Well, if you get that much, hook me up with a couple hundred grand. Computers are property, so destructive software and invasion is like destruction of property, plus i think there are some laws pertaining to malicious programs auto-downloading onto your computer or something. Before you reformat, i'd get to google and search for Ad-Aware, run a deep scan of everything and see if that helps. Ad-Aware usually gets that stuff out pretty well, and if that doesn't work I guess you'll have to take more drastic measures.
Attached Link: http://mjc1.com/mirror/hjt/
try this one"Reinstall Windows" is NOT a troubleshooting step.
If you can...... restore to a date previous to that visit to the real estate site. I have had to do this and it worked ok. If you have to reformat though, don't just format. Do a low level format and write all 0's back to your drive. That will eliminate any garbage that a regular or high level format won't take care of. Your hard drive will be like brand new.
There are 10 kinds of people: Those who know binary, and those who don't.Â
AÂ whiner is about as useful as a one-legged man at an arse kicking contest.
Attached Link: http://www.spychecker.com/software/antispy.html
or these"Reinstall Windows" is NOT a troubleshooting step.
Attached Link: http://www.answersthatwork.com/Tasklist_pages/tasklist.htm
tasklist someone say task list.."Reinstall Windows" is NOT a troubleshooting step.
This may be OT..Not sure why, but today I was surfing in here and clicked on forums, all of a sudden I lost my login and then internet.Nothing to do with my cable provider.Seemed almost as if I was invaded and had my config messed with.Unhooked my router and changed some IP config which got me back online.Now all is ok.
Painting: The art of protecting flat surfaces from the weather and exposing them to the critic_____website
I had the same while surfing a music site. Nothing could get rid of it and in the end I reformatted my Pc. Had to call Microsoft as I could not re-activate my Windows XP (They were very nice and activated it). Worst of all I forgot to back up my Bryce library files (mats, skies etc.). All the materials and skies and obps I had backed up, but not the library files. I had to import all of them one by one again.
Man, i really hope that these f.....g spammers, one day messes with the wrong people and end up with concrete shoes. Hope you solve it.
Rudolf Herczog
Digital Artist
www.rochr.com
STOP DO NOTHING!!! Don't install or buy a software remover!
Go here and follow the steps
http://www.pchell.com/support/ncase.shtml
Funny that this came up my computer was just got by something called the Internet assistant! This was a tricky one cause I must have clicked what I thought was a close button to install it(that should be illegal). I then had this IE assistant which may or may not have been usefull the point being I didn't ask for it. Then when ever I would type an Internet search it would take me to a chinese web portal (weird!). When I finally found it in add/remove programs it was in jibberish and the buttons did not work.I did a system restore and bye bye IE assistant. Someone should take a kick in the shorts for writing that one. Keep yer code clean not mean.
You think this is bad. My son's PC shop got hit by 2800 virus' over a weekend........
Thanks everybody for the info, in the end Spybot and AdAware could not get everything, so I used some reg hacks and still there are some persistant little buggers out there, so, I will do a wiping of my HD and then a low level format(as recommended), then a full reformat(oh boy, just what I wanted to spend my Saturday doing)but I do agree with Rochr,........I hope these schumcks get what's coming to them one day ! Once again, thanks for all your attention, ...............TOM(sackrat).
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
Simple solution for avoiding problems like this: Turn off Javascript in your browser. In fact, turn off all active content (Java applets, Javascript, ActiveX). Also while you are at it get rid of IE and use Mozilla or Opera or something else which is less of an insecure pig. If you have active content turned off, you can't get pop-ups or any of that other crap. Some sites require Javascript for certain things. Those that actually require it for navigation almost never have anything worth seeing, so I never see those sites. In other cases I simply turn Javascript on when I need it, then turn it off. Honestly, the Internet would be a better place if everyone simply turned off Javascript and boycotted sites that require it for navigation. Redneck - pop-up free since 1994
I don't have the Java machine on my system at all and although it means I can't do some things I'd like to do I have as yet not had any of these kinds of problems. All the active stuff in IE is very, very bad in my opinion 'cos it's like leaving a back door open for all sorts of destructive rubbish. Sorry this has happened to you sackrat but the last time this happened to me I had no choice but to reformat too. It suck's but sometimes it's the only way. 8) Catlin
Help !!! I went to a real estate site the other day and when I left the site, my main machine had been invaded by a company called "n-CASE - 180 Solutions" ,..........a spam and pop-up company. Well, now Bryce 5 will not load at all !!! I am periodically unable to type anything except caps. Does anyone know of a registry hack or anything else that will remove all traces of this piece of crap company from my machine ? I've tried reinstalling Bryce a number of times,.........I've used just about every piece of spyware removal software available,...AdAware, SpyBot etc......all to no avail. As well as being really frustrated, now I'm starting to get REALLY pissed off. And yes, I've tried to contact the company and have, as of this writing, recieved no reply. No real big worries,.........I've backed-up all my data(images, scene files, meshes, etc,.....to an 80 GB USB external HD,).....so I can always reformat my machine again, but that is a MAJOR pain in the butt. I'm not in the mood to do it again. But I suppose that's what I'll have to do if I can get no reliable answers or solutions. So, if anyone has any experience with this alleged company of alleged human beings(n-CASE - 180 Solutions) Please let me know, as I am getting very desperate,.............Thanks for your attention,........TOM(sackrat).
