Wed, Dec 4, 1:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 5:49 pm)
Subject: Grandma, what big claws you have!
Little_Dragon ( ) posted Mon, 23 February 2004 at 6:18 AM · edited Wed, 04 December 2024 at 1:47 AM
I'm in the final stages of assembly for Furrette 2.0.
Do you think this is overkill for her claws? As modeled, these amount to 200 polygons per claw, and with her four-digit hands the total is 1600 polys for the claws alone (the plantigrade feet won't have claws). By comparison, Victoria 3's nails average about 234 polys apiece.
I don't know if the claws would ever feature prominently in anyone's renders, so is this level of detail necessary? Opinions?
Incidentally, the design is patterned after a black bear's.
Tashar59 ( ) posted Mon, 23 February 2004 at 7:04 AM
Could you make them as a separate prop? Those that want to use them can. Would save on original size.
Little_Dragon ( ) posted Mon, 23 February 2004 at 7:14 AM
Smart-props? I hadn't considered that possibility. Thanks. Would make it a bit difficult to control the claw morphs, though; you'd have to select each individual claw, rather than having a master dial in Body to extend them all simultaneously. Perhaps as a conformer ....
dirk5027 ( ) posted Mon, 23 February 2004 at 11:10 AM
think these will work with m2 or m3, i've been wanting claws, very nice job
SpottedKitty ( ) posted Mon, 23 February 2004 at 3:14 PM
Nope, IMHO not overkill at all -- they look great. In fact I have a few ideas for pics using Mia and/or the Second Nature figures that really would need a realistic set of claws to look good. The standard long-fingernail morphs just don't cut it.
Would it be possible to have the smart-propped claws (if you decide to do it that way) useable with standard Vicky or Posette hands? (I think that's what Mia and the Second Nature critters have.) Would it just be a matter of re-parenting each claw to its fingertip, or is something more complicated involved?
One more idea -- wouldn't smartprops give us the option of setting up claws in the toes as well, if we want?
Looking forward to seeing Furrette 2...
AntoniaTiger ( ) posted Mon, 23 February 2004 at 4:52 PM
I think you could cut the polygon count a bit in the straighter section near the base. Look at the wireframe; there's not much change in the bit between the base-bulge and the start of the curving. As a prop, or whatever, you should be able to do a low-res claw as well. Most of the time, I doubt anyone would see the difference.
Little_Dragon ( ) posted Mon, 23 February 2004 at 5:19 PM
Yes, SpottedKitty; I could make conformers or props for Posette and Vicky. DAZ already sells something similar in its Cat Character package for Victoria 2.
I'll post some preview pics of Furrette 2.0 shortly. I haven't finished putting together all the pieces, and I'm still UV-mapping everything while converting from triangles to quads, but the modeling itself is complete, and I can share a few wireframes and untextured renders.
I'm hoping to keep the polycount under 20000, but I have yet to attach the head, tail, and fur, and I have no idea at this time how much that will add.
Little_Dragon ( ) posted Mon, 23 February 2004 at 5:35 PM
Here are a couple of comparison shots ... Furrette 2.0 in the middle, Posette and the original Furrette to the sides.
I basically scrapped the original mesh (which had its beginnings as a crude, low-res player model for the computer game Half-Life) and built a new mesh from scratch. By using the original as a visual reference during the creation process, I could ensure that the new figure has the same proportions and measurements.
Little_Dragon ( ) posted Mon, 23 February 2004 at 5:42 PM
And from the rear ....
My modeling skills have improved considerably over the years. It helps, though, that I'm specifically building the new version for Poser.
These shots of the body do not show the transmapped fur layers that I'll be adding later.
Little_Dragon ( ) posted Mon, 23 February 2004 at 5:51 PM
The new hands (at left) are much better than the originals (at right), which weren't intended to be posable in the computer game and didn't fare well in the conversion to Poser. This is an early test render; I've made some adjustments since then. And I'm particularly pleased with their UV-mapping.
Little_Dragon ( ) posted Mon, 23 February 2004 at 6:04 PM
Since Furrette 2.0 is essentially nude beneath her fur, I'll be including some conforming clothing with the initial release. Although she can wear Posette's clothes (more or less), these will be special items tailored specifically for her, with matching full-body morphs.
Planned items include a t-shirt, trousers, shorts, and footwear. Here's an example of the boots, currently in development ....
Little_Dragon ( ) posted Mon, 23 February 2004 at 6:08 PM
And here's an early pic of the catsuit.
hauksdottir ( ) posted Mon, 23 February 2004 at 8:29 PM
Not to look a gift critter in the nouth (especially when it comes with sharp fangs), but I thought that this version would have digitigrade legs? Did I misunderstand? She looks good, regardless, but I really need the backwards knees. Carolly
Little_Dragon ( ) posted Tue, 24 February 2004 at 1:19 AM
Initial release will be plantigrade, with the digitigrade option to follow.
