Thu, Jan 9, 12:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 08 11:53 pm)
Subject: Free IBL Generator TOOL for Poser
bagginsbill ( ) posted Sat, 16 August 2008 at 6:55 AM
Quote - hi estherau - I think you should be changing the Gamma In value in the shader to 1.0 for an HDR image.
Yes - this is right. Did you do that?
bagginsbill ( ) posted Sat, 16 August 2008 at 6:56 AM
Quote - I just checked bb's EnvSphere notes again... this is what he says for Poser Pro...
If used in Poser Pro, the use of PPro built-in gamma correction may produce undesirable results. If you're going to use Poser gamma correction, set Gamma In and Gamma Out = 1.0 in the EnvPanoramic and EnvPanoramicEffects shaders. The effects will produce different results in PPro+Gamma because it changes the interpretation of shader colors.
Also - in Poser Pro, did you remember to tell POSER, (not my shader) that the image is HDR and requires a Gamma In of 1.0?
bagginsbill ( ) posted Sat, 16 August 2008 at 6:57 AM
Quote -  I can't find an environments effects shader?
But I can change some settings in th envsphere prop materials.
Love esther
The EnvSphereEffects shader is in the package in the materials folder.
bagginsbill ( ) posted Sat, 16 August 2008 at 6:58 AM
Quote - ..and here is a test render of Blackhearted's GND2 with a new IBL light (using the map above) added into the scene.  the previous lights remain unchanged.
i won't bother y'all with another upload--but suffice it to say that illuminated w/ just the base lights she doesn't look 1/2 as good.  the IBL adds nice modelling to the shape.
best of all--while the pose it highly sensitive to the placement of the original lights--and actually looks bad from many angles due to the very striking lighting.  ...with the IBL added it--she's now pretty bulletproof--great in any pose and from any angle.
bagginsbill, thanks again for the great tools.  i will likely use this method for any fancy promo-type renders i do from now on....i've been wanting to try something like this....so this is cool!
question: can i make slight positioning tweaks to the tool object/camera so i can generate spherical reflection maps tuned to anywhere in the world?  dunno if that will even work.
r/.
Cool - move the camera anywhere you like. Just never rotate it.
bagginsbill ( ) posted Sat, 16 August 2008 at 7:00 AM
Quote -  okay - did that.
Here's how my pic looks now.
Love esther
Are you using Poser Pro gamma? (What is your rendering gamma?)
I'm going out all day today shortly - sorry I won't be around to sort this out with you interactively.
I'll check back later.
IsaoShi ( ) posted Sat, 16 August 2008 at 7:40 AM
*Quote - Also - in Poser Pro, did you remember to tell POSER, (not my shader) that the image is HDR and requires a Gamma In of 1.0?
The Poser Pro reference manual states: "HDRI files will be read and written in a linear fashion with a Gamma value of 1.0, ignoring whatever gamma value might be specified in that location."
Well, so they say. I'm not sure I believe it, so I'm on a mission now to find out if it's true, unless someone can save me the trouble!
/me walks away looking over shoulder...
estherau ( ) posted Sat, 16 August 2008 at 9:31 AM
 Hi everyone, I'm going well.  I turned gamma in and gamma out to 1. I had the checkbox checked for hdri optimized output,  But what really helped was when I turned off the gamma in the render settings as instructed. So now how do I fix his shadow.  I think it's looking pretty good otherwise. Love esther
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Sat, 16 August 2008 at 9:34 AM
 Oh, forgot to ask,
do I need to use/do anything with this:-
I haven't looked outside of my poser scene for this yet as my image is looking pretty nifty now already.
Love esther
bagginsbill ( ) posted Sat, 16 August 2008 at 3:29 PM
Esterau,
You were using Poser Pro with built-in gamma turned on. This causes all kinds of changes I didn't prepare you for. I built the EnvSphere shaders and GenIBL shaders for old-style Poser rendering. I can make everything work right under Poser Pro, but I have to do the opposite of various things.
Question: Is that image really HDR? It looks gamma corrected to me, even after you turned off gamma correction in Poser. Where did you get it? If that image is actually gamma corrected already, even if it is HDR, then you need to set Gamma In to 2.2, Gamma Out to 2.2.
