A very light grey noise map can also be used as a bump map - fill the texture with a light grey, add a noise filter and whalla: instant bumpmap. It will require some tinkering to look right - for one thing the head and the body texture are different size ratios so a bumpmap that looks good on the body will look way too coarse on the head. But it's good as a starting point. Nice texture btw, I like the eyebrows :o)
All this wonderful advice! I am so happy =) Okay..first, the glowing nostrils. You say change the material to black. I am going to assume you mean in Poser itself in the highlights section? I'll definately give that a try. As for eyes looking fake....I was going for the "contacts" look. As you can tell, these are not regular eyes. Should I still try to get rid of the white ring? The eyes (I will admit) are not my own creation, but added to the texture after. Third, I take it the bump map is totally seperate from texture map? i.e duplicate the texture map as a whole different picture, and then make the changes?If this is true, then I will definately try that and see what happens. Thanks so much everyone =)
I find, making a realistic bumpmap in photoshop is: open texture> goto filters> noise> ad noise. goto image>ajustments>desaturate (this ll make it greyscale) go to image>ajustments>brightness/contrast, and ad some contrast, then finall, goto filters>stylize>emboss (angle-90/hight 30/amount 60%, you can play around a little here, use the Save for web option to make it a little smaller .I find these make real good skin and textile bumpmaps! (remember to save under a different name or you'll lose tghe original!)
![file_98162.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_98162.jpg)
Okay...I have decided to try texturing, after having talked with Morris. She was able to point me in the right direction, but I think I am missing something. I have below a sample of what the texture looks like, but it still has a plastic look to me. How can I get it to look more real? I have heard someone talk about a "bump" map, but I have no idea how to use one, or apply one to a texture. This is for V1/2, and is created in PS7, if that helps any. Any help you all could give me would be so much appreciated.
