DAZ|Studio F.A.Q (Last Updated: 2024 Dec 16 1:35 pm)
If it even exists. Some kind of dynamic cloth tool for D|S is an obvious thing to do, but I don't think DAZ have even hinted that they are working on one (there was a mysterious Weight parameter showing up at one stage, but I suspect that would be more likely to be connected to the joint system than dynamics).
Tnanks .I understand that Daz studio haven't a dynamic clohing plug-in .But i thought it was able to import a Poser file where one frame has a caracter with a dress being fitted using Poser clothify system.Now i can see :it cannot...sorry!!One thing i like in Daz studio is it cartoon rendering system and its link with Bryce 5,5.But i have Poser 6 and Vue infinite anyway
Message edited on: 09/18/2005 11:50
You should be able to import it if you prepose the character and do the simulation in Poser, then export the clothing as an object and reimport before saving the scene. The clothing wouldn't be dynamic anymore, but if you're only doing a still scene it would be the best way to do it.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
You can use the Group toll within Poser to convert the end result of the simulation into a prop, too. You can also turn the end results into morphs (several people have done that) to make a multi-morphed prop that can be adapted to a range of poses. I read your original question as being from someone without access to Poser - sorry.
Is it possible that DAZ studio cannot importe correctly clothify dress when importing pzz files with this kind of cloth posing on Victoria(for example)?I have tried two times :the cloth is there but just like it was not clothify(zero posing)?