Also, you used GenIBL with Render Gamma = 2.2. You made a bad IBL probe. Do it over again.
As for you shadow, why do you even have one? There are no shadows in the photo. If you want a shadow that long, you need to make the ground cover more space. The shadow has to fall on the ground - it can't extend beyond the ground - there's nothing there.
Also, to get the shadow to be the right color, you really need to use my new shadow catcher, which I have not released yet.
estherau ( ) posted Sun, 17 August 2008 at 8:56 AM
 ah thanks. Now I haven't made the new probe with gamma turned off yet. I think the hdri was a proper hdri freebie from dosch design but I would have to check to be sure. In the meantime, before I read this I tried adding a spotlight and look what happened. Well I will need some sort of shadow won't I, otherwise won't the chap look as if he is floating?? Love esther
estherau ( ) posted Sun, 17 August 2008 at 8:59 AM
 yes it was dosch,
oh and my spotlight above is partially underground - oops.
bagginsbill ( ) posted Sun, 17 August 2008 at 9:11 AM
No I don't think you want a spotlight. Look at the photo. Do you see any shadows anywhere? I don't. It looks like an overcast day. You have not shown me the whole panorama so i can't be sure, but it looks like there are poles or something on the left and they cast no shadows.
This is a case where you should only have contact shadows, not directional shadows. Contact shadows can be calculated using AO. My new shadow catcher will do those for you.
estherau ( ) posted Sun, 17 August 2008 at 9:15 AM
 okay, well I am looking forward to the shadow catcher.  I will wait.
Love esther
bagginsbill ( ) posted Sun, 17 August 2008 at 9:16 AM
If that was a freebie can you tell me where to get it? I'll be able to help you much better if I can work with the image myself.
So far, what I see is a washed out, low contrast gamma corrected image with poor resolution. I suspect this may be your doing, not Dosch, so I'd like to sort this out for you. There's a hundred things you could be doing wrong which could take days to sort out if it is you or the image, whereas I'll go straight to the best render of that image on my own. Then I'll know for sure if you can do better or it's hopeless.
Synthetic ( ) posted Sun, 17 August 2008 at 3:35 PM
BB--
thanks.  could you give me a few more tips as to exactly placing the dolly cam?  i'm having trouble grasping the relation between the IBL (viewpoint) i generate and where i put the camera.
do i essentially want to pretend that the dolly cam is the "eye" or viewpoint for whatever POV i am going to render from?  and then generate IBL from there?>
perhaps just a link to how the contents of the IBL sphere map relate to a 360 degree environment would be handy to if you have one.
thanks a bunch!
r/.
bagginsbill ( ) posted Sun, 17 August 2008 at 4:18 PM
The GenIBL-Lens and Probe are the devices that are sampling your environment. The camera is 42 inches "south" of those, but because of the way the lens works, it's as if the camera is 42,000,000 inches "south".
So all that really matters is where the lens is, because it is the image on the lens that is being rendered into your IBL probe.
The data collected by the lens is the light reaching that point in space, from all directions. So you should position the Dolly Camera so that the light being sampled by that lens is the light you want to use to light your main subject - usually a figure.
Depending on the scale of the environment, this can matter more or matter less.
For example, if sampling a football stadium, anywhere near the center, even 50 feet off, is about the same as anywhere else.
On the other hand, sampling inside a closet, you'd better be within a few inches of the actual position of your subject.
Regarding human figure lighting - you have to choose whether you want  to sample from just above the floor (like a few inches) or chest height, or head height. Again, the issue is it depends on what is nearby.
The impact of a wall or floor that is only an inch from the lens is going to be huge compared to the same wall or floor that is 60 inches from the lens, unless that wall or floor is already enormous, in which case it won't matter much.
Look, just pretend you're an IBL probe. Stand somewhere in a room and pick an object such as a door. Imagine the door is lighting you. Move closer to do the door. Now imagine the door is lighting you in this situation. Which way does the door make a bigger influence on how you are lit? Obviously when you're closer to it, so that it subtends a larger angle, therefore is contributing a greater percentage of the total ambient light reaching you.
