Sat, Nov 23, 6:54 PM CST
Subject: Question about using UVMaps & Photoshop to edit textures
pazu ( ) posted Sun, 14 December 2003 at 9:18 PM ยท edited Sat, 23 November 2024 at 6:46 PM
OK, I've managed to create UV maps using UVMapper. Now I want to bring the UV map into Photoshop as a layer so I can use it as a guide to edit textures on other layers. My question is: how can I get Photoshop to display the white portions of the UV map as clear while keeping the black wireframe lines as perfectly opague? Right now I can only figure out how to reduce the transparency of the entire overlaying UV map, but this hazes out the texture beneath it.
Also, am I going about this the right way? Thanks!
PhilC ( ) posted Sun, 14 December 2003 at 9:46 PM
Select any white area using the magic wand tool. Now go to Select/Similar. Next go to Edit/Cut. This should leave the black lines whilst enabling you to see the layers underneath.
Little_Dragon ( ) posted Sun, 14 December 2003 at 9:53 PM
Alternatively, set the layer's blend mode to Multiply.
pazu ( ) posted Sun, 14 December 2003 at 10:13 PM
Thanks PhilC and Little Dragon...both those suggestions work great!
Lyrra ( ) posted Sun, 14 December 2003 at 10:41 PM
I usually set the template to Darken and work on layers underneath it. For dark colored items I invert the tempalte and set it to lighten ..
SWAMP ( ) posted Sun, 14 December 2003 at 11:26 PM
Attached Link: http://www.edesign.com/filters/
Promote your template to a layer and zap it with the eliminate white plugin (free at link),and you now have a wireframe on a transparent background. SWAMP
IndigoSplash ( ) posted Sun, 14 December 2003 at 11:55 PM
I make it into a mask and apply it to a solid black layer, it gets rid of all the white perfectly.
pazu ( ) posted Mon, 15 December 2003 at 1:38 AM
Once again thanks to all! Not just solutions to my basic question, but some great techniques I never even suspected were there, even a filter. What a great resource this forum is!
Tintifax ( ) posted Mon, 15 December 2003 at 8:00 AM
Use it as lowest layer. This is especially necessary when you are using a template with colored seamguides.
mikeberg ( ) posted Mon, 15 December 2003 at 8:35 AM
I would love having a tutorial explaining all these techniques for the newbie that I am.
jonzan ( ) posted Mon, 15 December 2003 at 8:43 AM
Attached Link: http://www.unwrap3d.com
Still having problems? I have another suggestion for you. If you're a pc user (sorry mac!), Unwrap3d can export straight to a Photoshop layer! No fuss, no mess. Which is pretty cool if you like vector layers and stuff.
