Thu, Feb 20, 1:46 PM CST
Forum Moderators: RedPhantom
Subject: whats causeing this?
grid ( ) posted Sat, 15 May 2004 at 3:34 PM · edited Tue, 18 February 2025 at 6:14 PM
Himmm I dont understand Whats causeing this? Ive Checked Everything Any one Ever run into this?
TrekkieGrrrl ( ) posted Sat, 15 May 2004 at 3:39 PM
Have you grouped it? And could those odd polygons somehow belong to another group (or material zone)? Looks very odd indeed.
grid ( ) posted Sat, 15 May 2004 at 3:46 PM
Yea its Been Grouped To all the Right Groups. I even did it @ times to be safe... =( I will post the Group part to show
grid ( ) posted Sat, 15 May 2004 at 3:49 PM
Here be the Image off The groups
nerd ( ) posted Sat, 15 May 2004 at 4:29 PM
Forum Moderator
You're going to need to re-do the UV mapping on this. The UV co-ords in that spot are messed up. Load it up in UV mapper, you'll probably find those facets off in one corner or something. Nerd
grid ( ) posted Sat, 15 May 2004 at 8:54 PM
I have Redone the Uv maps as well..
grid ( ) posted Sat, 15 May 2004 at 9:05 PM
Its The Same Thing on Both Sides Of the Item.. I Redid The Uvs and I still get the same thing I regropup It over and over
nruddock ( ) posted Sat, 15 May 2004 at 9:22 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1703140
If the item has double sided polygons and your using P5, then you need to add a tiny displacement to each material, and set the displacement bounds appropriately (see linked thread).
grid ( ) posted Sat, 15 May 2004 at 9:40 PM
OK THis is Whats Seems To be Going on. I Used UV Maper To Split The Shirt Front and Back. And This seems To Be causeing this. I i Dont use the Split by oritan and Keep it all together I dont get the mis place poly. This is strange. This Seems to happen With ever thing I made So far I just Check some other Iteams. Wounder why? sorry its p4
grid ( ) posted Sat, 15 May 2004 at 9:41 PM
Image forgot
nerd ( ) posted Sat, 15 May 2004 at 10:06 PM
Forum Moderator
That's it. Those orphanded polygons actually face the back while the ones around them face the front. A better way to do this (This should be a tutorial) In UV mapper create a view from the side. Plannar. X axis
nerd ( ) posted Sat, 15 May 2004 at 10:11 PM
Forum Moderator
Now assign select the polygons that should face front and assign them to a region
nerd ( ) posted Sat, 15 May 2004 at 10:12 PM
Forum Moderator
Now invert the selection and assign the rest to a new region called "back"
nerd ( ) posted Sat, 15 May 2004 at 10:15 PM
Forum Moderator
With those polygons still selected assign them a new plannar map, don't split it and this time use Z axis
nerd ( ) posted Sat, 15 May 2004 at 10:17 PM
Forum Moderator
Now select the front region you saved earlier and give it the same style map
nerd ( ) posted Sat, 15 May 2004 at 10:19 PM
Forum Moderator
Now just resize your front and back halves to fill the template. Nerd
nerd ( ) posted Sat, 15 May 2004 at 10:26 PM
Forum Moderator
If you want to venture into unwrapping the model this is an easy one to start with. A cylindrical map with just a touch of offset on the z axis will unwrap the top nicely. Happy Rendering! Nerd
TrekkieGrrrl ( ) posted Sun, 16 May 2004 at 4:58 AM
Oh I would wish someone would do an easy-to-understand tutorial of the offset thingies in UVMapper (pro) I've simply never understood how they work. And being a total math-illiterate I always have to try them all to figure out which axis is x and which is z. The Y is USUALLY easy (from the top) but as soon as bu original ovj isn't facing straight ahead I'm lost. Help?
nerd ( ) posted Sun, 16 May 2004 at 6:10 AM
Forum Moderator
Yeah and Poser's world being twisted 90 on the X axis doesn't help either. And don't feel bad I'm a math brain and I have to try them all first too. Nerd
grid ( ) posted Sun, 16 May 2004 at 7:45 AM
Yuper this is good stuff.... thx for the help.. its good to go now
Cyhiraeth ( ) posted Mon, 17 May 2004 at 4:09 PM
This is great, Nerd! This will help nicely with something I am texturing right now. Any chance you could do some more tutorials regarding this type of stuff? (pwetty pwease?) ;-)