When you use my EnvSphere, and measure lighting from it, every surface of the sphere is 750 feet from the origin. Moving the probe a few dozen feet won't make any noticeable difference. It will in a room that is only 20 feet long.
bagginsbill ( ) posted Sun, 17 August 2008 at 4:19 PM
By the way, use your main camera. Look at your lens and probe. Make the dolly camera visible, just like any other prop. Now you can drag the dolly camera around with the mouse, and you'll see where the IBL probe ends up.
estherau ( ) posted Sun, 17 August 2008 at 6:55 PM · edited Sun, 17 August 2008 at 6:55 PM
Attached Link: http://www.doschdesign.com/information.php?p=1
The file was called DoschHDR-ExtremeHires.hdr and came free with my C4D proggie in a folder called 3rd Party Textures 1  - it is a 42 MB file
aha, found the hdri, here, and there's a free car here too BTW. I am thinking of buying one the dosch packs for the city at night.  I've beens spending hours trying to make a vue city at  night and I think maybe I'll just go the backgrounds.
Love esther
bagginsbill ( ) posted Sun, 17 August 2008 at 10:03 PM
OK Estereau,
Dosch screwed up on this one. That image is gamma corrected - it is not linear color space.
So - even though it is an HDR image, you should treat it like a JPEG - use Gamma In = 2.2 and Gamma Out = 2.2.
This is a case where Poser Pro will do the wrong thing. It must not ignore the input gamma on this image because it is wrong. You must use a Gamma In of 2.2 to fix this image. I will show you some more things in a minute.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:08 PM
Let's keep this about Poser 7 or Poser Pro WITHOUT built-in gamma. Otherwise we'll get confused.
Here is a wide-angle view of that courtyard you're working with. This is using Gamma In = 2.2 and Gamma Out = 2.2 in my shader. Effectively, we can render it straight because it is already gamma corrected.
Key things to note: the sun is from the left and the entire courtyard is in shadow. Thus we see no ground shadows as there is no direct lighting going on there.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:10 PM
This is what yours looks like. This is an example of an image that has been gamma corrected twice. Learn to recognize it. It is wrong.
If you use Poser Pro built-in gamma, you will get this.
If you tell my shader to use Gamma In = 1.0 (for HDR images) you will get this.
For this image, we must treat it as gamma corrected, as if it was a JPEG.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:12 PM
This is back to Gamma In = 2.2 so we get good colors.
I'm showing you this one for a different reason. Looking in this direction, we can see the exact angle of the sun by the shadow across the building faces! Very useful to have an element like this in the image.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:27 PM
I decided to line up the courtyard pavement with my Poser universe axes, so I rotated the EnvSphere: yRotate = 53 degrees.
If I was going to show something in sunlight here, I'd do this first. With some trial and error, I have made an infinite light cast shadows at the same angle that I see on the buildings in the photo.
However, looking in the opposite direction at somebody standing in the courtyard, there will be no sun. We will want to use a small amount of directional light for the hazy specular produced by the sun in that part of the sky. We'll come to that in a minute.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:33 PM
Preparing my IBL now. Because I rotated the EnvSphere 53 degrees, mine is going to be oriented a little bit different than yours.
WIth the proper gamma correction applied to begin with, we see my IBL is much darker and richer. This is as it should be.
However, I'm concerned that I've lost some of the really bright stuff in the west (left side). So I'm going to render this one at half brightness, and use 200% intensity in the IBL light itself.
estherau ( ) posted Sun, 17 August 2008 at 10:37 PM
 funny thing was when I changed the gamma in and out in your dome back to 2.2 (leaving poser gamma off in render settings) there was absolutely no difference in my render.
love esther
bagginsbill ( ) posted Sun, 17 August 2008 at 10:38 PM
I just realized I gave incorrect instructions for increasing the dynamic range of an IBL probe.
To increase the range, decrease the brightness of the Lens Alternate_Diffuse. In my GenIBL page I said decrease the Color_Math to 127. That is wrong. Decrease the PoserSurface:Alternate_DIffuse to 127.
