Fri, Jan 24, 9:52 PM CST
Subject: Need an apron and chef hat
Casette ( ) posted Wed, 25 August 2004 at 12:48 PM ยท edited Wed, 22 January 2025 at 2:21 PM
Hi. I need an apron and a chef hat like this:
Can you help me?I need it for V2 or V3
Thanks.-
Message edited on: 08/25/2004 12:49
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
CaptainJack1 ( ) posted Wed, 25 August 2004 at 1:35 PM
Attached Link: https://home.comcast.net/~jhe1024/ChefHat.obj
I did a quick check of the usual suspects (DAZ, RDNA, TurboSquid, 3D Cafe, and Terra Incognita) and I couldn't find anything. I'm attaching a link to a chef's hat I just now whomped up in Wings 3D... I don't have a copy of Poser on this computer, so I can't check to see how it imports, but it ought to work okay, as long as the polygon smoothing doesn't warp it out of shape. I don't have the tools here to turn it into a prop file, but you should be able to import it okay. I expect a simple white texture with little or no highlighting will look okay with it.
If it's close but not quite, please let me know and I'll see if I can't fix it up some more.
HTH,
Jack
Casette ( ) posted Wed, 25 August 2004 at 1:50 PM
No problem, I hope to work well with it resizing and texturing Thanks, Rafa.-
CASETTE
cooler ( ) posted Wed, 25 August 2004 at 2:08 PM
Attached Link: http://www.philc.net
PhilC has/had a chef hat & apron in his archived freebies
Elsina ( ) posted Wed, 25 August 2004 at 2:44 PM
Poserworld (subscription site) has this one for Mike 2 with morphs.
My gallery @ Renderosity
pakled ( ) posted Wed, 25 August 2004 at 10:04 PM
eh..I tried..but wrinkles didn't come out quite right..;)
Dizzie ( ) posted Thu, 26 August 2004 at 12:16 AM
Jack, it seems to have a band across the bottom when rendering...:>)
CaptainJack1 ( ) posted Thu, 26 August 2004 at 6:23 AM
>> Jack, it seems to have a band across the >> bottom when rendering...:>)
Yeah, it looks even worse on my machine,as shown. Just to test it, I imported the model into POV-Ray, and it seems to render okay, except for the too-well-defined edges in the band. I modeled the band at the bottom with hard edges, so the vertext normals make it look odd in POV.
I intruded the base of the hat inside, to make it hollow, and I suspect that that's part of the problem. I'd bet that Poser is getting some of those polygons to show. I'll see about modelling a different one without the interior polygons and see if that makes a difference.
Jack
CaptainJack1 ( ) posted Thu, 26 August 2004 at 7:32 PM
Attached Link: https://home.comcast.net/~jhe1024/ChefHat2.obj
Okay, this one is a little better, anyway, but it's still not great. Guess I've got a lot more to learn about modelling for Poser. :)
I set the diffuse color to white and diffuse value to 1.000, specular value to 0.000, ambient color to white, and ambient value to 0.500, FWIW.
Jack
Casette ( ) posted Thu, 26 August 2004 at 10:51 PM
Thanks a lot ;)
CASETTE
CaptainJack1 ( ) posted Thu, 26 August 2004 at 10:57 PM ยท edited Thu, 26 August 2004 at 10:57 PM
You're quite welcome, hope it's useful. :)
Message edited on: 08/26/2004 22:57
