The morph problem: actually, if you set morphs in a dynamic part before starting the calculation, it will appear to be applied twice when the calculation finishes.
It's the same effect as when you spawn a new morph target from a combination of existing morphs: if you dial the new morph to 1, the other morph settings are added. In this regard, the generated Dynamics "morph" behaves exactly like an ordinary morph.
So if you use morph settings in a dynamic part, be sure to set them to the correct value at a frame before the calculation starts (usually frame 1), and set them to zero on a later frame (doesn't really matter what frame, as long as it is an earlier frame than the final simulation frame number).
Slowhands: if you're into animation, check out dynamic hair (strand based hair) too. Pick up the free hair proxies by kirwyn to make the calculation times bearable.
Animating the flow of transmapped hair, either prop based or conforming, is extremely time consuming and the results are usually not really good. Strand based hair is fantastic for animations.
@cobaltdream-
Thx, took me a moment to get it to act like that but still haven 't got the result that I am going for. cause I want it a bit more flowing.
Poser 7 is okay but I can't wait for them to do some updates. The cloth room runs way better but they have little things that they have to tighten up. And it can be frustrating at times being that I don't have a slow computer and it crashes at times. But the little problems they do have won't compare to the many problems Vista has. :P But I don't think Poser 7 and Vista was really playing together quite friendly cause I ran into numerous times that it collapse. Back on my XP harddrive just sometime the delete button stops functioning in Poser is the major problem I have.
Takes nothing to convert conforming cloths to dynamic if there modeled correctly.
Takes alot to make dynamic cloths conforming with morphs and all.
Why not just make conforming cloths that you can make dynamic if you want ?
Just model conforming cloths so thay will change over to dynamic if the buyer wants ?
Oh ya learning materials for anything in Poser is not easy to find free.
People our not going to use dynamic hair or cloth until it's explained to them easy and fast
RorrKonn
http://www.atomic-3d.com
The
Artist that will fight for decades to conquer their media.
Definately Hybrid for me, if it weren't for one problem - IS THERE A WAY TO FIX ALL THE FREAKIN CLOTHES FALLING APART? Arrrgg. Also, I have found that if I just select the hip (using a dress) it's a lot of hassle - having to constrain the top of it, Skirt not simulating right... if it drapes/moves at all. Maybe that was just one item, but anyway...
Yeah there should be a way that everything is automatically set up for the customers so all the customer would have to do is conform and then hit simulate. Not have to worry about how it drapes or locking certain areas. The easier it for someone to use the more will they would be to use it. I will have to check that out.
RorrKonn - that hasn't been my experience at all. i have stuff that doesn't convert to hybrid well simply because i've yet to see a simple and obvious way to combine groups. if i wanted to make the whole thing a prop, (mostly) no problem. but i haven't found a way within poser, for instance, to convert pants to have conforming hips and buttocks but dynamic legs made out the shins and thighs. i tried for a while with a certain set of clothes. every single option i tried allowed me to subdivide groups but not combine it with others. and when i left each part separate and made them dynamic, they did bizarre and unusable things. it's probably possible, but not so simple that i've figured it out, and i don't think i'm average in terms of willingness to muck with stuff.
conversely, philc has made a tool to make conforming clothes out of an obj file. and in fact, here's a one page tutorial showing how to do it by hand.
explained easy and fast? all the tutorials i've found have been both. compared to my efforts to convert conforming pants to hybrid, which failed after days, my efforts using my first dynamic clothes were painless. as in, about 10 -15 minutes, with trial and error of different settings.
but that's the important part. if clothes are quality made hybrids or dynamics to begin with, they're pretty easy to use. it's been hours of work and sometimes futile converting stuff. from making custom morphs so that stuff is pulled up in order to fall properly (i.e., in many poses, loose skirts should come down from a circle), to carefully choosing settings in order to make it behave properly. it would be a lot easier if clothes were made with the right morphs, the right dynamic, conforming, soft and hard decorated groups, and the right settings to begin with. asking customers to do all that themselves is basically not making it dynamic.