This is the result. The sunny sky area now has a nice gradient. The ground and buildings seem almost black - but that's just because your monitor sux. :) They are not black at all. Do not worry. This is what linear images look like.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:40 PM
Quote -  funny thing was when I changed the gamma in and out in your dome back to 2.2 (leaving poser gamma off in render settings) there was absolutely no difference in my render.
love esther
That's because Gamma In and Gamma Out are opposite effects. If they have the same value, you cannot tell them apart, but ONLY if you do nothing in the middle. If you had done something in the middle, such as increase saturation, or decrease brightness, the difference between Gamma In/Out = 1 versus Gamma In/Out = 2.2 would be apparent. This is the whole point of the gamma issue. When you do math on the image, are you doing it in linear color space or not? The only accurate math is in linear color space, so you must bring the image into that space before applying math.
Until you use effects, the actual gamma will not matter as long as they are equal. But I want to teach you to think about gamma - be aware of gamma - make sure your gamma is always right. Then you have more options and get better results when you use those options.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:46 PM
I hope you see that I'm doing this in real time - meaning I'm just typing what I'm doing, without any plan or rehearsal. I hope this impresses you with how well this works.
So I add a figure and a few props. I use the grid of my ground plane to figure out how to position my camera so that perspective matches up with the photo.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:48 PM
I attached the dark IBL I made above to my IBL and set it to 200% intensity.
I kept my Infinite, but at 50% intensity, with a yellow tone (RGB 1, 1, .7), and Shadow intensity .5, and ray trace shadow with blur radius of 10 pixels. All just guesswork. Let's see how it renders.
bagginsbill ( ) posted Sun, 17 August 2008 at 10:49 PM
Here's the render.
estherau ( ) posted Sun, 17 August 2008 at 10:54 PM
 Hi, that isimpressive and I am trying to follow but can't keep up - with 2 youngchildren bouncing all over me, one saying pleeeease I want to see macarena. I haven't changed the IBL at all - but I'm in poser pro - do I need to?  I just used your ordinary light probe which of course I redid after I rotated the dome.
estherau ( ) posted Sun, 17 August 2008 at 10:57 PM
 can you please show how you attached the IBL to the IBL that was set to 200?
Love esther
bagginsbill ( ) posted Sun, 17 August 2008 at 10:58 PM
The probes I posted are correct probes for any Poser.  As long as you turn off Poser's built-in gamma, your renderer is same as mine. (I have Poser Pro too, but I'm using P7 at the moment.)
Is your IBL contrast = 1?
If you're using the darker one, make sure your IBL intensity is 200% (or 2.0 in the material room).
If you're using the lighter one, make sure your IBL intensity is 100%.
While we cross posted, I made a couple material changes on the pole and box - just to give a sense of real material - nothing fancy.
bagginsbill ( ) posted Sun, 17 August 2008 at 11:00 PM
> Quote -  can you please show how you attached the IBL to the IBL that was set to 200? > Love esther
Sure.
estherau ( ) posted Sun, 17 August 2008 at 11:03 PM
 I used the original darker ibl without changing anything, then I set the intensity to 200 in this render - I';m rathe pleased, except of course he looks floaty with shadows off. Love esther
estherau ( ) posted Sun, 17 August 2008 at 11:04 PM
 when I changed the camera focallEngth should i have made a new IBL?
bagginsbill ( ) posted Sun, 17 August 2008 at 11:10 PM
No your camera position or focal length has nothing to do with IBL. Only thing matters for IBL is the environment position and brightness.
I know you are anxious for contact shadows in this image, so here I give you the simplest possible contact shadow catcher. I'm making a much more sophisticated one, but this will do for you. Only two nodes needed.
Change your ground shader to this. In the MaxDist of the AO node, I wrote 200, but Poser changed it to 199.99. Also, my 200 is with display units in Inches. You must convert, or switch your units to Inches temporarily, before typing in 200.
bagginsbill ( ) posted Sun, 17 August 2008 at 11:15 PM
Here is a better render showing the ground contact shadows. Not bad for 2 nodes eh? Click to enlarge.
estherau ( ) posted Sun, 17 August 2008 at 11:17 PM
okay - thanks
have top go - baby crying
bagginsbill ( ) posted Sun, 17 August 2008 at 11:17 PM
When doing photo composite, it is necessary to make the figures less sharp with most photos, while also making the photo more sharp if possible.
