Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 16 7:48 pm)
I don't know, but I'm seriously considering buying it. If it wasn't for the constraints of my hard drive, I wouldn't have any qualms at all. I have Vue 5 infinite but it leaks memory like a sieve. Naturally, (for e-on) Vue 6 didn't fix this problem. Though capable of amazing things, you still face severe constraints if you work with Poser imports without a supercomputer. You could use Mojoworld for placing Poser figures into environments, though the camera is awkward and you might spend 5 hours on a render before you discover that there are problems. Bryce 5 is junk. Not that you can't make good art with junk occasionally. Could Carrara 6 is the Poser environment and rendering solution I've hoped for all these years? I doubt it, but it might be worth a try anyway.
I have used carrara 5 pro and you can render massive scenes superb and have vue 5 and 6 though 6 esprite a rip off don't buy, it has problems that they made sure was not in pro or above.
You could wait a few days to see what post's people put up as I'm going to get today as have room on credit card, and hopefully the out door scenes and water like vue should be good.
If not sure just look for posts.
Just be aware that currently there's some confusion over why Transposer 2 wasn't included with Carrara 6 Pro and without it you can't import Dynamic Clothing or hair and many PZ3 files into Carrara 6 Pro that were created using Poser 7. Hopefully they'll be fixing the updates for folks who have previously purchased Transposer 2 with Carrara 5 or 5 Pro so they don't have to pay the extra $100 or $40 for PC members additional costs for Transposer 2 for C6!
Also, there seems to be an issue with Carrara 6's ability to search mutiple runtimes for calls from one figure and textures and OBJ's are having to be manually located by many people. If you have external runtimes, it has been found that if you have the word "Runtime" anywhere in your runtime folder structure above the actual runtime itself that Carrara has even more difficulty in locating items.
IE:
Good folder Structure:
G:Poser ContentDAZ ContentRuntime
Bad folder structure:
G:Poser RuntimesDAZ RuntimeRuntime < Two Too many uses of the word Runtime!!
As with any new software release, the users are finding all these issues that should have been caught in Beta Testing phase and filling the forums with posts about them.
Reccommendation:
Wait for the kinks to be found if you don't need the stress of testing software.
I'm confused already!!
According to the features page at DAZ I can import pz3's etc. into C6 with no problem!
In the forums everyone is going on about not having Transposer for Poser imports or such!! Anyone explain what this transposer is and what it does that C6 doesn't do without it!!
Sorry never used Carrara in any shape or form so it's all nerw terminology for me, I'm a Vue man up to now!!!
TIA!
Injustice will be avenged.
Cofiwch Dryweryn.
Transposer is an add-on utility that permits to import native pz3 with dynamic hair or/and dynamic clothes. Without it, you can import pz3 into Carrara, but without dynamic. I think it's the only difference.
I have C5, but never get use of it (not enough time... :)
Due to the Vue6 issues, i were looking at C6 too.
Transposer is a Plugin Importer that was made to import Poser files to Carrara before they ever had a native importer. It allows the importing of some features, such as Dynamic Hair & Dynamic Clothing, that Carrara's Native Poser Import just doesn't support. If you don't use Poser Dynamic Hair or clothing it's not needed. If you do, it's a must have.
Sorry to be a pain, so is the native Carrara 6 Pro importer work properly with Poser, only I've seen some threads at DAZ where textures and props etc. don't actually import!
After the nightmares I've had with Vue6Inf memory management I don't want to add another headache into the mix!! [LOL].
Cofiwch Dryweryn.
Did you READ the first post I made to this thread? It explains the problems people are having with imports and part of the reasons that have been discovered. I'm sure that more reasons will become apparent as we, the early birds, run it through the mill.
The native importer works fine on anything created in Poser 6 or below (IE: Poser's 1 thru 6)EXCEPT FOR Dynamic Hair and Dynamic Clothes. There is NO guaranteed Poser 7 Support because they never bought EF's SDK for Poser 7. This means content and PZ3's created in Poser 7 will cause problems. Workarounds are being discovered and discussed.
It has difficulty locating some OBJ's and some Textures due to naming issues with external runtimes and possibly other reasons as well which are as yet unknown. It appears that C6's runtime search feature doesn't like to go back and forth between runtimes to find OBJ and texture calls from more than one runtime per item being loaded.
" According to the features page at DAZ I can import pz3's etc. into C6 with no problem!"