frankly, i don't think it's the info. i've been around a while, and i've seen multiple threads, multiple tutorials, multiple very clear instructions detailing all sorts of aspects of how to use dynamic clothes. i think it's three things: the quality of most dynamic clothes on the market, the lack of communal effort put into making dynamic cloth easy to use, and the complaints most people have about dynamic clothes in general.
in the first, i think so many dynamic clothes are made with no seams, edges or other finishing touches. they end up looking like paper thin clothes draped over the figure. so they don't look as good. hybrids and dynamics need to have the same level of quality as conforming to gain people's interest. in the second, i only know of a few people who have made presets for different cloth settings. if the community as a whole spent as long on cloth room settings as was spent on jcm tricks and killing poke-through for conforming clothes, it would be worlds easier for the average poser user to use dynamic cloth. also, as i mentioned, i find that with dynamic clothes you really have to consider the starting pose. results will be totally different with different starting positions. i think dynamic and hybrid clothing would be much easier to use if they came with morphs to work with that. there's lots of details and concerns that should be addressed. dynamic clothing shouldn't be treated like less complex conforming clothing, because it isn't. and the less that difference is handled by the creator, the more that difference has to be handled by the user.
the third issue stems from the other two. because users have to handle these issues, or just have things not work, many who try to use dynamic clothes end up having huge problems and giving up. and posting complaints that make it sound terribly difficult and arcane. personally, i've had issues in the cloth room and ones that i shouldn't have had if poser's cloth room were better. but the difference between quality dynamic clothes, clothes that were kind of thrown together (a couple of freebies, so no complaints), and converted clothes has been consistently huge. and hasn't just been a matter of the mesh. dynamic or hybrid clothing should be tested just as rigorously, come with just as many features, and be made with just as much care as if conforming clothing.
people will never use dynamic or hybrid clothes if they're made as an afterthought, and more effort is put into conforming versions.
Personally, as I've said elswhere, I don;t like converted clothing! Strange things cna happen with it since the "child" groups still affect the "parent" groups, so if a shin is made dynamic it can have odd effects on the thigh group, hip groups can affect abdomen groups etc. So hybrid cltohing I design have a "ghost" group of one or 2 rows of verts seperating the dyanamic groups from the confoming groups. I also name my dynamic groups differently than the groups in the main figure, to avoid conflicts.
Hybrids that break up happen as a general rule if there are no matching bones in the skeleton. Even specific dynamic groups have to have a coresponding bone in the skeleton of the conformer. Also check the group elding commands to be sure your dynamic groups are welded to the correct conforming group.
I agree with Cobaltdream, thought has to be put into the construction of the hybrid, makeing it as an after thought or conversion MIGHT give you decent results, or it might not. Making the clothing with Hybrid Dynamics as part of the design strongly reduces the potential problems.
I also wish E-Frontier would provide a file structure similar to the Material files in the Material Room where the setting could be save and loaded for the Cloth Room. This would go a long way to making the Cloth Room user friendly. Maybe some type of Mat (Dyn ?) Pose can be developed... I've just started look into what areas of the CR2 control the dynamics to see if this is a possibility but I'm not the most knowledgable person when it comes to CR2 hacks...
Still Hybrid Clothing can produce some really nice pictures and this is an area of Poser that deserves serious attention!
have fun,
mike
@cobaltdream
I absolutely agree with you. The more user-friendly it is made the more willing people will be to use it. Like a video game I never read the manuals that come with them I expect that the game control to be set up good enough that I can sit down and figure it out in a few moments. People even find it acceptable to have in-game tutorials instead of sitting with a book in their hands reading how to play. The in-game tutorial involves them more than a book. So I am sure that with dynamic clothes and hybrids people will have the expectation that there should be no hard work on their part.
trav - well, i do know that material files can be used to set cloth room settings. actually, that might be better. because then could have a material that just set silk as silk and denim as denim, with the correct material and cloth settings at once. instead of trying to do the two separately.
edited to add: i don't think cloth settings are quite universal, though, so i'd say it would be best if each piece of clothing had its own specific settings.