Here are the render settings I used in the last image. Make a render of your own, then change to these settings, and render again. Study the differences, if any.
bagginsbill ( ) posted Sun, 17 August 2008 at 11:18 PM
Enjoy your baby :)
Mine are in high school.
OK I think you're all set to play now. I'm going to bed. It is 12:18 am and I have to leave for work at 6:15.
Talk to you tomorrow.
estherau ( ) posted Mon, 18 August 2008 at 6:20 AM
HIgh school - that should make for a fairly quiet house at times then.  Mine haven't started school yet but my 16 month old boy has just learnt to climb.
Well they are both asleep now, but sadly so are you and now I am stuck.
I just can't get shadows right.  Now, silly question I know, but you do have to have shadows on for the IBL light don't you?  And then you had an infinite light as well, also with shadows on?  And you had a diffuse light too?  Do these all have shadows on or off.  If I turn off all shadows I get no shadows, even using that ground material setting for shadow catching that you showed me, and shadows on for render settings.
Love esther
PS I have to work tomorrow, and when I get home you will be asleep, but I look forward to seeing "lighting for dummies" in the posts here.
estherau ( ) posted Mon, 18 August 2008 at 7:03 AM
 weird - I think I better start from scratch
estherau ( ) posted Mon, 18 August 2008 at 7:19 AM · edited Mon, 18 August 2008 at 7:23 AM
 I restarted poser pro and now everything seems to be working and it seems I have caught a little contact shadow with my catcher. Love esther PS it is very subtle though - if it's there at all...
bagginsbill ( ) posted Mon, 18 August 2008 at 4:02 PM
I see the AO. Sometimes Poser AO misbehaves, especially at certain shallow camera angles like this one.
I usually raise the Irradiance Cache value and it fixes it. Of course, that costs render time.
bagginsbill ( ) posted Mon, 18 August 2008 at 4:06 PM
*Now, silly question I know, but you do have to have shadows on for the IBL light don't you?  *
No I don't. I'm using no shadows on the IBL - I always use material based AO - more control and better quality. Fewer odd behaviors, less grainy, and faster usually.
*And then you had an infinite light as well, also with shadows on?  *
Yes. But the shadow catcher I showed you is not doing directional shadows at all, so it doesn't matter.
*And you had a diffuse light too?
Just the IBL and the infinite. That's all. Sometimes you want to make the infinite only do specular. This is one of those times.
*Do these all have shadows on or off.
Shadows on for the infinite - this is so you don't get highlights on the 3D in wrong places. However, the shadow catcher using only AO will not catch directional shadows. My super duper new shadow catcher can do directional only, AO only, or both.
*If I turn off all shadows I get no shadows, even using that ground material setting for shadow catching that you showed me, and shadows on for render settings.
Probably because of the Irradiance Caching.
Material-based AO never needs a shadow on the light - but you do have to enable ray-tracing and enable shadows in render options.
vincebagna ( ) posted Mon, 18 August 2008 at 4:40 PM
Your super duper new shadow catcher seems very intriguing... :)
estherau ( ) posted Tue, 19 August 2008 at 5:37 AM
 this is with 2 lights, infinite and IBL.  In this one the IBL shadow is on and infinite is off, and I think I like this one a little better than the next one.
estherau ( ) posted Tue, 19 August 2008 at 5:38 AM
 In this one, the IBL shadow is off, but infinite shadow is on.
In both I had the irradiance cache turned up to 100%.
There is definitely a contact shadow that can be seen where the ball meets the ground which I presume is the shadowcatcher working.
Love esther
bagginsbill ( ) posted Tue, 19 August 2008 at 6:13 AM · edited Tue, 19 August 2008 at 6:14 AM
Uuuh, those two images are identical.
Yes there is contact shadow. If you want to see how much it contributes, simply hide the ground (Ctrl-G) and render without it.
Also, you can alter the Ambient_Occlusion node properties. I was just giving a starting point.
If you want bigger contact shadow, increase the MaxDist value.
