Fri, Feb 14, 2:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: WIP...need help
Avengia ( ) posted Wed, 11 February 2004 at 11:01 PM · edited Tue, 11 February 2025 at 4:52 AM
Okay...I have decided to try texturing, after having talked with Morris. She was able to point me in the right direction, but I think I am missing something. I have below a sample of what the texture looks like, but it still has a plastic look to me. How can I get it to look more real? I have heard someone talk about a "bump" map, but I have no idea how to use one, or apply one to a texture. This is for V1/2, and is created in PS7, if that helps any. Any help you all could give me would be so much appreciated.
Avengia ( ) posted Wed, 11 February 2004 at 11:04 PM
And here is what she looks like with no hair.....and no postwork what so ever....this is a straight render from Poser4.
whoopdat ( ) posted Wed, 11 February 2004 at 11:36 PM
A quick a dirty bump map can be made by saving your existing texture as a greyscale image, then apply it as the bump. I imagine the "pros" also adjust levels when they do that, but I could be mistaken.
TrekkieGrrrl ( ) posted Thu, 12 February 2004 at 3:11 AM
A very light grey noise map can also be used as a bump map - fill the texture with a light grey, add a noise filter and whalla: instant bumpmap. It will require some tinkering to look right - for one thing the head and the body texture are different size ratios so a bumpmap that looks good on the body will look way too coarse on the head. But it's good as a starting point. Nice texture btw, I like the eyebrows :o)
TygerCub ( ) posted Thu, 12 February 2004 at 4:48 AM
Two things that jump out at me immediately: The infamous glowing nostrils. Change the material to black. It' won't be perfect, but will help. Second, the eyes look artificial. The ring of light/white color around the pupil looks wrong. If you could create a more subtle shading, it might help.
TygerCub ( ) posted Thu, 12 February 2004 at 4:49 AM
Avengia ( ) posted Thu, 12 February 2004 at 7:13 AM
All this wonderful advice! I am so happy =) Okay..first, the glowing nostrils. You say change the material to black. I am going to assume you mean in Poser itself in the highlights section? I'll definately give that a try. As for eyes looking fake....I was going for the "contacts" look. As you can tell, these are not regular eyes. Should I still try to get rid of the white ring? The eyes (I will admit) are not my own creation, but added to the texture after. Third, I take it the bump map is totally seperate from texture map? i.e duplicate the texture map as a whole different picture, and then make the changes?If this is true, then I will definately try that and see what happens. Thanks so much everyone =)
rasputina ( ) posted Thu, 12 February 2004 at 7:34 AM
I love the mouth, gorgeous lips and color.
bull57 ( ) posted Thu, 12 February 2004 at 8:54 AM
I find, making a realistic bumpmap in photoshop is: open texture> goto filters> noise> ad noise. goto image>ajustments>desaturate (this ll make it greyscale) go to image>ajustments>brightness/contrast, and ad some contrast, then finall, goto filters>stylize>emboss (angle-90/hight 30/amount 60%, you can play around a little here, use the Save for web option to make it a little smaller .I find these make real good skin and textile bumpmaps! (remember to save under a different name or you'll lose tghe original!)