I have some conforming close.
The Topology is not always correct.
Dynamics has limits on what thay will do.
No you are not going to get dynamics with any and all the detail you can get out of conforming.
Hybrids would half to follow all the rules to work correctly.
And you will half to accept the limits it will still have.
Do not think ya morphs would stay after ya made a conforming dynamic.
I'm learning Poser 5.
I swear the person that wrote the Lightwave manual wrote the Poser manual.
INJ's nothing about them in the manual.
There are a few Tutorials out there.
With out this form I would still be rendering a cube.
zBrush, C4D went to the extreme with learning materials.
RorrKonn
The
I use comforming clothes, simply because I can't figure out the friggin' cloth room! :cursing: Try as I might, even with a tutorial sitting right next to me, I can't understand how to do it, or with me and learning something...why it does what it does.
I have 2 dresses I'm dying to learn how to use, the Abyssal Queen and the Starlight dress. They are beautiful gowns, but, they just don't won't play nice with me and I can't understand why. (and yes, I know, they are probably the easiest of the dynamic clothes to use! haha)
I have a feeling when I finally figure out the cloth room, I'll go into debt getting dymanic clothing for my little peeps.
RorrKonn - that's not true. i already own a couple dynamic clothing sets with good detail, some are in development, and some have been converted by others.
great examples:
http://www.runtimedna.com/mod/ophoto/index.php?photoid=12674
http://www.runtimedna.com/mod/ophoto/index.php?photoid=12498
and i think it's ridiculous to be talking about the limits to dynamic clothes at this point. conforming clothes work well after years of a huge number of people striving, innovating and sharing information about grouping, jcm, erc, and movement magnets. whole forums dedicated to the topic of creating conforming clothes. and there are, what 5 or 6 people consistently working with dynamic clothes? we just discovered hybrids, and very little has been done with them. if dynamic clothes were figure creation, we'd be on Posette and just discussing the possibility of Eve. if people had had the same "can't do" attitude about conforming clothes, we'd still be using Posette's wardrobe and saying it can't get any better.
as for poser 5, i believe it came out before v3 with her hundreds of injection poses. i'm not certain, but i believe they're a hack. iirc, you need to make them by hand or using injection pose builder.
StevieG1965- what problems do you have with the Starlight dress? i don't have poser here, but i believe this is what worked for me:
cobaltdream: I agree. Very few content developers work on dynamic cloth, there is still a LOT to learn.
The more I think about it, the more I believe that hybrids are the way to go. Actually, hybrids with helper bones, like my hybrid garter under development. The helper bone system has been developed for conforming clothes, years ago, and it has helped to partly overcome the conformer limitations, especially when it comes to skirts, dresses, and capes.
I think hybrids with helper bones will enable the cloth developer to have the same level of detail as we've come to expect from conforming clothes, with the added versatility and natural flow of dynamics. The best of both worlds.
So, unlike what RorKonn states, I believe that a well developed hybrid will not suffer from the limitations of both conforming and dynamic clothes. On the contrary, I believe that it will be possible to use the strong points of the conforming parts to overcome the limits of dynamic, and the other way around. The best of both worlds.
Still, there's a lot of research to do. I wonder how "state of the art" Poser clothes will look, a year or two from now...
Humm, while I'm thinking about it one other area of parallel developement to look into with Hybrid/Dynamic clothing is Displacement mapping. I remember a while back some one using displacement mapping to create really fabulous detail in a rather plan mesh figure. This might be another route to adding some really complex details in the Dynamic clothing and Dynamic groups of Hybrid.
