Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
"This is because most probes are backwards. Don't argue with me."
:) LOL! I think I'll use that as my quote here at Rendo!
Thanks for the prop!
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Quote - I saw the site. Thanks man!
What's this Matmatic?
Just the single best shader program known to mankind! :)
Download it here:
http://sites.google.com/site/bagginsbill/free-stuff/matmatic
Find out how to use Matmatic at the bottom of the first post in this thread:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2722867
say." - Ghandi
BB--you aren't working for Smith-Micro because.......
DUDE! You're a creative machine! Now, I'm going "dude". :lol: LOLOLOLOLOLOL
I cannot save the world. Only my little piece of it. If we all act
together, we can save the world.--Nelson Mandela
An inconsistent hobgoblin is
the fool of little minds
Taking "Just do it" to a whole new level!
Next week I'll publish some tools you can use to make an IBL for your scenes, using only Poser. It's a prop with a special shader, and a camera setting.
You set up an environment sphere, rotate it how you want it, and apply effects if desired. You load the special prop and camera settings, render, and save the resulting IBL probe. Then you load it into a light.
Optionally, you load up big props like buildings and ground cover, trees, cars, whatever you want to include in the environmental lighting. You light them using the first probe. Then you render a second probe that includes these other surrounding props. In the end you have a custom IBL probe that includes the sky and stuff from the photo, as well as the big props you've put in the scene.
It usually takes less than 5 minutes and you'll get perfect matching, regardless of how you spin the environment sphere, or what special effect you put on the sky.
Hypothetically--if I render an image in Vue up to 1600x1200 px as a bmp file, could that be used instead of a photo? Vue affects some poser materials in less than a friendly way, and that might be quicker to bypass the whole thing with dome and the new tool of which you speak.
I think.
Quote - Hypothetically--if I render an image in Vue up to 1600x1200 px as a bmp file, could that be used instead of a photo? Vue affects some poser materials in less than a friendly way, and that might be quicker to bypass the whole thing with dome and the new tool of which you speak.
I think.
I agree with the way Vue uses poser materials (C4D is FAR better at it) but I have already rendered using 'normal' images in the envshpere. It works fine but is not without problems, ie boundary wrapping. However you can minimize that by roataing the sphere on it's y axis. The other issue would be matching IBL lights for the scene.
i7 6800 (6 core/12 thread), 24 GB RAM, 1 gtx 1080 ti (8GB Vram) + 1 Titan X (12GB Vram), PP11, Octane/Poser plugin, and a partridge in a pear tree.
Oh, and a wiener dog!
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2697974&page=3#message_2985027
Angelouscuitry (see link) says that Vue can directly render a scene (or at least a sky) as an equirectangular image. Such an image would then directly be usable on the EnvSphere or EnvDome - not sure which.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
In that thread I linked above, on page 2, I actually said how to make your own IBL.
But that was before I understood the problem of gamma correction, and also before I fully understand that "mirror ball" format is not the same as "angular map" format. You need angular map format for accurate IBL in Poser, and you need to take gamma correction into account for accurate color reproduction. That's why I have a custom prop shape and a custom shader - not a straight up reflection shader.
If you want to try the technique discussed in that thread, even though it is wrong on two counts, it is written here:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2697974&page=2#message_2983155
Awesome stuff, oh the God of shaders! :thumbupboth:
We're not worthy!
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
The lighting is very subdued and yellow. There is a ceiling mounted light fixture with 4 bulbs, and the walls are yellow. The cabinets and appliances are white, but the lighting makes them look cream colored. I generated and loaded an IBL image, and I also set up a dim, yellow spot light from above. (Necessary for speculars, and also because the original photo is LDR, not HDR, so the hot spot information from the light bulbs are missing in the photo.)
I placed Simon into the scene, applied VSS shaders to him, and rendered.
gasp there's a nekkid man in the kitchen! I think I like it ;)
yurs?
BadKittehCo
and product support
(The man is drunk and demanding food preparation. His wife and sister are disgusted. Again.)
I have Poser 7 where do I download for that? Says to contact you? Starting with nothing so would need to get pointed to the right ones. The only thing I found was for Poser 6 which I don't use. Not sure how much work it's going to take to set this all up as I don't understand any of it at this point.
Thanks
Marque,
Sorry about the delay in answering. I have uploaded the Poser 7 version of matmatic beta 1 scripts to my matmatic page.
In case it result useful for this prop, there is a program called HDRI Shop it's free:
With this you can converst a lat/long picture to a probe then you can use the matching IBL as in the env sphere. the only thing I noticed is that the sphere must me rotated 180º in the Y axis to match properly.
Good job ima70 - I meant to tell people about that program but I forgot. And you're correct, you must rotate the sphere 180.
OR
Rotate the image in HDRSHOP by half its width.
However, while this does work, there is a problem if you're going to use my special effects. In such cases, the original image does not have the correct colors and brightness. Nor will it take into account any large nearby props (such as a wall) or your ground color (if you're using a 3D ground.)
That is why I'm working on my IBL Generator tools. With a couple clicks you'll be able to render a 100% perfect IBL probe to go with any scene you've set up, including your props, your special effects, and whatever rotation you happen to have used on the EnvSphere.
Attached Link: http://sites.google.com/site/bagginsbill/free-stuff/genibl---ibl-generator
IBL generator is done. Go get it.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
I typed many useless things. Then I found the word "equirectangular". Very unique and very specific.
