I've seen it had an option to save as .swf in the animation file formats but when I tried it in Poser 5 it didn't work out so well since I couldn't read the swf. I have done the render to .jpg each frame and import them 1 by 1 and it works pretty good.
Click to get a printed and bound copy plus T-shirts, mugs and
hats
Attached Link: http://www.quiss.org/swftools/
Haven't tried it but you might look at SWFTools which is supposed to have jpg2swf and avi2swf capabilities. Not a direct option but possibly useful."Democracy is a pathetic belief in the collective wisdom of individual ignorance." - H. L. Mencken
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1976031
Reading the thread at the above link may help.Attached Link: Flash poser
heres one shot at it. black and white only at this time. Look for the index like called inkcmdinfocentral-- The inkcmd feature is not in the manual. The reference page is all there is. The idea is to use poser to produce a series of obj files, then create a batch file that calls the inkcmd exe for each obj file, and turn it into an *.ai file. Flash then will recognize these as a sequence and pull them in. That's how I did the animations that you see on the page.
When I export Poser to Flash (because to publish on the web) I get a crappy cartoon like figure. Surely Poser-to-Flash works better than that --- or else what's the use of exporting to Flash anyway --- I am stuck using all Macintosh software and hardware --- can't afford to start over with .obj system. What do you think I should do other than 'dump this thread and search' ?
Attached Link: http://www.swishzone.com
Save to AVI and convert to SWF using SwishVideo. You'll find an example of one I did on my www.lostin3d.com Opening Page.Thanks, you are very helpful and I tried what you said and it worked ! I am now trying to convert .obj files to files I can open in any of the programs that broke me to buy viz. photoshop, illustrator, strata cx, fireworks, text edit, note pad, gif maker, flash, --- what's the deal with .obj files --- how can I learn more about converting files back and forth? I really like Poser and want to become agile with it and nimble. Thanks again for your helpfulness.
Attached Link: http://www.micromouse.ca/
You can convert OBJ's and many other 3D file formats using Accutrans from this link:This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Possible and how best to export a Poser animation to Flash
