Tue, Dec 24, 7:07 PM CST
Subject: tips to create foreground detailed rock cliff?
lightning2911 ( ) posted Tue, 24 February 2009 at 11:48 AM · edited Tue, 24 December 2024 at 7:16 AM
i cannot remember where i have seen this but i have a memory of a craggy rock cliff. i guess it was some sort of slate where you had all these layers protruding outwards making the surface look kind of like a pile of tiles.
rocktest
this is what i have come up with so far. its a horizontal and vertical stretched voroin 4th neighbour pattern used for displace/bump. but it still looks very geometric. so i would like to know if you have tips for making this more irregular. maybe more bump nodes? or just some good surface colour settings?
thanks in advance
chris
dburdick ( ) posted Tue, 24 February 2009 at 1:30 PM
Interesting you should ask this question as I'm working on exactly the same type of thing:
  1. see the attached image
  2. also check this image out http://www.renderosity.com/mod/gallery/index.php?image_id=1838272
It's a bit tricky when using displacement on curved or irregularly shaped objects/terrains.  I was able to come up with something by using World Cylindrical mapping with a Squares noise node.  I'm still working to try and perfect this and then I will Metanode the variables (e.g. roughness, spacing, etc) and then throw in into my Rock My World - Rock Generator.
Sue88 ( ) posted Tue, 24 February 2009 at 9:30 PM
That looks great!
lightning2911 ( ) posted Wed, 25 February 2009 at 12:26 AM
just when i thought i would not need rock my world :-)
your example looks very good and more in the direction i was hoping to be able to go.
i will try your settings and see what i am able to do.
lightning2911 ( ) posted Wed, 25 February 2009 at 2:12 AM
i played around and this looks great. a new path to experiment ...
first world-cylinder mapping on a cylinder with square noise for bump
square noise
and then i tried the standard chipped material and reversed the bump direction with an opposite filter node.
chipped reversed
now i am looking forward to the rock my world set as i find it very useful for learning to study materials from the pros!
dburdick ( ) posted Wed, 25 February 2009 at 8:52 AM
Looking pretty good there lightning - I think you're on the right path
