low as 0?).  how can it simultaneously clamp values greater than 1 and be HDR?
I didn't say the Dosch mis-constructed HDR was clamped. I said it was encoded in sRGB data values, not linear as it is supposed to be. The HDR spec says luminance is linear, i.e. luminance = dataValueInImage.
In JPEG or any other sRGB, luminance = dataValueInImage ^ 2.2
See the difference?
It's no big deal to convert from one to the other. But it is totally a big deal if you don't/won't/can't understand the difference which results in the necessity to perform conversions, i.e. to gamma correct or anti-gamma correct or do nothing.
You're supposed to be able to follow this simple rule:
HDRI are linear - I do not need anti-gamma before I can use it as data. I do need to gamma correct before displaying the data.
When Dosch did the opposite, you have to use the opposite rule.
With a Dosch HDRI is non-linear - I do need to anti-gamma before I can use it as data, I do not need to gamma correct before displaying the data.
See the problem? I cannot give you a simple rule. I've been through this at length on some other thread. "How do I know if it is linear or not" You know because if it looks stupid when you look at it - then it's linear. If it looks great when you look at it, it's sRGB.