Also, I generally try to add some wrinkles and folds to add some realism to clothing, but the idea of making a plain flat model and adding several displacement maps to provide the user with a CHOICE of wrinkle/fold patterns is something I've been thinking about, lately. Oh, so many avenues to expore and so little time!
have fun
mike
Displacement mapping is certainly another of those underused avenues. I've seen some really stunning work using displacement by stonemason, here in the forums, a year back or so.
I wish I had the time to learn more about UVmapping and texturing,... my mind's eyes sees hybrid clothes with the main features modeled into the mesh, and the fine detail provided by displacement maps, specular maps and more... damn, so much to learn, so little time...
displacement is definitely a wonderful source of variable detail. stonemason has some wonderful freebies that show off the power of displacement, as well as some products that do even more. and displacement is something that can benefit any type of figure or prop. the thing to keep in mind with dynamic clothes is how much you allow them to stretch. so if you decide, for example, to do all you seams in displacement rather than modeled, you might find that they do odd things in certain situations.
Cobal
Really have no idea why you took what I said and totally re wrote it to trash.
What is not true or ridicules ?
Conforming and Dynamic cloths both have limits,that is not my ridiculous opinion it is a fact.
Do not write imaginary sentences for me."can not do" I never said.
I want the best cloths possible,but I understand there limits that I half to deal with.
In any 3D App.
Just for a fast example,not the best example I no.
Tales of Adventure - Crystal Mage form DAZ
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=3020
The blouse has jewelry and stuff on it.
Not so sure ya could cloth the blouse.or if ya could it would do well as dynamic.
Not so sure it was made to be dynamic
I am saying model cloths that can be conforming and dynamic.
Ya brown suit was modeled to start with to be dynamic,yes ?
Would be easy enough to make conforming,Yes ?
Ya see what I am saying,now ?
RorrKonn
The
The Crystal Mage outfit - the corset is figure-hugging, and would be made of fairly stiff material in - ahem - "real life". Conformers work best in such a case, though fully constrained dynamic cloth would also work - with the advantage that you wouldn't have to set oodles of morphs (some of which might not be present) to fit a morphed Aiko..
The shoulder pads are designed to be armor. Stiff material. Conformers work best in such a case, dynamic wouldn't be any advantage.
RorKonn: you're talking about limits. I'd rather talk about possibilities.
Rigid or semi-rigid clothes profit most from the properties of conforming clothes, so they should be made as conformers.
Loose, flowing clothes profit most from the properties of dynamic cloth, so they should be made as dynamic.
Clothing that has both (semi)rigid and loose flowing parts, such as a long dress with a tight bodice should be made as a hybrid.
As for detailing, judicious use of conforming parts, rigid and soft decorated groups, and displacement maps, in combination with well thought out modeling will go a VERY long way.
We don't know the limits of dynamic cloth yet. As cobaltdream said, conforming cloth has been researched and expanded upon for many years, and some very clever tricks have been devised that have made conforming clothes better and easier to use. Many of those tricks were never envisioned by Metacreations/Curious Labs/e-frontier.
The same will happen with dynamic cloth and hybrids. It just will take time and effort.
Don't think in terms of limits. Think in terms of possibilities.
I'm not thinking limits, I'm thinking of making it correctly.
Thinking realistically.
Ah ok in most main 3D apps thay go the rules is model with only quads don't use tri's.
Thay say that cause most 3D app's when thay subdivide a Tri turns it to a quad then it pinches.
XSI,LW our the only 2 app's that I know of that will subdivide a Tri and leave it a tri.
Do not know what all the 3D app's will do.
http://www.atomic-3d.com/RK_Tutorial/RK_Sub_D_Quads.htm
http://www.atomic-3d.com/RK_Tutorial/RK_T_Mix_Sub-D_Tri-Quad.htm
Since TS,C4D subdivide system is limited to quads if your going to model a face.
Model it out of quads not tri's.
If you model it out of tri's it will look bad no one would want it.
If you going to make cloths regardless if there conforming,dynamic,hybrids make them correctly or no one will want them.
