DAZ|Studio F.A.Q (Last Updated: 2025 Jan 31 8:48 pm)
Hi, FranOnTheEdge! Which Dragon are you trying to use, and are you using the updated version of DAZ|Studio? I'll see what I can do to help you out ;) MS
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Millenium Dragon 2 Daz Studio 0.9.20.9 Fran
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
That release is a little buggy. Ok, it was a lot buggy. What I'd recommend first is to upgrade to the latest version of D|S, and see if you get the same problems with the latest build ;). If not, let me know, and I'll see if I can duplicate your problem with my Mil Dragon ;) MS
into a fruit salad.
Yup. Same.
Measure
your mind's height
Hi, Fran, I'm diligently trying to break the tail off of my dragon, to no avail. Is there a possibility of a screenshot of the broken tail? :D Thanks a bunch! MS
into a fruit salad.
Measure
your mind's height
aha. That is actually a fin "prop" figure that attaches to the tail. What you need to do is go to your "Scene" panel, and select the tail prop. When the "Parameter" panel shows the tail prop, look at the "Fit to" entry, and make sure it says "Millenium Dragon 2" or equivalent, otherwise, it won't fit to the character. Cheers! MS
into a fruit salad.
Magnificent, thanks so much - it actually worked!
Fran P.S. and the same thing worked with the body fins too, brill!
Message edited on: 05/20/2005 12:26
Measure
your mind's height
:D Glad to have helped! It's a tricky thing, if you haven't done it before ;) Have fun with the dragon!! MS
into a fruit salad.
Hi, I'm trying to pose a dragon in Daz but the poor thing's tail end keeps dropping off when I try to move the tail - help?
Measure your mind's height
Fran's Freestuff
http://www.FranOnTheEdge.com
