Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
Attached Link: https://home.comcast.net/~jhe1024/ChefHat.obj
I did a quick check of the usual suspects (DAZ, RDNA, TurboSquid, 3D Cafe, and Terra Incognita) and I couldn't find anything. I'm attaching a link to a chef's hat I just now whomped up in Wings 3D... I don't have a copy of Poser on this computer, so I can't check to see how it imports, but it ought to work okay, as long as the polygon smoothing doesn't warp it out of shape. I don't have the tools here to turn it into a prop file, but you should be able to import it okay. I expect a simple white texture with little or no highlighting will look okay with it.If it's close but not quite, please let me know and I'll see if I can't fix it up some more.
HTH,
Jack
Yeah, it looks even worse on my machine,as shown. Just to test it, I imported the model into POV-Ray, and it seems to render okay, except for the too-well-defined edges in the band. I modeled the band at the bottom with hard edges, so the vertext normals make it look odd in POV.
I intruded the base of the hat inside, to make it hollow, and I suspect that that's part of the problem. I'd bet that Poser is getting some of those polygons to show. I'll see about modelling a different one without the interior polygons and see if that makes a difference.
Jack
Attached Link: https://home.comcast.net/~jhe1024/ChefHat2.obj
Okay, this one is a little better, anyway, but it's still not great. Guess I've got a lot more to learn about modelling for Poser. :)I set the diffuse color to white and diffuse value to 1.000, specular value to 0.000, ambient color to white, and ambient value to 0.500, FWIW.
Jack
Hi. I need an apron and a chef hat like this:
Can you help me?I need it for V2 or V3
Thanks.-
Message edited on: 08/25/2004 12:49
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