I pushed alot of app's to there limits that is the only way your no what thay will do.
I am just learning Poser but I will keep at it till I push it to it's limits.
There is no point in making cloths that do not work.
I am all for pushing it as far as we can thou.
RorrKonn
The
To say it has limits is to say man will never land on the moon. Everything is possible. All it is, is finding a new direction. That comes with hard work and new Ideas. I started with poser 4, and was happy to animate with it, but quickly saw a lot of limitations with the charactures clothing and renders. It was great for it's time.
Now look at what we are talking about. Displacement maps, clothes that flow. Hair that Flows. Special effects with bombs bursting in the air. Rain comming down. All these things I can do now, and it can be done because a number of people dove into the unknown and said. I'll find away. We have only just begun.
In three years "if the rest of the world holds together," You will see amazing things with clothes, renders, and animations. At that time then Then tell me I don't know what I'm talking about. When I first saw the Shrek animation, I was blown away. By the second Shrek movie, I saw some of the freatures in the movie that was filtering into Poser. No where that top knotch quality, but in the same direction.
Slow
"quote"To say it has limits is to say man will never land on the moon"
Man your reaching with that sentence.
Have no idea where this obsession of putting words in my mouth came from.
It's unprofessional I do not deal with unprofessionals.
RorrKonn
The
RorrKonn - no, i responded to exactly what you've said. you're actually now saying the opposite with
Quote - Ya brown suit was modeled to start with to be dynamic,yes ? Would be easy enough to make conforming,Yes ?
i believe carodan converted that outfit, but that's beside the point. in your previous post you said,
Takes alot to make dynamic cloths conforming with morphs and all.Why not just make conforming cloths that you can make dynamic if you want ?
this is the first thing i refuted. i don't need to do it again. but i will point out that you brought up clothes that were primarily designed to be conforming and could be made dynamic after the fact. which is why i said what i did. i think some people make dynamic clothes because they're easier to get working than conforming. which isn't bad at all, but it means that a lot of dynamic clothes don't have a lot of skill and knowledge put into them. and they often seem to get treated as the easy, quick and dirty way to make clothes. people see that, and then many think that's all dynamic clothes can be. instead of trying to improve them. so i think the above is a very negative starting point for discussing dynamic and hybrid clothing.
next you said
Quote - Dynamics has limits on what thay will do. No you are not going to get dynamics with any and all the detail you can get out of conforming.
i didn't say this statement was opinion, though the latter is. i didn't say as a statement it was ridiculous. i said it's ridiculous to talk about limits to dynamics and hybrids now. it's akin to looking at the limitations of posette's joints and saying, "well, poser joints have limitations." everything has limitations, but it's absolutely ridiculous to talk about them when you've barely begun to explore the possibilities. as svdl mentioned, the whole community has been using and creating conforming clothing for years. talking about the limits of conforming clothing now, after easy pose underground, after erc, after joint controlled magnets, and after apollo, makes sense. talking about the limits of dynamic clothing at this stage is not even vaguely equivalent.
making meshes that work properly in poser is only part of the issue. and a small part at that. there's lots of details i've run into in the cloth room, and most have had nothing at all to do with the mesh.
and no, you never literally said can't. but "you are not going to get" and "can't" are so close in meaning as to be splitting hairs.
and you said limits. as quoted above. referring to that is accurate, not "unprofessional." there's no need to get heated, but people are responding directly to what you are posting and the words you are using. if you want to correct yourself and use different words, fine, but stop accusing people of putting words in your mouth when all they're doing is refuting precisely what you've posted.
RorrKonn: Did I say you don't know what your talking about?
Your taking this way to personal. That statement is one of the future not the past. it is not even directed at you. That was a statement on the direction of the whole convesation.
I'm an optimist, I see the world with a lot of work, and without limits, if that upsets you, then be your professional self, "as you say. " I have no doubt that you are!" But don't start climbing on an alter and start preaching that everyone is below you. You know nothing about me.