I'm sure the marketing hype that claimed this is no longer visible so it never existed. Welcome to the happy valley. Also I distinctly remember being told by someone semi-official that C6P would read P7 files just fine. This was a decider for me because C5P chokes on P7 but not P6.
And there's one more problem to think about, if you are planning to upgrade from C5P. I registered my C5P at DAZ less than two weeks ago, giving them my serial number to verify and succeeding to the point that I qualified for a free upgrade. Fine, except my free upgrade says I have an invalid serial number. So I've had C6P since Wednesday, but I can't install or use it. I e-mailed DAZ immediately. Got a responsemore than 24 hours later that their Tech people would "look into it." So now it's Saturday and my C6P is still not installed. No word from their "Tech people."
I considered buying another upgrade, but what if the problem is that it can't read my serial number? Then I'm out a small but useful chunk of money. I even considered buying a new full license (a similar problem occurred with my Hex 2.0 license, and I gave up and bought a one-month PC and a new Hex 2.1 license), but based on what I see here, I think I'll wait until the product catches up with the promise. Who knows? Maybe what I have already was worth every penny?
M
The import of P7 pz3 into CAR 6P is not good ...9/10 times its stops working..
On my Xp Pc and on my MAC same thing...
Transposer2 for C6 is a complete ripoff ..
is was a part of C5pro ..so C6 Pro is 100$ over priced!
because they took it out for separate selling.. ripoff in my book.
So beware that P7 is not 90% working with C6Pro....
C6pro and P6 i dont know yet...
DS/should work but i see tons of "not working" messages over at DAZ...
Im NOT happy with it ....
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
I just rread a post over at daz that transposer was built into C6Pro, but as previously mentioned, P6 and below support are available and P7 support not.
If P7 had JUST been released, I could maybe forgive that, but it's been around for quite some time now. Looks to me like a move to get users into using DS rather then poser, and I have a feeling they will end up alienating a large portion of the P7 user base.
Regarding the problem I had with the serial number: Someone at the Carrara forum pointed out that DAZ issued a new serial number, listed on my "serial codes" page. Using that, I am installing C6P.
This does not address the P7 problem. If Carrara doesn't support P7 3rd party items, it will be of limited use to me. Really too bad, since it was my exclusive pro renderer for Poser when C5P worked with P6.
M
Sigh. The error message (including a Dr. Watson) apparently was a spook. Carrara is installed and runs. However, I tried to load my latest PZ3, made in P7 with V3, Heavy Horse, Harvey Mann's "I Dream of Jeannie" hair (Allura?), and the Environment set from DAZ, and it harrassed me for 20 OKs demanding a bunch of ...X.bmp files that I don't have. Needless to say, Poser loads this file without them.
Sure enough, loading PZ3's uses the old, unreliable Import approach. Haven't tried setting up the Runtime "transparently" yet, but the importer demanded that I identify my default Runtime, so the question may be moot. I'm with the folks who were given the distinct impression that TransPoser WAS the "transparent Poser load" tool. How silly of us.
For the record, here are the "non-transparent" elements of the imported PZ3:
That's enough fun for today. I have a Saturday to live in. I recommend waiting for the reviews of C6P 1.1. This looks like a not half bad modelling tool (of course, so is C5P), and it may integrate nicely with DAZ Studio. But as a tool for rendering Poser scenes, it's worthless. Unlike C5P. I recommend finding an old C5P and looking for some techie solution to loading P7 scenes into it. I think the only problem is that you must be able to point TransPoser at a pre-P7 exe file, so if all you have is P7, you are truly out of luck.
M
I think the point that's being missed is that with Carrara 6 Pro YOU DON'T NEED POSER! For anything!
You can load your existing Runtimes right into C6's content browser and start working right away. You can pose, add MAT poses, INJ/REM poses, conform clothing, etc.-right in Carrara. And it's much faster than Poser. C6's OpenGL is hugely improved over C5, so you can create animations and watch them back in real time before you render.
There's no point in worrying about Poser's dynamic hair either because C6's dynamic hair is just awesome. It simulates wickedly fast and the tool set for styling the hair is great. Plus you can use the dynamic hair for grass, fur, fuzz, carpet, etc.
Some of the crazier shader trees from Poser won't translate over, but who in the hell cares? C6's shader setup is hugely more robust than Poser's and if you spend the 15 minutes it takes to learn how to use Carrara's shaders, you'll have a wealth of possibilities at your fingertips.
