Mon, Jan 27, 6:51 AM CST
Subject: Really good male hair that isn't dynamic/transparencies made?
dvd_master ( ) posted Sat, 23 October 2004 at 9:32 PM · edited Mon, 27 January 2025 at 6:46 AM
For a class, I have to use a character in a movie. But I can't find ANY good male hair that isn't Dynamic or use some form of transparency map. I need to use green-screening on it, and dynamic and trasnparencyies where is blends into the background make really undersierable effects. All the skull cap/wig types look very fake and underdeveloped. Any help I could really use. If you have any you could send me, please PM me.
PapaBlueMarlin ( ) posted Sat, 23 October 2004 at 11:39 PM
Poser hair is either a prop consisting of multiple hairs (hence transparencies) or can be created in the hair room of Poser 5. Both types can look real or fake depending upon the level of detail placed in them. Could you show us a screen shot of what character you are working with and what results you are wanting. In my opinion, some of the dynamic hair looks fake because the hairline is too high. If this is the case, you can make adjustments. PS - tell us when the assignment is due so we can expedite our assistance...
AmbientShade ( ) posted Sun, 24 October 2004 at 4:50 AM
I may be completely wrong, but, hair props are always going to use transparency, whether they're dynamic or not. that's part of what goes into giving hair the realistic effects. if no transparency is used in its creation, then the hair is going to look "plastic", like those people from those old energizer commercials. keep in mind, a green screen background is going to eventually have some form of scenery added to it, which would remove the green bleed-through from any transparent material and replace it with parts of that scenery. E.D.
dvd_master ( ) posted Sun, 24 October 2004 at 11:57 AM
Can you help me with green-screens then? Attatched is an EXAMPLE (I don't really want to green-screen it). No matter what I try in Premiere or After Effects, it tries removing the color in solid amounts only, and doesn't catch the gradients for when the brush is part see-through. All the good Poser Hair would have this same problem. What software/plugin would make it look like there was never any green-screen. Ever.
PapaBlueMarlin ( ) posted Sun, 24 October 2004 at 2:55 PM
you might ask in the animation or director's forums...
brainmuffin ( ) posted Sun, 24 October 2004 at 3:05 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=787015&Start=1&Artist=brainmuffin&ByArtist=Yes
You can have this hair if you want it. It's transmapped, but it's only really transparent in the front and the back.
BastBlack ( ) posted Sun, 24 October 2004 at 3:14 PM
dvd_master, Forget chroma keying, it's messy and unless you love rotoscoping to get rid of helo, I strongly suggest you render with an alpha channel, then import the animation with alpha channel in After effects. Piece of cake. bB
Saro ( ) posted Sun, 24 October 2004 at 7:14 PM
I agree with BastBlack, make use of the alpha channels in Poser. It works in After Effects (i've tried it). There is also an option when rendering the movie (in After Effects) that you must check...I think that it's "+Million Colors" anyway, just look for the plus sign. Then make sure it's an animation file. I did that, and I could then overlay the movie onto another movie/layer.
dvd_master ( ) posted Sun, 24 October 2004 at 9:19 PM
Can you go in detail about the alpha channels for Poser? Like, where would I go to set it. I really appreciate this. And where is the option in After Effects to check? Thanks thanks thanks.
Naylin ( ) posted Mon, 25 October 2004 at 2:25 AM
Save the image as a png instead of a jpg... I think tif also, but not really sure about that.
Image on the left just plain white BG... On the right just dropped in a BG... No other work done at all. There is a slight halo on the hair a little bit, but not bad.
--Naylin
    My Store   My Gallery
____
"You have the right to remain silent. Anything you say can and will be misquoted and then used against you."
PapaBlueMarlin ( ) posted Mon, 25 October 2004 at 9:54 AM
I think he's talking about an animation rather than a plain image.
dvd_master ( ) posted Mon, 25 October 2004 at 7:05 PM
I does need to be an animation. Is that possible, or could I even export the video as image sequence's (with the transparencies?) Finally, I just do Export > Image and change it to TIF and it automatically creates the alpha-thingy? Thanks
