Sat, Feb 1, 1:50 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 31 8:48 pm)
Subject: Dragon in Daz
FranOnTheEdge ( ) posted Mon, 16 May 2005 at 12:12 PM ยท edited Sat, 01 February 2025 at 1:45 PM
Hi, I'm trying to pose a dragon in Daz but the poor thing's tail end keeps dropping off when I try to move the tail - help?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
JenX ( ) posted Mon, 16 May 2005 at 3:32 PM
Hi, FranOnTheEdge! Which Dragon are you trying to use, and are you using the updated version of DAZ|Studio? I'll see what I can do to help you out ;) MS
FranOnTheEdge ( ) posted Mon, 16 May 2005 at 4:32 PM
Millenium Dragon 2 Daz Studio 0.9.20.9 Fran
Fran's Freestuff
JenX ( ) posted Mon, 16 May 2005 at 4:49 PM
That release is a little buggy. Ok, it was a lot buggy. What I'd recommend first is to upgrade to the latest version of D|S, and see if you get the same problems with the latest build ;). If not, let me know, and I'll see if I can duplicate your problem with my Mil Dragon ;) MS
FranOnTheEdge ( ) posted Tue, 17 May 2005 at 4:52 PM
Yup. Same.
Fran's Freestuff
JenX ( ) posted Tue, 17 May 2005 at 8:03 PM
Hi, Fran, I'm diligently trying to break the tail off of my dragon, to no avail. Is there a possibility of a screenshot of the broken tail? :D Thanks a bunch! MS
RHaseltine ( ) posted Wed, 18 May 2005 at 10:01 AM
Is it possible that you (or a D|S glitch) have unhidden the translation dials on the tail? You should have Bend, Twist and Side-to-side sliders in the parameters palette, but not x-trans, y-trans and z-trans.
FranOnTheEdge ( ) posted Thu, 19 May 2005 at 10:44 AM
Screen shot as requested - with the dials, just in case it means anything to you.
Fran's Freestuff
JenX ( ) posted Thu, 19 May 2005 at 11:34 AM
aha. That is actually a fin "prop" figure that attaches to the tail. What you need to do is go to your "Scene" panel, and select the tail prop. When the "Parameter" panel shows the tail prop, look at the "Fit to" entry, and make sure it says "Millenium Dragon 2" or equivalent, otherwise, it won't fit to the character. Cheers! MS
FranOnTheEdge ( ) posted Fri, 20 May 2005 at 12:25 PM ยท edited Fri, 20 May 2005 at 12:26 PM
Magnificent, thanks so much - it actually worked!
Fran P.S. and the same thing worked with the body fins too, brill!
Message edited on: 05/20/2005 12:26
Fran's Freestuff
JenX ( ) posted Fri, 20 May 2005 at 2:10 PM
:D Glad to have helped! It's a tricky thing, if you haven't done it before ;) Have fun with the dragon!! MS
