Hmm... I don't use Wings, I use Whino. (elitism!) But neither Wings NOR Whino use anything remotely like collision detection, much less gravity. Perhaps I'll just take this question to the Maya forum, but there's not many users that stop by there... Mostly, I was wondering if anyone knew how to do it in KnotPlot, or if there was a free app anyone knew about to do such a thing?
No, no... I suppose that I should have specified. I have no problem at all modeling chain links, or positioning them by hand. That's easy for me. What I'm looking for is a dynamic way to make the chains realistic. Keywords : gravity, collision detection. I guess I'll just dive into Maya and see what happens...
Glad to see you have gone back to scenes from the WOT. Is this going to be with Callandor there, or after? I had a go at the Dome at Far Madding, but never finished it, wasn't happy with it. Can't help with the chains, if I tried modelling a cube I would probably end up with a weird blob!
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
(laughs!) Aye, those were made with a torus and cylinder boolean combination. Too RAM intensive, for the amount of chains I need. I suppose I'm just too damn picky, on this scene. Robert Jordan may be the best writer, ever. I just want to do him justice! I've got my chain link from Rhino into Maya, now. Which is stupid. Maya and Rhino model almost identically, I should have just made it in Maya to start with. And I'm running the dynamics on both gravity and collision... should be done in a bit...
blender has collision detecting but i supose its not elitist for ya??? :P
for
some free stuff i made
and
for almost daily fotos
Good point, Erlik. I'm merely striving for perfectionism, here... It's all up in the air, anyway. Maya doesn't export objects without some kind of plug-in, which I don't have. So I'll just stick to the Rhino-to-Bryce solution... I'm not quite ready to do the whole scene in Maya, although that might be cool... I don't know how to use Poser characters in Maya, at all... Also, to do a chain the length that I need in Maya, with this rigid body /gravity technique, would drive any PC to it's knees, and take as long to calculate as the scene probably will to render. I tried the calculation on 12 links and had to close down Maya after waiting half an hour with no response. I must not be doing it right!
Doesn't Maya supposedly have a built in modeler? (post #15)I'm all confused now...
Wings works easy for chain links too. Cut a torus in half, move 'em apart some. Bridge back together. They can then be manually positioned using bounding box and vertice selections.
Attached Link: http://www.geocities.com/electroglyph2002/3Dresources/rhinochain/rhinochain.html
Did someone say Chains? Here's my Rhino Tutorial.oh..well, my work here is done..;) Not sure what collision detection in rendering is (in networks, it's CSMA/CD and such..;). I'd just take a torus, grab half, pull hard on the major axis. Duplicate along the axis, rotate the dupe on that axis 90 degrees, and wash, rinse, repeat to taste..but that's me..;)
Aye, Pakled, but a torus is a circle. A chain link is not necessarily circular! Indeed, you'd be hard-pressed to find any chain, anywhere, that is circular. Collision detection is when the polygons do not overlap, just like in real life. Bryce has nothing even remotely like collision detection, alas. If you move an object up against another object, they don't "bump" into each other. They just overlap. In real life, if you move two solid objects together, they cannot occupy the same space at the same time. They actually stop. This happens every time you touch anything, for example. Electroglyph, that's totally the way to go. Thank you very much! Should be a piece of cake, now...
(laughs!) Close, Xenic. But it's not even remotely like collision detection. I'm very familiar with "Land to". It's just a pale, fake imitation. Not trying to point out Bryce's flaws. But they DO exist. And I'm starting to need other options in my work. Bryce's "Land to" option is mathematical, based off of positions. It's not based off of polygons, and doesn't detect anything like that. Even with terrains, it's just a shadow of what other apps do. Which is why you can't roll a sphere down a terrain, for example. Hopefully they'll work on that for version Six. Now back to my architectural slavery!
A scene I'm working on calls for chains, to hang lighting globes from. The scene is the Stone of Tear, from the WOT book, "The Dragon Reborn", by Robert Jordan of course. Here's a quick prototype, I'm doing some architectural research so don't mind the garbage-looking arches. Those will be re-modeled... But I need to make chains hanging the lights which obviously don't exist in this scene. I want to make GOOD chains, links that can actually be used in Maya with collision detection and gravity on so that they fall into place properly, and I'm wondering if anyone knows how to do this? Of course, I'll be exporting the chains to Bryce (Maya not only uses the .obj format, it's parent company is the one that created the format!) Anyone know how to go about such a thing?
