_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
Nice idea ziggie ... you know you can make a really wet effect... change the footprints above to negative and use as specular map on a plane, it is the best effect when you render animation and change the light, the footprints will shine. you can also use a reflect node on a plane and plug in the footprints as low value bumps... it will looks like somebody was walking on the mirror .. I made this one a time ago in test animations :)
This is an awesome effect! Thanks, you guys, for sharing it with us! MS
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Hi Cath, (Mec4D) I did try that and from the top that does look really good. Maybe I'm too much of a perfectionist, but I learned that viewing from different camera angles will affect the realism of the effect, which is why I was looking for other ways to approach this. I think displacement maps are somewhat limited, although I hadn't thought of blurring the image, that would probably solve the hard edges. What started out as simply playing is becoming a bit of an obession LOL. I'll keep playing with it and see what comes of it. Thanks for your responses.
Tyger purr, Nice job, that definitely softens the edges. I think we're getting closer to creating a decent footprint. After sleeping on it for the night I think I'm going to go back to the original render (Figure 7)and instead of inverting it, just remove the black baground and then like Mec4D and Tyger purr try blurring the edges to soften them a bit. I'll play with that idea today and see what I come up with.
Sorry if I sound like a wet blanket (of sand??), but I'm afraid that none of the above attempts look very realistic to me. Please don't get offended; I sincerely admire the efforts going on here, but I feel I should add some constructive criticism. It took me a while to work out what I was seeing seemd wrong, but post 31 clarified it for me. If you look closely at a footprint in wet sand, you'll notice that the heel and the ball (plus the toes) of the foot go in deeper than the arch, and are distorted lengthways. This is because when the foot hits the sand as it lands, most of the weight is on the heel, and that weight is pushing forwards, not just downwards. As the stride continues, the weight is transferred fairly evenly through the arch, then onto the ball. Then the sand is pushed backwards as the foot propels the body forward. So you end up with deeper, longer heel and ball. The effect is even more noticable when running. I hope this is of some help. I'm not trying to be destructive.... I wonder if it'd be possible to do something using a python script? Okham??? Cheers, Diolma
I hope the single frame above from my animation shows, that by using a gradient matching the foot shape, that I'm on the right track.
I know this thread was done in June 2005 but I was wondering if it would be applicable to Vue5 Infinity?
I have a V3 walking along a beach barefoot at the waters edge.(The water is animated with a small surf rolling onto the beach) I want to animate one foot after the other (Walker Deigner V3 walk) 76 frames with a wet sand.
Do I set up my figure in Poser 6 first,Save as a PZ3 ? ..and then import into Vue ,or do I make my adjustments in Vue itself. If so,how do I do this? I have been working on this project off and on for about six months and I am tearing my hair out trying to achieve this animation.
Any help fully appreciated. Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Many Thanks.Cheers
bmk
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
A couple of questions regarding LZ2483's WIP.
Is the figure rotated 180 degrees below the ground plane?
How do you move the main camera facing down towards the feet? Every time I try to re- position the camera everything moves!
How is the square rotated to get a black outline?
For a 139 frame animation,do I have make 139 separate displacement maps frame by frame?
I am attempting to do this tutorial step by step to make an animation of a figure walking along a walk path on a beach leaving footprints in the sand as she goes!
Cheers