The only thing I'm not sure about is dynamic cloth. Transposer handled it just fine, but I have too many deadlines to wait for Poser to run a cloth sim. DAZ's OptiTex plugin is on its way, so that should sove that problem.
I personally haven't had any issues with PZ3s in C6, but it is much faster to just load Poser content into C6 right from your Runtimes.
And to think I thought DAZ Studio would be the Poser-killer...
Well, ya still can;t rig a poser figure in C6pro, can you? If not, then yes, there still IS a need for poser, at least for content creators.
Are proceedural shaders supported from poser in opengl? If not, there's another reason you need Poser, if you are developing Poser shaders.
From your statement, it sounds liek there's now a third platform to support, Poser7, DS, and now C6p. fragmenting the market seems like a fool's errand to me. Content creators are already trying to maintain compatibility with P4-7, and DS.
I wonder if we'll see products with dynamic hair for poser only, and products for C6P with dynamic hair that are C6P only.. we're already seeing many DS only plugins available.
Quote - I think the point that's being missed is that with Carrara 6 Pro YOU DON'T NEED POSER! For anything!
That point certainly hasn't been missed in DAZ' C6P buzz fest. Unfortunately, it seems to have been missed in the implementation. If you are suggesting that I could have built the entire Godiva scene from scratch in C6P, that may be so, but it has no dynamic objects (of which I have many), the transparencies are part of the products in the case of all the cr2s but Vickie (a total of nearly twenty in two scenes), and the crumpling of the mesh might well have occurred even if the figure was zero'd out (I'll check tomorrow).
What's more, the C6P interface is not equipped with parameter dials, which are my first recourse, and the transform tools are far from as easy to use as Poser's. The one thing I have never adjusted to in Carrara is having to type parameter guesses into the boxes to move things (yes, I know about the neato gimbeled rings; I don't find them easy to use for some reason).
I say all this prepared to junk Poser permanently if I don't need it. Right now, I'd say it would be grossly premature. C6P may be the greatest all-around bargain in modeling software (though it's hard to beat Blender's "free"), but as a substitute for Poser it's a wash so far.
I'll give it a few more hours to convince me, but then it's back to the Blender tutorials for me, I suspect. If some GPL techie is working on a Blender to Poser interface, my mind will be made up.
M
Gareee, jt411 was talking from a user standpoint, and from his standpoint even though a merchant needs to continue to use Poser to develop content for Poser, that won't stop the customer from buying your Poser content if they want to becouse they will be able to import it directly into carrara. as far as procedural shaders for Poser yes they will be out of luck becouse Carrara uses its own shader system, so they will need to recreate shaders, but then again people already do have to do so for Studio in some cases. Some merchants have seen oppertunities in additional support for Studio, some have chosen not to. that may well happen with Carrara as well. just means more possibilities to me.
Sure you can rig figures in C6 Pro! Remember Carrara is a full-fledged modeler too. I don't think rigging in C6 is comparable to let's say 3ds Max, but it's there and it works.
As far as the dials are concerned, that's purely personal taste. I grew up on 3ds Max, so it's natural for me to manipulate body parts directly when posing a figure.
Carrara uses sliders for morph targets though :)
I'm not happy with Carrara6 Pro. I have bought Carrara5 Pro last year but never used it because I didn't like the interface and the way Carrara works. When I saw the dynamic hair in Carrara6 Pro I thought: "OK, give Carrara another chance!" so I updated to Carrara6 Pro. I still think it's difficult to work with Carrara. There is only a few tutorials (I tried Modo 203 -demo- and was very happy with the huge amount of well-done tutorials). In Carrara6 Pro I had to try and try again myself to understand how a function works, how I could make some hair, how to render it properly.... I finally understood how I could make some dynamic hair on a sphere. But the problem is that I can't export the hair. If I try to export it in Poser 6 a message says: error plugin...So what's the point on making hair if you can't export it? Personally I would never change Vue for Carrara. Creating landscapes is much easier, faster and better in Vue! My purpose is to use DAZ figures in a great environment/landscape. So if I use Carrara it's to create dynamic hair/cloth and export it so I can render my figure in a beautiful landscape. If I can't export any dynamic hair/cloth from Carrara it's useless for me.
I have an old version of Carrara and never really got on with the interface. I mainly use Poser, but after seeing some of the new functions I am thinking about getting it.
