Forum Moderators: RedPhantom
:: (and ya don't see me do THAT very often, unless it's a bit of ordinance! :) ) um... um... dunno, can you just send a pp2 out the way you send out cr2's? but seems to me the pp2's have the geometries embedded in 'em. plus, there's no obj, so you couldn't use objaction mover... i hope you can, though, it looks delicious! :)
Thanks people, Unfortunatly, It is more involved than just a quick UV map. I REMOVED the fork and napkin. So now the original obj file is quite different. and the new geometry is contained in the CR2. I guess the best way is to do it all over again with the original obj file untouched. Just hoped that there was a different solution. James PS: What flavor Ice cream? heheheh.
I downloaded the "Peice 'O Pie" from Zygote's site. Fun prop. So I immeadatly figured I needed a better map. So on to the grouping tool and UVMapper. As you can see from the render I broke it up in several peices. Top, sides, bottom and back. I also removed the napkin and fork. My question is ... Now that i've done this and made my texture, how can I share this? Is there a way to share without having to send the new obj file? James