Elfwine ( ) posted Tue, 24 February 2004 at 1:55 AM
Wouldn't a full body suit (like a cat suit) be fatal to a bi-pedal creature completely covered in fur? I mean, they don't sweat. At least indoors, the thermostat could be lowered to make it comfortable, but then the humans would freeze. Wouldn't they would prefer a minimal amount of clothing?
 Don't sweat the petty things, and don't pet the sweaty things!  ; )
Little_Dragon ( ) posted Tue, 24 February 2004 at 3:01 AM
That issue comes up occasionally among furry artists. It usually boils down to fashion and style vs. practicality and comfort.
In the comic strip Freefall, one of the main characters was raised by humans and thus has been instilled with their cultural mores concerning modesty. Also, she's a ship's engineer, so she needs a form-fitting jumpsuit for its protective qualities against hazardous work conditions.
If you really want to have some fun, try asking members of the furry community about the pros and cons of footwear ....
For Poser, however, the catsuit is an essential utility, as it can be transmapped to create a wide variety of clothing.
freyfaxi ( ) posted Tue, 24 February 2004 at 3:49 AM
Does this mean we'll have a good looking Florence AmBrose ? I can't wait to start working on some pics of her :) Did I also recall correctly ? I think in a much earlier thread there was reference to a possible equine-based anthro. Was I correct there ?
hauksdottir ( ) posted Tue, 24 February 2004 at 4:00 AM
I'll be patient. Really. I agree about the cat suit being needed... transmapped you can get wreathes of leaves or leather straps or anything spaced out so that sweating isn't an issue. It gives flexibility to create clothing across body parts. Puss in Boots was so distinctive because he did wear shoes. ;^) Thanks! Carolly
Caly ( ) posted Tue, 24 February 2004 at 9:17 AM
Oh, looking forward to this! :) Can I beg for a long dress as well? :) It could then be transmapped into a short skirt etc.
Calypso Dreams... My Art- http://www.calypso-dreams.com
Renderosity Gallery
Little_Dragon ( ) posted Tue, 24 February 2004 at 11:37 AM
The actual modeling of a long dress wouldn't be difficult, but making the skirt conform is probably beyond me. Would dynamic cloth be acceptable?
I also don't know if I can model a bikini; someone else might have to develop one of those.
Speaking of which, have you seen the new trailer for Shrek 2?
Here's a preview of the trousers. I haven't added pockets or belt loops yet. If anyone's ever wondered how bipeds with tails manage to put on their pants, the answer is that there's also a fastener in the back.
Caly ( ) posted Tue, 24 February 2004 at 11:43 AM
Ahh I only use Poser 4, so dynamic cloth wouldn't work. It's great work anyways. :)
Renderosity Gallery
hauksdottir ( ) posted Tue, 24 February 2004 at 3:33 PM
Yes, and the Donkey's response is priceless... only ONE annoying talking animal allowed. ;^)
Little_Dragon ( ) posted Tue, 24 February 2004 at 3:50 PM
No, that was just the teaser ... they have a new trailer up on the site with additional footage of Ser Puss hacking up a hairball (and Donkey gets transformed into a white stallion).
shogakusha ( ) posted Tue, 24 February 2004 at 3:54 PM
LD, if you want to model a long dress, I'd be willing to take a crack at conforming it. I have had modest success before, although I may have to use some 'cheats like body handles or extra bones. Let me know! BTW, this looks like a terrifically awesome project of yours. Shogakusha
Little_Dragon ( ) posted Tue, 24 February 2004 at 4:38 PM
I might take you up on that offer, shogakusha. I'll let you know in a week or so, after she's released.
catlin_mc ( ) posted Thu, 26 February 2004 at 1:48 AM
Your critters are always adorable LD and I'm really looking forward to playing with Furrette 2.0. 8) Catlin
mondoxjake ( ) posted Tue, 02 March 2004 at 4:13 PM
Thanks for coming up with another great product and sharing it with us. Only comment in ref to poly count of claws, and clothing items that I have is: Please don't forget those of us who are still sticking with Poser 4 on lower end-system resource computers.
Valandar ( ) posted Tue, 02 March 2004 at 11:44 PM
A suggestion - make the claws a conformer, so that yoou can put FBM's on claw length, etc...
Remember, kids! Napalm is Nature's Toothpaste!
shogakusha ( ) posted Mon, 02 August 2004 at 3:34 PM
Hey Little Dragon, Assuming you have modelled a long skirt for Furrette 2.0, my offer still stands to work to make it a conformer. Let me know! Shogakusha
catlin_mc ( ) posted Tue, 03 August 2004 at 12:08 PM
It's been so quiet in regards to Furrette 2.0 for a while, is there any news on your progress Little Dragon? Catlin