Thanks for those settings, I had pretty good results playing around with the Starlight gown, it draped properly and all skin was covered except a little of the calf on one leg...so, good for a first step!! I'm still wanting to learn how to give a "flowing" look to it...ie, walking in the wind with the bell of the gown catching the breeze and blowing back, but, that's probably hit and miss playing with the dials and magnets. Now that I have a tiny idea with a simple standing pose, I'll start playing around with sitting poses and more complicated angles. This could be really fun! Thanks for the quickie help.
you're welcome! personally, i haven't mastered the wind force, so i don't know how to actually make something blow in the wind. in terms of trains trailing behind, it really matters where you start. for instance, if you want something to trail behind someone, what you want is to start with the item above the floor (obvious, but bear with me) and then allow enough draping frames for it to reach the floor before it starts the simulation. and in terms of the motion of the figure, you want her to move forward so that she can leave the train behind on the floor. at least, that's what i've found works.
Slowhands your right, we do not know each other.
This is causing confusion and miss understanding.
I did not mean to sound like anyone was below me.
Since I am new to the forms
Don't guess any of you all knows how to take me.
There for, my post are not being taken the way I meant it.
Since I do not know you all I am taking you all's post wrong also.
Now where all on deferent pages.
This does not help production.
If we keep at it will get to know each other.
Then will all be on the same page.
Then production will be flying to the moon :)
RorrKonn
The
Cobaltdreams
Is the tan belt loops Dynamic ?
Is the belt Conforming or Dynamic ?
Could you make the Dynamic pants button fly and put prop buttons on them ?
RorrKonn
The
my pic: Escape from the Office
that image uses svdl's free office clothes. the blouse has several different versions of fastening, the skirt unzips. the blouse has buttons, and the skirt has a zipper. note the visible seam at the bottom of the shirt.
he's making an even more complex hybrid set for v4.
this is what carodan said about his pants in this thread:
Quote - I'm getting more into using dynamic clothing. The realism just can't be beaten. I've also found that some conforming clothes convert quite well by exporting and reimporting them and running through the cloth room. In my pic I used the G2 Male Fashion Pants, magnet morphed to fit my Apollo character as closely as I could.
perhaps he went through the trouble of keeping the belt conforming, but unless he used a hybrid and then said it was just dynamic, pants are dynamic. i can't imagine how he would attach the loops as separate props, and export the pants without them.
A3 Clock
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=2999
I do not think it does dynamic.
but it's just a cape one would think it would turn dynamic easy enough.
Is there a list some where of when your modeling dynamic meshes what to do what not to do ?
RorrKonn
The
RorrKonn: This is an excellent way to discuss things that we are all leaning from the Poser point of view, cutting edge ways to make Clothes from one another that will be to everyones benifit. I like that fact that every one is taking a look at different techniques of going about putting Clothes in motion.
A Different point of view is vital to see things at a differnt perspective. What you experience is vital information that can be looked at, and studied. The things you experiece tells us all about problems or possable solutions that some may have not came across.
What we are doing now is working inside the box. The final porduct for fantastic clothing may well be a complete technique that is dicovered by accident, like Plastic was, as an example.
What ever we end up with, I hope is a more automated way of putting the steps to get it to work easier for the majority of poser masses. This might well be in the Efrontieer end product. But it might very well be stimulated from one of the many people working to make Hi Bred Clothing or Dynamic clothing as easy as Conforming. You will then see that market explode. The person that comes up with that product should make a lot of money. I'm all for that! (Not in the big price tag, but in the number of sales)
I'm sure if you come up with a way of making a great product, and as simple of a product to use, that is a goldmine combonation.
This is what confuses me.
the A3 Clock is double sides so it will not turn dynamic.
but the tan pants has belt loops.don't know if you would call them double sided but it's not a flat plane.
I can bevel a shirt collar and it turns dynamic.
Is not the bevel making the mesh double sided ?