I was going to buy Syntheyes because it is the only Poser compatable motion tracker, however Carrara 6 although not able to do motion tracking itself can import them from a few programs. I have a motion tracking program that I got free on a magazine cover. What I need to know is:
It sounds a round about way of doing this but Syntheyes is more expensive the Carrara 6, and Carrara could be used for rendering, modelling etc while Syntheyes just does the tracking.
Daz Studio 4.8 and 4.9beta, Blender 2.78, Sketchup, Poser Pro 2014 Game Dev SR5 on Windows 8 Pro x64. Poser Display Units are inches
Dynamic hair - C6pro now has it's own dynamic hair so not being able to import Poser dynamic hair isn't too much of an issue. I also understand that a plugin will 'soon' be available to also give dynamic cloth capability within C6pro
This pz3 imported fine (V4.1 and juli hair) once I'd deleted all the lights - this rendered in about 40 minutes on relative high quality settings (AMD FX60 dual core with 2GB ram)
Quote - I've not had any problems importing P7 pz3s into C6pro once I came across the tip to delete the lights in Poser and resave the pz3.
You left out "and then spend whatever time it takes to do the lighting, cameras, and shaders again in C6P." Lights are much easier to work with in C6P than in Poser, and lighting effects are better. But using it with this tip means changing your workflow to avoid doing anything with lights until you go to C6P. Or duplicate effort. Personally, I prefer to work holistically, tinkering with lights, camera angle, pose and even props all through the process. I repeat, I would never assume that I can "just open my PZ3s in C6P." I was Ok with that in C5P, because Eovia had the integrity not to imply I could. The claim that you can in C6P is cheap marketing BS. Importing PZ3 files into C6P is actually less effective than it was in C5P, because of the greed about TransPoser (which was free in C5P, part of the "Pro" part...).
You also left out that transparency might as well be deleted, and C6P provides no simple way to make a single change to multiple shaders (a gross omission in Poser, but in Poser, the merchant's transparency settings work...). And that the default camera won't be set up in the scene. Create animation with complex camera angles and changes in Poser? Then plan to duplicate the effort after import. My imports all arrive with some sort of distant camera and the scene a tiny dollop in the middle of the screen. Just like in C5P. None of the camera settings are being used, as far as I can tell.
I haven't even looked at the animation compromises, but I'm sure they are substantial, regardless of whether the end result is better.
I would never consider importing a PZ3 with commercial shaders into C6P. P6+ shaders are a major part of commercial product appeal, and they will be hosed. That eliminates a whole lot of commercial products that supposedly can be used WITHOUT POSER!!!
It's a pretty good issue if you have invested in commercial dynamic hair. And I was under the impression C6P did dynamic cloth. Should have read the fine print. Since dynamic cloth is a major commerical line (and rightfully, since cloth works much better than hair in Poser), it's lack of availability is a major hinderance to using my Poser third-party props. I can understand not supporting cloth dynamics, but it's a simple matter to convert a dynamic cloth into a changed (or morphing) static object, and if it can't do that, then a big investment (of time and money) in one of Poser's advanced technologies is money down the drain.
What it boils down to is that Poser "replacement" was glib marketing hype. That's no surprise, considering the source, but I'm not going to sit by and watch DAZevangels recite misinformation in the face of the truth. The Cat_Knight morph that got crumpled on V3 is all DAZ technology; it won't even handle their own products! I am reminded of the first time I loaded V2 into the so-called "public beta" of D|S: It looked like such utter, useless crap that I deleted the program. My avatar at DAZ Beta Forums is based on what D|S did to her image map.
C6P might be a good substitute for Poser if you are
Personally, I've never fit the marketing demographic.
M
Looks to me like you have some work to do on skin materials - in case it's of any value (I don't know what Carrara's shading interface is like, so probably not much):
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2709987
Sigh. TBird: I think your "seamless import" speaks for itself....
Yes, we were under the impression that "TransPoser would be unnecessary" but your interpretation was a little different than mine. I assumed that meant because its functionality would be integrated into the application and the import function. Not that I would learn to live without it once I knew more....
M
Daz maintain that with C6Pro you no longer need to work in Poser, the 'truth' of this statement or not remains to be seen and it is true that there are some who will always prefer working in Poser to working in a new package. I see myself continuing to use Poser, certainly for now, but as I learn to use C6pro then that may change though I accept that it may never be as good for certain things as Poser is, I have to say though that I have never been able to get good results from Posers dynamic hair so I am looking forward to seeing if Carrara's is any better.
