Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
This is a persistent problem, especially in Poser 7. Displacement
causes mesh lines to show. You might be able to improve the
situation with a finer mesh, or maybe not.
My python page
My ShareCG freebies
Displacement works in the normal direction (perpendicular to the surface). If two surfaces meet at, say, 90 degrees, and displacement is carried to the edges of the surfaces, they will appear to separate. I don't know any way around this. It is best to keep the displacement to details, and avoid going to the edge of a surface as much as possible where this will show.
There is a technique, using a color math node, that allows both positive and negative displacement on the same material. This may be helpful in some circumstances. If you're interested, let me know and I will search for ther thread.
John
The other solution would be to make it so that displacement works to displace the mesh inward, not outward. Do this by adding a subtract node in front of the displacement map. Connect the map to input 1, and set both input values to 1. Then connect this subtract node to the displacement setting in placeof the map. This makes the parts which had been pushed out (thus breaking the mesh) stay static, and takes those parts which had been used as the base level inward by the same amount the original deformation went out.
JonTheCelt
Quote - Displacement works in the normal direction (perpendicular to the surface). If two surfaces meet at, say, 90 degrees, and displacement is carried to the edges of the surfaces, they will appear to separate.
This is true for un-welded polygons - not true if they're welded.
When two polygons appear to share an edge, but they each have their own pair of vertices forming the edge, it only looks like they are joined. Any displacement works as John describes, moving the polygon in the direction of its normal.
However, when the two polygons actually share an edge, the normal is smoothly interpolated across the edge. Any displacement will do the right thing. Were this not the case, then displacement would never work on a Poser sphere or cylinder, yet it works perfectly.
Also, are you actually trying to displace (expand) the cylinder here? Or did you do that by mistake. Particularly, is it your intention that the smooth parts of this cylinder remain in their original positions? If so, you may be dealing with an issue I've written about a jillion times.
In Poser, displacement is based on the numerical value of the displacement source (image or math nodes.) Black = 0 = no displacement. White = 1 = 100% displacement. Mid gray = .5 = half displacement!
Many applications other than Poser use a convention that the displacement map is offset by 50%, so that mid gray is intended to mean no displacement (.5 - .5 = 0), black is negative half inward displacement (0 - .5 = -.5) and white is half outward displacement (1 - .5 = .5).
This is the style of map produced by ZBrush, for example.
If you've got a displacement map that is encoded this way, you're getting displacement from the mid-gray when you intended that you have none. The solution is to use a math node and subtract .5 from your displacement, and plug that into the displacement input.
Attached Link: Displacement thread
Link to a thread where I explained this in more detail, with pictures.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
Bagginsbill, I tend to disagree. Any object with a displacement map that is incorrectly applied will split along the edges, whether it is welded or not. The attached example picture is a welded box, yet because the displacement has not been corrected by a math node, it still splits.
Your specialist military, sci-fi, historical and real world site.
You can force Poser to pretend an edge is not welded, even if it is, by adjusting the "Crease angle" on the object.
Here are four Poser Hi-res spheres. The first has no displacement - the other three have a uniform 1 inch displacement.
#2 crease angle=80 - all smooth
#3 crease angle=10 - partial separation of some polygons
#4 crease angle=6 - total separation of some polygons
Quote - "This is true for un-welded polygons - not true if they're welded."
Nope - that's crease angle at work as I just cross posted!
When you tell it the wrong crease angle, the edge becomes unwelded.
However, Poser doesn't smooth 90 degree angles perfectly. It only really works for angles less than 90 degrees.
Both boxes have 1-inch displacement. The second one is welded with crease=100.
Same with cylinder.
Also, you may have to enable smoothing, to apply additional displacement based on welded edges.
Here I have a Poser cylinder 3 times. The second and third have been welded. All have 1 inch displacement.
The first explodes on the unwelded edge (top and bottom) but remains connected on the sides.
The second and third have crease=100.
The second no longer explodes, but has no "smoothing" so it looks wrong.
The third has smoothing, too and is closer to correct. However, as I said, Poser really can't deal with 90 degree smoothed angles too well.
But the locomotive wasn't anywhere near 90 degrees. Welding and crease angle will allow it to be displaced correctly. However, I really think the problem is that there is no displacement desired on the cylinder of the locomotive - the displacement map must be offset by .5 if gray is to mean 0 displacement.
OK, I stand corrected, although I must admit that the box doesn't look that good with a crease angle of 100, much better to just fix the displacement map as in my second example.
That is what I love about Poser, you learn something new everyday.
You're right - its better to make the map produce no displacement, if what is desired is no displacement. If you have no intention of displacing a polygon, it doesn't matter if its welded or not.
On the other hand, if you do want to displace a cylinder, to make a rib or whatever, you have to have all the polygons welded.
We still have no idea if that is the issue with this locomotive.
Thanks guys for your help. Just a couple of quick notes before I dive into another serries of tests on this.
The dispacement map starts at pure black; the only displacement on the main steam cylinder should be the bands and bolts.
All parts are using the same smoothing of 22.5 and it is rendered with smoothing off.