From Google Image search, that word led me to flickr.com. In flickr alone there are thousands and thousands of equirectangular images. Many are in excellent super high resolution, 10000 by 5000!
Quote - I typed many useless things. Then I found the word "equirectangular". Very unique and very specific.
thank you for your help. do you have to register?
If you're going to directly see the sphere, then yes biggest is best, especially if you're not using a wide-angle camera.
For reflections only, high resolution doesn't matter much.
For environmental lighting, high resolution doesn't matter at all.
The only reason not to use the biggest is to save memory and perhaps compute time. I've seen Poser go nuts taking all day rendering reflections of a 10K by 5K e-sphere image, while in the same scene just zipping through reflections of a 6K by 3K e-sphere image.
A question: I have rendered using your Environment Sphere Dome, and I think what you did was excellent. How is that when I render I get fuzzy background? Is it because of the low resolution image? Should I move my camera or better yet, size the sphere down a bit?
Other than that, I like it?
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Quote - A question: I have rendered using your Environment Sphere Dome, and I think what you did was excellent. How is that when I render I get fuzzy background? Is it because of the low resolution image? Should I move my camera or better yet, size the sphere down a bit?
One of the most curious things about the environment sphere is this: changing its size has little to no effect on how big looks, or on how fuzzy it looks.
The fuzziness is due to you looking at a tiny part of the photo. You need a really big photo to get away with looking at only a tiny part.
Everyone should experiment, please, and learn how things work. Change the sphere scale to 50% - render it? See no change. Try 10%. See no change. If you get small enough, though you'll start to see perspective distortion - i.e. where your camera is will change how it looks.
Try changing your camera focal length. Go smaller. Go bigger. Move the camera to bring your subject into view at different focal lengths. Observe the changes in the background.
Great picture, ice-boy. Try animating it - it's even more stunning.
Very nice animation.
I'm not sure why my sphere renders faster than others. Perhaps because I kept the poly count lower? Higher poly count slows things down. On the other hand, going too low on poly count results in larger polygons, which tend to be "seen" by the ray-tracer more often, and requires more culling. Or maybe it is because my polygons are facing inwards, unlike every other sphere I've ever seen.
ice-boy:
Everything I do is faster than anybody else's implementation. :)
I'm impressed that you notice the subtle stuff I do - always. You're the only one who really got excited about gamma correction in shaders, and realized you could do it yourself all over the place.
My new shadow catcher has the same behavior. Poser has a built-in shadow catcher. I am making a new one in shaders, which should be slower. Mine does 10 times more stuff, renders better, and has lots of control parameters. But mine is faster than the built-in one.
I work on these tools for days, weeks, even months. The EnvSphere and its shaders took me about 150 hours. I did over 400 test renders. The GenIBL tool took months of research, experimenting, and testing. I went down so many wrong paths on that one. Then one day, while I was on my usual 2 hour drive to one of my clients, I was thinking about how refraction works, and I worked out how to do the perspective correcting lens in my head. I was so excited, I coded it up as soon as I got out of the car. I was so surprised it worked. Who would have thought that setting the index of refraction to 1,000,000 would have any practical use? Still, after that I fine tuned the number of polygons in the probe for hours, trying to find the minimum that produced accurate reflections, so it would be fast.
Quote - ice-boy:
well i notice things buecause i read everyhitng you writte. i like all the technical stuff that you do. i dont always understand them but i try my best to do.
you are obvious a very smart man. you are also a thinker. i think you wrotte many time that this is your hobby and that you like the chalange. i agree.
i just hope ...i really hope that one day the people who are working on poser will take your ideas.
the best things about this new sphere is :
about gamma correction: are you really sure that i am the only one? gamma correction was basicly the last step where you made poser renders look.....REALISTIC. the difference is obvious. i really think there should be a sticky. and a mini tutorial. there should be NOOOOO renders without gamma correction.
shadow catcher? hmmm. whats this? when you render only the shadow and make the ground invisible?
GEN IBL is groundbreaking :)
In the sample note that I used a displacement map (granite) applied to the ground plane to suggest the grassy ground in the photo.
Boni
i'm not BB, but i'll take a crack at part of this...
first of all, he has a better shadow catcher that he gives away. i suggest pointing at that instead of the ground plane one.
second, you can fake it. you've already got the ground worked out, now all you need is the sides and top. if you don't want to make more of a pano and use BB's environment sphere, just use a box. the thing is to give his IBL generator something to work with that works fairly well. IBLs aren't very precise, so you don't really have to be precise with the environment. also, we don't really know what we can't see, so you can have some fun. just don't give the IBL generator a huge unnatural patch of a solid color. once you have a rough environment on all sides, load up his IBL generator and make some IBLs. for anything lit, i use the method suggested by (iirc) Synthetic. and iterate my IBL renders to simulate the bounce. but if everything is already lighting independent (like a background photo usually is), then i'd just do the one IBL render.
Attached Link: http://sites.google.com/site/bagginsbill/free-stuff/environment-sphere
Here is some free stuff to create 360 degree environments in Poser. It includes a special effects shader that is very handy for transforming sky photos for more dramatic results.Follow the link to my free stuff area for this freebie. There are several sub-pages with lots of info and instructions.
Go directly to here > http://sites.google.com/site/bagginsbill/free-stuff/environment-sphere/environment-sphere-demo-renders < to see some demo renders.
If you have questions or need help or you find bugs, please report them here. I'll respond as soon as possible.
Ask quick, though, because tomorrow afternoon I go out of town for 2 days on business and I won't be Poserizing.