As an aside this was created entirely within C6pro, taking just a few minutes to put together using the content tab.
Uh, the two closeups you provided had really wonky materials. Not trying to knock you or anything, but ... :confused
Some problems with building from scratch:
Based on this, I concede (again) that C6P can be used effectively to create original scenes. Using it with any legacy material, from texture maps to PZ3s, is hopelessly time-consuming.
M
Here's what the dog's head looks like with just a single "Moonlight" object, default settings. Strangely enough, repositioning the "moon" has no effect on the lighting! I recognize that using C6P to its full potential will refine the image, of course.
Quote - Here is an image of the same 'material' rendered in P7.
Oh my. That ... is really not my kind of material set. On the other hand as you say, it seems to have converted reasonably well.
(bright red squiggly eyelashes??? :ohmy: )
I'm a C5 owner.... used it for a little while and then returned to Poser 6 again. Once in a while I still use it, but not often.
I bought C5 for doing multiple figure scenes. At the time I was using Poser 5 and Vue. Vue handles Poser figures badly and multiple figures even worse, so I switched to C5 with transposer, hoping it would do a better job. Not really...... it handles multiple figure scene pretty badly also. C5 becomes really slow and rendering (even with low settings) takes ages. While C5 has impressive features, it's slowness and slow render times spoils all the fun.
In the end I bought Poser 6 and I've not regretted it. For me it handles multiple figure scenes just fine and they even render at acceptable quality and in a acceptable time.
I wondered if C6 would do any better, but reading all of the problems people are facing, the many bugs (it's even worse then the initial poser releases) and looking at the horrible looking renders shown here that took a long time to render, I changed my mind and I'm going to spent my money on something else.
I also did try Vue 6, but that really is a joke, so I spent that money on buying a lot of landscape items and plants for Poser. Much better spent money.
I'm sticking to Poser and for my modeling needs I use my good Cinema4D v6 that offers far more modeling tools then C6 does and is very fast at everything.
Carrara sounds very impressive, until you start to use it, then it suddenly isn't as impressive anymore and after a while the way it worked even started to annoy me.
Food for thought.....
I have a question as i've seen the release of C6 Standard:
Does C6 Standard do something the other apps i have don't?
note: about dynamic hair, i played a little with it in P6, but never get good results.
Since you asked, I went and looked at the Carrara 6 feature list - wow, that is some slanted marketing.
http://www.daz3d.com/i.x/software/carrara/-/comparison
Poser 7 can't do custom keyboard shortcuts? Yes it can (editing one of the .xml config files).
Poser 7 can't do creation of morph targets?
Cinema 4d can't do "small/medium/large scenes"? Cinema 4d can't do boolean operations on geometry? Vue doesn't have primitives? Vue can't do boolean operations?
Also they completely ignore all the commonly available plugins, both Maxon proprietary and 3rd-party e.g. Kuroyume's interPoser.
Yep it's another one of those famous DAZ slander your competition campaigns to make yourself look much better, nothing new. I think they also should have a stabilty comparisment to reflect the truth a bit better. While C6 may have this or that, a good number of the features don't even work well and they've forgotten to fix quite some of the C5 bugs, they just carried them over into C6.
*"I have a question as i've seen the release of C6 Standard:
*It's safe to say that if you never used C5 even though you own it, that you will not use C6 either. If you're happy with the Vue6Pro-Hex2-P6 combination, then C6 will add nothing onto it (except for a lot frustrations perhaps). You're better of spending the money on something else.
Quote - Yep it's another one of those famous DAZ slander your competition campaigns to make yourself look much better, nothing new.
Golly, Mr. Hardy, you think? :)
Someday the Poser crowd will finally get it that giving away candy could maybe, just possibly, be a way to get you into the back seat....
M
You do most of us no justice if you call us the Poser crowd....... I'm using more applications then Poser only, as a lot of us do..... don't tell anyone, but I'm a Carrara user also.
I have a question - does Carrara have any method of smoothing polygons? I'm seeing poly corners that one would avoid in Poser by rendering with smooth polygons, and in other apps possibly by subdividing (that's how I do it in C4D).
That'd probably do the trick then, subdivision levels, although of course it would add to render time as it does in Cinema (not a real big deal to me though). Thanks.
Carrara 6 Pro is out. Will it be better for rendering Poser 6/7scenes? I have Carrara 5 regular.
