Mon, Jan 13, 8:32 PM CST
Subject: How to make a Surrounding helix of Thunder !!!!!
amlan70 ( ) posted Sun, 07 May 2006 at 11:35 AM · edited Mon, 13 January 2025 at 8:25 PM
HI,
    **     I am on a project that I decided to render out and alow materials from Bryce. Thus in here I need a helix of Thunder surrounding a girl`s body .. Usually if I need my thunder I add them in my post works through KPT or Autofx in PSP. But here I need a 3d thunder surrounding the girl. I thought of importing a lofted helix from 3Dmax and then applying some thunder material on it in bryce. But I didnt find any such material that can give similar effects that I usually get in my postworks. But then how to create the surrounding helix of thunder ?? Once I also thought of fractals , but then i dont know how to use it as surrounding thunder in Bryce. **
Super Brycians please help !!!
N.B> I may come up with frequebtr questions noq in Bryce or Max forum , But thats becasue I am finishing my portfolio for my admissions , and its only you people who helps me so much. Thanks..
TheBryster ( ) posted Sun, 07 May 2006 at 12:33 PM
Forum Moderator
I'm not sure I get this...:blink:
Are you talking about LIGHTNING? The Flashy electric stuff that creates the noise we call Thunder?
(posted through (IE6)
amlan70 ( ) posted Sun, 07 May 2006 at 12:43 PM
Ya Bryster !! You are correct , by thunder I mean Lightning.
So can someone solve my problem ??
TheBryster ( ) posted Sun, 07 May 2006 at 12:52 PM
Forum Moderator
There's helix in the CREATE catalogue/menu in Bryce and there's LIGHTNING in the Bryce FREESTUFF but you'll have to hunt for it.
tjohn ( ) posted Sun, 07 May 2006 at 1:05 PM
Fear me, for I am Helix of Thunder!!! (waves sword about).
Sorry, sounded like a good name for a barbarian. 😄
amlan70 ( ) posted Sun, 07 May 2006 at 2:21 PM
Ok ? But where is the Bryce material for Lightning ?? I understand its in the Freestuff are but in which site ?? I have already surched Renderosity.com.Its not there.Can you give me at least the name of the site ....
Anyone with any better idea.Feel free to extend the same....
TheBryster ( ) posted Sun, 07 May 2006 at 2:41 PM · edited Sun, 07 May 2006 at 2:43 PM
Forum Moderator
Attached Link: http://www.joes3dfantasyworlds.com/down/scifi01/scifi01.htm
Here's one for ya! :biggrin:
Rayraz ( ) posted Sun, 07 May 2006 at 3:01 PM
How about this for an alternative solution that allows you to use the postwork lightning creation methods you're already used to:
- Create a Cylinder in 3dsmax with a decent number of vertical segments (amount depends on the amount of rotations ur helix has to make
- Apply a mesh edit modifier to the cilinder, delete the caps at top and bottom, and all poly's on the sides except for 2 opposing collumns of poly's
  • Apply a twist modifier to the resulting mesh and twist it so your collumns of poly's will turn into a helix shape.
  • UVWunwrap the resulting helix to get a cylindrical map of the mesh.
- Draw a lightning texture on a black background the same way you would draw lightning in postwork using the UVmap as a template for the helix shape.
  • Bring the UV-mapped helix mesh into bryce, put it around your digital woman.
- Apply the lighting texture you made to the helix mesh. And make the texture Additive.
  • Hit the render button and check out the result :-D
(_/)
Rayraz ( ) posted Sun, 07 May 2006 at 3:05 PM
Additionally, if your lightning results look too flat you could always try to apply a noise modifier to your mesh to distort it some (in 3dsmax).
(_/)
amlan70 ( ) posted Sun, 07 May 2006 at 10:17 PM · edited Sun, 07 May 2006 at 10:19 PM
Good Rayraz , sounds good but I cd proceed upto 'UVWunwrap the resulting helix to get a cylindrical map of the mesh' . BUt can you please help me by detailing me a bit of the rest of the process as I have never sone those earlier . I am attaching a pic  for the the  last step I cd proceed upto !! Thanks......
Rayraz ( ) posted Mon, 08 May 2006 at 5:43 AM · edited Mon, 08 May 2006 at 5:46 AM
hmmm having a 2nd think about it. I think you might want to go with the default uv map your uv-unwrap will give you.
It'll create a very clean and easy to draw on template in this case. (see attached image)
Just render a UV template, open the resulting image in photoshop, and draw ur lightning texture on it. I would draw the texture in another layeras the lightning texture though, beause you will want to be able to remove the uv wire template from your final lightning texture 😉
Then bring the uv-mapped helix model into your render application of choise. apply the texture u drew, and voilá! I think in bryce u have to set the texture mapping to "parametric" to use the uvmapping of ur helix mesh...
(_/)
Gog ( ) posted Mon, 08 May 2006 at 10:58 AM
I wouldn't go with a painted texture, use something based on the volumetric plasma textures.....
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
Rayraz ( ) posted Mon, 08 May 2006 at 12:52 PM
Well, u could always still do postwork on a painted texture. And volumetric lightnings are very difficult unless ur highly skilled and experienced with the DTE, and even then they'd prolly not be that easy.
(_/)