Other cylinder shapes on the model use the same type of map yet show no defects.
I'll render some more side-by-side tests and post here in a bit.
As an aside, the only time I have trouble with displacement at edges of maps is when I haven't carefully uvmapped and then drawn the displacement map to line up exactly. I make the displacement black/zero at corners of cubes to avoid it pushing the surface outward and splitting it.
"All parts are using the same smoothing of 22.5 and it is rendered with smoothing off."
Do you mean crease angle? That's kind of low - might be the problem. Try increasing that.
Hmmm if the engine is all one part, then may separating more parts off it woudl be wise?
That way, you could have different smoothing rates on different groups, and if they aren;t poseable anyway, the additional grouping would have little other effects.
Quote - "All parts are using the same smoothing of 22.5 and it is rendered with smoothing off."
Yes. I meant crease angle. I raised it and got the same result.
This is confusing me because back in November I rendered using the same maps and models, and didn't have the banding. I don't know what has changed.
Muralist, just a stupid question, but have you rendered it with displacement turned off, just to check if it really is the displacement causing the problem.
When I have a problem, I go through it step by step, turning off options until I find the real cause. Sometimes the cause is not what you think it is.
Yes, of course and it looks fine without displacement, except then I lose all the bolts and other detail. The strange thing is that the whole train uses the same shaders, only different maps (which are constructed in the same way) for each of 9 materials, all use displacement, and the only problem is with the main boiler. I thought it might be the geometry of that part so I rebuilt it and subdivided, and still no luck.
OK I got the model.
It renders just fine as you gave it to me. I don't see the polygon edges. It is not a crease angle problem. You have to lower the crease angle to 11 degrees to have a problem on these polys.
However, I can see artifacts (worse than you have shown) if I put a Reflect node into the shader and enable raytracing and have variable displacement.
If the displacement is even (doesn't have to be 0, just smooth and flat) there is no problem. By that I mean a featureless displacement.
These are interesting clues. I know that Poser has confusion regarding the reflections of displaced surfaces.
You might want to try adding a few edge loops near the displacements and see what that does. In my experience, if the displacement features cover only a small fraction of a polygon, reflections of that polygon can take on all sorts of meaningless information.
Another thing I've found is increasing the RayBias will decrease (but not eliminate) the problem.
I increased the Raybias on the Reflect node to 5 inches. This means it will ignore any self-reflections within 5 inches of the original reflection point. Now on this model, the cylinder cannot reflect itself without displacement. However, with displacement, it seems to be confused about what part sticks out where. Increasing the Raybias made it less confused.
I've now reinstalled P7 and am setting up a render: you're the second to post a render with no trouble, so I thought maybe my installation was corrupted. We will know in a few minutes. Here's the other good render.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2719401&page=2
There are no artifacts.
Quote - Here's what I mean. I put your displacement map and just a Reflect node on. (I have a 3D environment photo around the train.)
I'm confused about the cylinder reflecting itself. What do you mean? I see the black artifacts, but the areas around the bolts look good. Should I cut a line in each side of each band around the boiler?
Quote - This is how it renders without reflection. This is close to the material you gave me - I tweaked it a little bit, but its still using a fake reflection via Sphere_Map and an image.
So we know now that so far, with fake reflection, no artifacts, and real reflection, artifacts?
Tweaking Raybias helps. Decreasing displacement helps. Making smaller/more polygons helps.
SInce I'm not into modeling, I did the first two of those three.
Changed Raybias to 12 inches.
Decreased your displacement amount to .7 inch (you had about .98 inch).
Artifacts gone. (mostly - still a teensy bit at the top - but not really easy to see)
This model is kind of low-poly in places, which is fine, if I could turn on Smoothing. But you've got some wonky polygons that go crazy with smoothing. If you could adjust those polys (just cut them near the corners so they don't try to bend around so much) we could turn on smoothing and the round parts would really look round, instead of piecewise linear.
Cool model.
Okay I'll set it up for smoothing.
I rendered it with Poser default light and no lines appeared, then rerendered with my IBL light -- I'm now wondering whether my AO settings cause those lines. The light is in your Runtime/Lights/EnvPanorama folder -- will you take a look at the AO setting in the IBL light please.
Your reflective shaders look good; are you saying the renderer itself is randomly throwing artifacts in?
I generally use material AO nodes.
So that's a good clue - you have AO problems.
I'm pretty sure this is all due to trying to use ray-traced effects with displacement. We can work around these, but we have to respect Poser's limitations. Remember the third workaround is more polygons. You may want to try it.
BTW: Here's you locomotive after a 12 hour run. Needs washing again :)
I'm off to bed now. I'll check on you tomorrow.
It should look something like this. Using this technique, you can easily see what the AO is doing, and not confuse the issue with other shader stuff.
Having done this test with the AO node, I'm now certain this has to do with ray-tracing a displaced surface.
Maybe you should completely separate those rings and actually model them. Just use the displacement for rivets. Right now there are tons of AO artifacts. I didn't bother adjusting or tweaking or using higher render settings, so its pretty bad. It may not be possible to eliminate them.
