Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Okay, that made no sense whatsoever. ;) What is a 'correcting controller' (and I've got a rather good indepth knowledge of Poser)? I understand putting one figure into the same pose as another type, but what's this about 'value of 1'? Is this a Full Body master dial? How do you compensate for rotation variations between figures with this method? Thanks
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Sorry, I'll try again ... "Correcting controller" (newly coined) is a controller - Partial Body Dial that, when set to 1, will return the pose of the new (zeroed) figure to that of the old (zeroed) figure . Hope I make sense so far ... The way to obtain the Corrector is to : Superimpose the new figure on the zeroed old figure in Poser . Adjust the dials of the new figure till the pose matches that of the old figure . Save out a pose . Open the pose in a text editor, and check the rotational values . Create a Partial Body Dial on the new character with those rotational values that are non zero . Poses created with the old figure can then be applied to the new figure; and if the Partial Body Dial is set to 1, this should correct the poses for the new figure .
Poser may be many good things, but having figure standardization is not one of them. In attempting to make a "generic" animated pose for arms, I find that almost none of the values will transfer well from one figure type to another (i.e.: P4, P5, Mil figures). Rotations turn out completely different. Is there any possible way to get around this other than making a pose for each figure? I'm asking because the project would be practically impossible (or strictly limited) if one must use that technique. Thanks for any insights and responses.
-- Bjarne Stroustrup