I'm lost I do not get what the deference is between the clock,pants and shit collar.
RorrKonn
The
Quote - RorrKonn: This is an excellent way to discuss things that we are all leaning from the Poser point of view, cutting edge ways to make Clothes from one another that will be to everyones benifit. I like that fact that every one is taking a look at different techniques of going about putting Clothes in motion.
Slowhands
I am glad we are all getting on the same page.and every thing is starting to run smoothly.
Killer cloths and $$$ would defiantly be to every ones benefit.
RorrKonn
The
quote: *i defer to masters such as trav, svdl and others in this matter. but i'm betting it has something to do with being a dynamic, soft-decorated, hard-decorated, or choreographed group.
*It isn't really that hard but you have to be a little acquainted with the group-editor: Suppose you have a skirt with stitched-up pockets, a belt and buckle and some buttons on it and you want to lift up a tip of the skirt:
the skirt itself is part that moves, this is the dynamic group.
You don't want to drop the skirt, so a part of the skirt is attached to the body, this is the constraint group.
The belt and the pockets move and folding with the shape of the skirt: this is the soft-decorated group.
The bucket and the buttons move with the skirt, but keep their own shape: this is the hard-decorated group.
And at last when you want to pull or raise a tip of the skirt, you select that part of the skirt where you grip it, and then you go to the pose room and you move the whole skirt in the last simulation-frame in the direction you want. In the simulation only the part you selected will move that way: this the choreographed group.
Hope this clear-up things, I spent the last five days in the cloth-room and I learned a lot of new things.
I am starting to understand this stuff.
Poser 5, Don't think it has soft-decorated, hard-decorated.
May be I am missing some tools,
Could not hurt to get Poser 7 as soon as possible.
RorrKonn
The
Poser 5 does have soft and rigid decorated groups. It's just not described in the manual.
Quote - "Poser 5 does have soft and rigid decorated groups. It's just not described in the manual.[/quot]
If soft and rigid decorated groups are not in the manual.
I am open to suggestions on how to learn them ?
RorrKonn
The
The Poser 7 tutorial manual goes way more in depth about the cloth room and the purpose of each function. But just remember while you are doing you construction of dynamic cloth that
Soft decorated Groups
Assign vertices to this group when you want them to flex and move with the underlying cloth. Such as belts, belt buckles and shoe strings. So in the cloth room you will see the button for Soft Decorated groups just select it and then the group box will pop open for you to select the areas that will belong to the Soft Decorated group.
Rigid Decorated groups
Theses are parts of the group that when you want then to move with the underlying cloth but they don't bend or flex. When these are usually your buttons and jewelry type stuff. And you would do the same for the Rigid Decorated click it and the group editor box will pop up for you to select the vertices for that group.
I recommend when modeling you outfits in whatever 3d app you already know what you want to do with each area and make the groups in the 3D App so when you pull it over to poser the groups you set in the 3D app will transfer over. And you can just select the groups that way when setting up.
Go to the cloth room hit whatever functions you are using and then select add a group and all the groups you made in your 3d app will appear for you to select and it will add your vertices that way. But the Poser 7 tutorial manual is more explanatory. But that is really all it is to it.
Wow! Now I'm going to have a clothing file for each Conforming, Dynamic, and HiBreed piece of clothing. Once I finish up on the last parts of my movie, I'm going to have to do some serious messing with Dynamic, and HiBreed clothing. It is such a big improvement over Conforming. I just hope I can find a workaround for my movies So I can get the clothing to lineup correctly.
No Questiong that Dynamic is the way to go for small animations. I know most people use Dynamic clothing as Art and not animation. and it looks great. Once I get into it, I might start experimenting in making my own. So little time an so much to do!
Nice look there HollywoodBest. Unfortunatly I don't have any answers for you, as I am just starting to mess around with Dynamic clothing. I've been working on a movie for the last 6 months with about a week to go to finish, and I couldn't change the charactures clothing at this point. Maybe the next movie.
