Mon, Jan 27, 3:07 AM CST
Subject: Poser to Flash
gpacioli ( ) posted Sat, 25 December 2004 at 5:33 PM · edited Sun, 26 January 2025 at 9:48 AM
Possible and how best to export a Poser animation to Flash
gpacioli ( ) posted Sat, 25 December 2004 at 5:34 PM
Joe Strata says it can't be done.
Jaqui ( ) posted Sat, 25 December 2004 at 5:45 PM
export to a series of stills. import each still as a single frame into flash. or, select all and cast to time. but not directly from poser.
Argon18 ( ) posted Sat, 25 December 2004 at 6:06 PM
I've seen it had an option to save as .swf in the animation file formats but when I tried it in Poser 5 it didn't work out so well since I couldn't read the swf. I have done the render to .jpg each frame and import them 1 by 1 and it works pretty good.
Click to get a printed and bound copy plus T-shirts, mugs and hats
lmckenzie ( ) posted Sat, 25 December 2004 at 8:43 PM
Attached Link: http://www.quiss.org/swftools/
Haven't tried it but you might look at SWFTools which is supposed to have jpg2swf and avi2swf capabilities. Not a direct option but possibly useful.
jwhitham ( ) posted Sat, 25 December 2004 at 10:38 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1976031
Reading the thread at the above link may help.
dhenton1000 ( ) posted Mon, 27 December 2004 at 2:45 PM
Attached Link: Flash poser
heres one shot at it. black and white only at this time. Look for the index like called inkcmd
gpacioli ( ) posted Mon, 27 December 2004 at 5:34 PM
yeah! that is it.
InfoCentral ( ) posted Tue, 28 December 2004 at 1:28 PM
Inkulator? I was reading the pdf file and it didn't mention anything about animating with it but it sure shows a B&W animation with Poser 5 on the opening screen. Have you tried this program out?
InfoCentral ( ) posted Tue, 28 December 2004 at 1:45 PM
I guess I should say Ink9000 not Inkulator. I did notice that there is a command line renderer. I guess this is where the animations are done. But what about Poser's own Sketch Designer. Isn't it possible to produce the same thing with it?
dhenton1000 ( ) posted Tue, 28 December 2004 at 2:39 PM
infocentral-- The inkcmd feature is not in the manual. The reference page is all there is. The idea is to use poser to produce a series of obj files, then create a batch file that calls the inkcmd exe for each obj file, and turn it into an *.ai file. Flash then will recognize these as a sequence and pull them in. That's how I did the animations that you see on the page.
gpacioli ( ) posted Fri, 07 January 2005 at 6:02 AM
When I export Poser to Flash (because to publish on the web) I get a crappy cartoon like figure. Surely Poser-to-Flash works better than that --- or else what's the use of exporting to Flash anyway --- I am stuck using all Macintosh software and hardware --- can't afford to start over with .obj system. What do you think I should do other than 'dump this thread and search' ?
SteveJax ( ) posted Sun, 09 January 2005 at 7:23 AM
Attached Link: http://www.swishzone.com
Save to AVI and convert to SWF using SwishVideo. You'll find an example of one I did on my www.lostin3d.com Opening Page.
gpacioli ( ) posted Sun, 09 January 2005 at 6:32 PM
Thanks, you are very helpful and I tried what you said and it worked ! I am now trying to convert .obj files to files I can open in any of the programs that broke me to buy viz. photoshop, illustrator, strata cx, fireworks, text edit, note pad, gif maker, flash, --- what's the deal with .obj files --- how can I learn more about converting files back and forth? I really like Poser and want to become agile with it and nimble. Thanks again for your helpfulness.
SteveJax ( ) posted Mon, 10 January 2005 at 1:03 AM
Attached Link: http://www.micromouse.ca/
You can convert OBJ's and many other 3D file formats using Accutrans from this link:
gpacioli ( ) posted Mon, 10 January 2005 at 7:30 AM
Thanks Steve, There I go, stuck again. Accutrans is PC only and I was dumb for Apple.
SteveJax ( ) posted Mon, 10 January 2005 at 8:00 AM
Hrmmm...Well since you've gone and stumped me there all I can suggest is a google search on "3D File Conversion".
gpacioli ( ) posted Mon, 10 January 2005 at 11:15 AM
Hey, Great Suggestion! I know to do it but didn't think of it in the heat of battle. Thanks.
lmckenzie ( ) posted Tue, 11 January 2005 at 2:27 AM
Look under the topic forums over on the right. There is a Macintosh forum. They can probably help you with more information on 3D applications for the Mac.
